MHB NICK's question at Yahoo Answers regarding a solid of revolution
  • Thread starter Thread starter MarkFL
    Revolution Solid
The volume of the solid obtained by rotating the region bounded by the curves y=x, y=0, x=2, and x=4 about the line x=1 is calculated using both the washer and shell methods. The washer method reveals that the volume is V=76π/3, derived from two integrals that account for varying inner and outer radii. The shell method confirms this result, yielding the same volume through a different calculation approach. Both methods validate the accuracy of the volume computation. The final answer for the volume is 76π/3.
MarkFL
MHB
Here is the question:
Calculus ii question!?
Using disks or washers, find the volume of the solid obtained by rotating the region bounded by the curves y=x, y=0, x=2, and x=4 about the line x=1.
Volume = ?
Here is a link to the question:
Calculus ii question!? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello NICK,
Using washers, we find that we have one interval where the inner radius is a function of $y$, and another in which the inner radius is constant. For both intervals, the outer radius is constant.
Thus, we find the volume is:
$$V=\pi\left(\int_0^2 3^2-1^2\,dy+\int_2^4 3^2-(y-1)^2\,dy \right)=$$
$$\pi\left(\left[8y \right]_0^2+\left[9y-\frac{1}{3}(y-1)^3 \right]_2^4 \right)=\pi\left(16+27-\frac{53}{3} \right)=\frac{76\pi}{3}$$
To check our work, let's use the shell method:
$$V=2\pi\int_2^4(x-1)x\,dx=2\pi\left[\frac{x^3}{3}-\frac{x^2}{2} \right]_2^4=$$
$$2\pi\left(\frac{40}{3}-\frac{2}{3} \right)=\frac{76\pi}{3}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
