MHB Nick's Calculus Problem: Find Closest Point on Plane
  • Thread starter Thread starter MarkFL
    Plane Point
The calculus problem involves finding the closest point on the plane defined by the equation x - 2y + 3z = 6 to the point (0,1,1). The objective function is the square of the distance from any point (x,y,z) on the plane to (0,1,1). Using Lagrange multipliers, the system of equations derived leads to expressions for y and z in terms of x. Solving the resulting equations yields the closest point as (5/14, 2/7, 29/14) on the plane. This solution effectively addresses the optimization problem posed.
MarkFL
MHB
Here is the question:
Need help with calculus problem? Optimization.?
Find the point on the plane x - 2y +3z = 6 that is closest to the point (0,1,1).
I can't figure this out. Does anyone know how to do this? Thanks.
I have posted a link there to this thread so the OP can see my work.
Mathematics news on Phys.org
Hello Nick,
Let's let our objective function be the square of the distance from the point on the plane $(x,y,z)$ to the given point $(0,1,1)$:
$$f(x,y,z)=x^2+(y-1)^2+(z-1)^2$$
The point $(x,y,z)$ is constrained to be on the given plane, hence our constraint is:
$$g(x,y,z)=x-2y+3z-6=0$$
Using Lagrange multipliers, we obtain the system:
$$2x=\lambda$$
$$2(y-1)=-2\lambda$$
$$2(z-1)=3\lambda$$
This implies:
$$\lambda=2x=1-y=\frac{2}{3}(z-1)$$
From this, we obtain:
$$y=1-2x,\,z=3x+1$$
Substituting for $y$ and $z$ into the constraint, we find:
$$x-2(1-2x)+3(3x+1)-6=0$$
Solving for $x$ (and using the values for $y$ and $z$ in terms of $x$) we find:
$$x=\frac{5}{14}\implies y=\frac{2}{7},\,z=\frac{29}{14}$$
Thus, the point on the plane $x-2y+3z=6$ that is closest to the point $(0,1,1)$ is:
$$\left(\frac{5}{14},\frac{2}{7},\frac{29}{14} \right)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
