No idea to do this differential equation queation.
In summary, Maple 14 gets the solution as y = (x/5)*[1+Z(z)^5], where Z(x) is a solution of the equation 5z^6 - cxz^5 - cx=0, and c is an arbitrary constant.
vkash
318
x2y1+xyy1-6y2=0
find solution for this differential equation.
y1 mean dy/dx
How to do this question. I have no idea.
x2y1+xyy1-6y2=0
[tex] x^2 \frac{dy}{dx} + xy\frac{dy}{dx} - 6y^2 = 0 [/tex]
I don't know how to do it systematically, but one may reason about it.
If we assume [itex] y [/itex] is an nth degree polynomial in x, the degrees of the 3 terms are n+1, 2n, 2n. For the terms to cancel, we need n+1 = 2n, so n = 1.
So try letting [itex] y = Cx + D [/itex] and solve for [itex]C[/itex] and [itex]D[/itex].
If there is a "proper" way of doing it, I hope someone tells us.
Hint: Try differentiating x^2*y^2.
y = (x/5)*[1+Z(z)^5], where Z(x) is a solution of the equation 5z^6 - cxz^5 - cx=0, and c is an arbitrary constant. When you take c = 0 the solution is pretty simple; otherwise, it is likely horrible.
RGV
I wonder if human beings are supposed to do it by "integrating factors"
[tex] (x^2 + xy) \frac{dy}{dx} - 6y^2 = 0 [/tex]
Is not an "exact" differential equation, but perhaps there is an integrating factor M(x,y) so that:
[itex] M(x,y)(x^2 + xy)\frac{dy}{dx} - 6M(x,y)y^2 = 0 [/itex] is exact.
sorry sorry sorry this is wrong question.
The correct question.correct one is
x2y12+xyy1-6y2=0
Factor this.
Let u = x·y',
then u2 + uy -6y2 = 0
Factor the left hand side.
(u+3y)(u-2y)=0
Solve for u, then put x·y' back in for u .
Can you take it from there?
Related to No idea to do this differential equation queation.
What is a differential equation?
A differential equation is a mathematical equation that relates a function with its derivatives. It is commonly used to model physical phenomena and can be solved to find the behavior of the function.
Why are differential equations important?
Differential equations are important because they provide a mathematical framework for understanding and predicting how systems change over time. They are used in a wide range of fields, including physics, engineering, economics, and biology.
How do you solve a differential equation?
There are various methods for solving a differential equation, depending on its type and complexity. Some common techniques include separation of variables, substitution, and using integrating factors.
What are the applications of differential equations?
Differential equations are used to model and understand a variety of phenomena, such as population growth, radioactive decay, chemical reactions, and electrical circuits. They are also used in engineering to design and optimize systems.
Can I use software to solve differential equations?
Yes, there are many software programs available that can solve differential equations numerically. However, it is important to have a good understanding of the underlying concepts and techniques in order to accurately interpret and use the results.
