No mass for mass per unit length
In summary, the question asks for the tension in a steel cable of length L and radius R, which is connected to a ski gondola. A wave pulse travels along the cable and takes T seconds to return. By using the equation v=sqrt(T/mu), where μ is the mass per unit length of the cable, the velocity and volume of the cable can be calculated. However, to find the tension, the mass of the cable must also be known. This can be determined by using the given dimensions of the cable and knowing its material (steel). By setting up equations and seeing if some dimensions cancel out, an expression for the tension in the cable can be obtained.
nanocreation76
A ski gondola is connected to the top of a hill by a steel cable of length L and radius R . As the gondola comes to the end of its run, it bumps into the terminal and sends a wave pulse along the cable. It is observed that it took T seconds for the pulse to return.
What is the tension in the cable?
v=sqrt(T/mu)
With the given information I can calculate velocity and volume of the cable. I can't figure out how to turn that into tension. There's no given mass for calculating mass per unit length, and I can't figure or find any other way of calculating tension.
v=sqrt(T/mu)
Since you know the material of the cable (steel) you should be able to calculate how much mass a cable with the given dimensions would have. Knowing the length will give you an expression for μ for the cable. You know how long the cable is and how long it takes for the pulse to travel along the length.
You have to make an attempt at seeing if some of these dimensions cancel, and you can come up with an expression for the tension in the cable. It may not be a number which you obtain, but another formula. You won't know for sure until you start writing equations down.
Related to No mass for mass per unit length
1. What is "No mass for mass per unit length"?
"No mass for mass per unit length" is a concept in physics that refers to the absence of mass in a given length of space. It is a fundamental principle that states that the mass in a specific region of space is directly proportional to the energy in that region.
2. How does "No mass for mass per unit length" relate to the theory of relativity?
"No mass for mass per unit length" is a key component of Einstein's theory of relativity. The theory states that energy and mass are interchangeable, and the amount of energy present in a given space determines its mass. This principle is crucial in understanding the relationship between space, time, and gravity.
3. Can "No mass for mass per unit length" be observed in real life?
Yes, "No mass for mass per unit length" has been observed and confirmed through various experiments and observations in the fields of physics and astronomy. For example, the bending of light around massive objects, such as stars, is evidence of the presence of mass in space.
4. How does "No mass for mass per unit length" impact our understanding of the universe?
"No mass for mass per unit length" is a fundamental concept in modern physics and has greatly influenced our understanding of the universe. It has led to the development of theories like the Big Bang Theory, which explain the origin and evolution of the universe. It also helps us understand the behavior of objects in space, such as the movement of planets and galaxies.
5. Are there any practical applications of "No mass for mass per unit length"?
Yes, "No mass for mass per unit length" has many practical applications, particularly in the fields of space exploration and technology. It is used in the design and operation of satellites, spacecraft, and other space-related technologies. It also plays a crucial role in understanding and predicting the behavior of celestial bodies, such as comets and asteroids.
11K
