No integer whose digits add up to ## 15 ## can be a square or a cube
The discussion centers on a proof that no integer with digits summing to 15 can be a square or a cube. It establishes that integers can only yield specific remainders when squared or cubed modulo 9, specifically excluding the possibility of yielding a remainder of 6. The proof relies on the property that a number's congruence modulo 9 is equivalent to the sum of its digits modulo 9. Some participants emphasize the need for clarity in assumptions made during the proof, particularly regarding the congruence of digits and powers. Overall, the conclusion is that the proof is valid, but it requires explicit acknowledgment of certain assumptions for clarity.
Math100
Prove that no integer whose digits add up to ## 15 ## can be a square or a cube.
[Hint: For any ## a ##, ## a^{3}\equiv 0, 1, ## or ## 8\pmod {9} ##.]
None.
Proof:
Let ## a ## be any integer.
Then ## a\equiv 0, 1, 2, 3, 4, 5, 6, 7 ##, or ## 8\pmod {9} ##.
This means ## a^{2}\equiv 0, 1, 4, 9, 7, 7, 0, 4 ##, or ## 1\pmod {9} ## and ## a^{3}\equiv 0, 1, 8, 0, 1, 8, 0, 1 ##, or ## 8\pmod {9} ##.
Thus ## a^{2}\equiv 0, 1, 4 ##, or ## 7\pmod {9} ## and ## a^{3}\equiv 0, 1 ##, or ## 8\pmod {9} ##.
There exists no integer ## a ## such that ## a^{2}\equiv 6\pmod {9} ## or ## a^{3}\equiv 6\pmod {9} ##.
Therefore, no integer whose digits add up to ## 15 ## can be a square or a cube.
Math100 said:
Homework Statement:: Prove that no integer whose digits add up to ## 15 ## can be a square or a cube.
Relevant Equations:: None.
Proof:
Let's see:
\begin{align*}
N&=a_k\cdot 10^k+\ldots +a_1\cdot 10 +a_0 = a^m \text{ with } m\in \{2,3\} \text{ and } \sum a_i =15\\
&\Longrightarrow \\
N&\equiv a_k \cdot 1^k +\ldots +a_1\cdot 1 +a_0 \equiv 15 \equiv 6 \pmod{9}
\end{align*}
Your solution is correct, I just needed ##10^j\equiv 1\pmod 9## to close the gap between ##\sum a_i =15## and ##a^m \not\equiv 6 \pmod 9.##
Likes Delta2, malawi_glenn and Math100
But that is the only non-trivial step! Without it the 'proof' is worthless.
The OP has done many problems here where he states that a number modulo 9 is equal to the sum of its digits (in base 10) modulo 9 so in his mind he has this step self implied I think. But of course the objective reader can't be inside his mind to know what he is thinking.
Indeed. And even if the OP decides to assume this without proof, they still need to state that they are assuming this without proof. The same goes for the assumption that ## a^2 \pmod 9 \equiv (a \pmod 9)^2 \pmod 9 ## at the beginning.
Why the OP doesn't think it is important to include these assumptions but thinks that it is important to state that ## a \in \mathbb N \Rightarrow a\equiv 0, 1, 2, 3, 4, 5, 6, 7 \text{ or } 8 \pmod 9 ## is unfathomable to me.
