No load voltage / resistance question
In summary, the voltage divider circuit is designed to handle a load resistor of 3.6 kΩ or less. If the load resistor is greater than 3.6 kΩ, the no load voltage will drop below 7.5V. When the divider is loaded, v0 should not drop below 7.5V.
orangeincup
123
The no load voltage in the voltage divider circuit is 8V. The smallest load resistor that is ever connected to the divider is 3.6 kΩ. When the divider is loaded v0 is not to drop below 7.5V.
Part 2)
Assume the voltage divider has been constructed from 1 W resistors. What is the smallest resistor that can be used as rL before one of the resistors in the divider is operating at its dissipation limit.
r1*r1/(r1+r2)
v(r1/(r1+r2))=v0
I started by saying
eq 1) Vo=40*R2/(R1+R2), therefore R1=4R2
eq 2) Re=R2*RL/(R2+RL)
eq 3) 40*Re/(Re+RL)=7.5V, which reduces to R1=4.33Re, therefore 4R2=4.33Re.
I'm not sure where to go from here. What do I do with the value of 3600 kΩ? I tried that below but didn't get very far with it:
eq 4)
Re=4.33Re*3600/(3600+R2)
Can you explain your first relevant equation?
I suppose the second is for the case RL is not connected.
eq 1) OK, eq 2) OK, eq 3) OK. Now substitute Re from eq 2) in eq 3): one equation (namely 4R2=4.33 R2*RL/(R2+RL) ) with one unknown. Because you know the RL that causes this worst case, namely ...
Gives you R2 !
For part 2 of your exercise: which of the two would get to this limit first ? What current ? What voltage drop ?
Likes 1 person
Gives you R2 !
Okay, I calculated R2=1200Ω and R1=300Ω by subbing in the equations.
For part 2:
eq1) vr1^2//1200=1 W, vR1=34.6 V
eq2) 40V-34.6V=5.4V for R2+RL
eq3) 40*Re/(1200+Re)=5.4V. Re=188.4Ω
eq4) 300*RL/(300+RL)=188.4Ω, therefore RL=487Ω
Not sure if this is right. Is there an easier way of calculating the RL, or do I have to calculate Re first like I did here?
1200Ω is spot on.
So is your part 2 calculation. I don't see any real shortcuts there: all paths are more or less the same. Want to see the one I was thinking of? Here goes:
eq1), eq 2: same as you
Vr1/R1 = 28.87 mA Vr2/R2 = 17.86 mA → VrL/RL = 11.00 mA → RL = 5.36 V/11.00 mA
It's not very generalized, sophisticated, high-brow, etc. But good enough here...
Comes down to using Ohm's law for the various current paths. And Kirchoff's law (which I never really absorbed -- I thought of it as 'the current has to go somewhere' :smile:).
Re=4.33Re*3600/(3600+4R2)
Re=4.33Re*3600/(3600+4*(4.33Re))
Re=4.33Re*3600/(3600+17.32Re)
0=4.33Re*3600-7.5*(3600+17.32Re)
0=15600*Re-2700*Re+7.5*17.32Re
0=15600*Re-2700*Re+129.9Re
0=129.9*Re-2700*Re
0=129.9*Re-2700*Re
-2570.1*Re=0
Re=0
It seems like you are on the right track with your equations, but you may have made a mistake in equation 4. Instead of setting Re equal to 0, try solving for R2 to find the smallest resistor that can be used as rL before one of the resistors in the divider is operating at its dissipation limit. This will give you a numerical value for R2 that you can then use in your calculations. Additionally, make sure to take into account the 1 W limit for the resistors when solving for R2.
Related to No load voltage / resistance question
1. What is no load voltage?
No load voltage refers to the voltage measured across a load when no current is flowing through it. This typically occurs when the load is disconnected or when there is an open circuit.
2. How is no load voltage different from open circuit voltage?
No load voltage and open circuit voltage are often used interchangeably, but technically, open circuit voltage refers to the voltage across a load when it is disconnected from a power source, while no load voltage refers to the voltage across a load when it is connected to a power source but no current is flowing through it.
3. How is no load voltage measured?
No load voltage is typically measured using a voltmeter. The voltmeter is connected across the load and the voltage reading is recorded.
4. What factors affect no load voltage?
No load voltage can be affected by the power source's internal resistance, the load's impedance, and any other components in the circuit. Changes in these factors can result in a change in the no load voltage.
5. What is the significance of no load voltage?
No load voltage is important in understanding the behavior and characteristics of a power source. It can also be used to determine the internal resistance of the power source, which is useful in circuit analysis and design.
