Nitrogen-Vacancy centres in Diamond for NMR spectroscopy
In summary, the diamond NV center is a spin 1 system that can be read optically. Its energy splitting between different spin states is sensitive to magnetic fields, which can be measured by applying microwave radiation and looking for fluorescence dips. This allows for nanoscale magnetometry, including measuring the NMR and EPR spectra of materials. The NV center also allows for single atom defect detection and can be used to create a nanoscale NMR scanner.
Jon.G
45
Hello,
I have been looking into NV in diamond and how it can be used for nanoscale magnetometry, and was wondering if anyone could help explain how it works or link to a paper that does.
Is it just a spin 1 state (splits to 3 levels) that undergoes NMR or is there something else happening? I'm just having a bit of trouble seeing what's going on, and how it can be used to help image other 'things' (for lack of a better word - I'm a little tired :S )
I thought NMR spec. allowed us to discover the properties of a sample, and don't really understand how placing these centres close to it would help.
Thanks for your time.
I have studied a little bit about nuclear magnetic resonance, but am no expert, and probably don't have an answer. Perhaps I can give a little info that you might find useful, but I might be repeating what you already know. With the NMR/MRI, in a uniform magnetic field, the resonances of like atoms would all be at the same frequency without any spatial information provided. To get spatial information, I think the usual technique is to introduce well- controlled gradients in the static magnetic field so that localized resonances occur at a given frequency. Paul Lauterbur and Peter Mansfield were awarded a Nobel prize in 2003 for developing these techniques. To get down to a nanometer type resolution, it is likely additional refinements would be necessary, but that is about as much info as I have for the present.
The diamond NV center is a spin 1 system, where the spin state can be read out optically. More specifically, it fluoresces more when it is in the ms=0 spin ground state as opposed to the ms=-1 or ms=+1 states. The energy splitting between the different spin states is sensitive to the magnetic field via the Zeeman effect HZ=gμBB where B is the magnetic field, mu_B is the bohr magneton, and g=2. So if you can measure the splitting between the different ms spin states then you can measure the magnetic field. This is accomplished by applying microwave radiation to the NV and sweeping the microwave frequency. When the microwave frequency is resonant with either the ms=0 to -1 or ms=0 to +1 transitions it will induce coherent oscillations of the spin state, which causes the fluorescence to decrease as compared to just the normal ground state occupation of the ms=0 state. So by looking for the fluorescence dip at a given frequency you know the energy splitting and hence the magnetic field. This is one technique to measure static magnetic fields - it is also possible to measure sensitively fluctuating AC magnetic fields by applying microwave pulses to the NV center.
The main difference compared to normal Nuclear Magnetic Resonance or Electron Paramangetic Reasonance measurements is that the diamond NV can be read out optically using lasers which can address single atom defects. NMR and EPR are bulk methods which rely on measuring the microwave absorption of a very large ensemble of spins.
Single NV centers can be brought within a couple of nanometers of the diamond surface, where you can place some interesting material which you want to make magnetic measurements. This can be used to actually measure the NMR or EPR spectrum of nanoscale materials, which is not possible with conventional techniques.
Here is a pretty nice talk discussing the NV center capabilities and using it make a nanoscale NMR scanner:
Likes Charles Link
Related to Nitrogen-Vacancy centres in Diamond for NMR spectroscopy
1. What are nitrogen-vacancy (NV) centres in diamond?
Nitrogen-vacancy (NV) centres are atomic defects in the crystal structure of diamond where one carbon atom is replaced by a nitrogen atom and there is a missing carbon atom (vacancy) next to it. These defects create unique electronic and magnetic properties that allow for their use in various applications, including NMR spectroscopy.
2. How do NV centres in diamond work for NMR spectroscopy?
NV centres in diamond have a spin-active electron that can be polarized and manipulated with external magnetic fields. This spin state can be detected through changes in the fluorescence of the NV centre, which allows for the measurement of magnetic fields. This can be applied to NMR spectroscopy, where the magnetic fields of molecules can be detected and analyzed.
3. What makes NV centres in diamond suitable for NMR spectroscopy?
NV centres in diamond have several properties that make them ideal for NMR spectroscopy. They have a long coherence time, meaning their spin state can be maintained for a longer period of time, allowing for more accurate measurements. They also have a high sensitivity to magnetic fields, allowing for the detection of even small changes in magnetic fields.
4. What are the advantages of using NV centres in diamond for NMR spectroscopy?
Compared to traditional NMR techniques, using NV centres in diamond offers several advantages. First, it does not require a strong external magnetic field, making it more portable and versatile. Second, it can measure a wider range of magnetic fields, including those in the nanoscale. Finally, it has the potential for higher sensitivity and faster data acquisition.
5. What are the current applications of NV centres in diamond for NMR spectroscopy?
NV centres in diamond are currently being used in various applications, including the detection and analysis of biomolecules, imaging of small-scale magnetic fields in biological systems, and characterization of quantum materials. They also have potential applications in quantum computing and sensing.
