B NIST database and compressibility factor Z
The NIST database offers extensive data on various fluids, including Nitrogen, across a wide range of pressures and temperatures. However, there are concerns regarding the accuracy of the compressibility factor data, as it may not align with established charts like Standing and Katz's. Users are questioning whether the NIST data is based on approximations or calculated using specific formulas. The original poster later found the reference articles that clarify the data sources. This highlights the importance of verifying data accuracy when using large databases for experimental research.
FranzSC
TL;DR Summary
Is NIST database accurate?
There's a huge volume of data on NIST database:
https://webbook.nist.gov/cgi/fluid....nit=m/s&VisUnit=uPa*s&STUnit=N/m&RefState=DEF
I'm interested in getting extensive sets of experimental data for the compressibility factor of Nitrogen. Could not find them anywhere until now, so it seems strange to me that NIST has a huge database for all ranges of pressures and temperatures. Do any of you know if the data on NIST database are approximations calculated with some formulae? For example, the NIST data do not seem to represent the Standing and Katz's chart accurately. Thanks.
My bad, I finally found the reference articles for the database. Sorry.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Does Poisson's equation hold due to vector potential cancellation?'
Imagine that two charged particles, with charge ##+q##, start at the origin and then move apart symmetrically on the ##+y## and ##-y## axes due to their electrostatic repulsion. The ##y##-component of the retarded Liénard-Wiechert vector potential at a point along the ##x##-axis due to the two charges is $$ \begin{eqnarray*} A_y&=&\frac{q\,[\dot{y}]_{\mathrm{ret}}}{4\pi\varepsilon_0 c^2[(x^2+y^2)^{1/2}+y\dot{y}/c]_{\mathrm{ret}}}\tag{1}\\...
