No Max for Functions: Examples & Explanations
In summary: Wondering)In summary, the conversation discussed finding a space $D \subset \mathbb{R}^2$ such that a function $f(x_1,x_2)=x_1+x_2$ does not have a maximum in $D$. Examples were given for $n \geq 2$, such as the open unit ball around the origin. There was some confusion about the notation $D=((x_1, x_2))$ and how to determine if a mini-ball around each point in the ball is completely inside the ball.
evinda
MHB
3,836
Hello! (Wave)
If $f: \mathbb{R}^n \to \mathbb{R} (n \in \mathbb{N})$ and $D \subset \mathbb{R}^n$ then it doesn't generally hold that there exists a $\max_{x \in D} f(x)$, i.e. that there is a $\overline{x} \in D$ such that $f(\overline{x}) \geq f(x)$ for each $x \in D$.
For example if $n=1$ and $f(x)=x$, $D=(0,1)$ then $f$ doesn't have a maximum in $(0,1)$. Give examples for $n \geq 2$.
Hint: $f(x_1,x_2)=x_1+x_2$ and find a space $D \subset \mathbb{R}^2$ so that $f$ has't maximum in $D$.How can we find a $D$ such that $f(x_1,x_2)=x_1+x_2$ doesn't have a maximum in $D$ ?Would it be right as follows? $$$$
We consider $D=((1,1), (2,2))$.
If the maximum is in $((1,1),(2,2))$, it holds that $\max_{x \in D} f(x)\subset (2,2)$, say it is $(2- \epsilon_1, 2-\epsilon_2)$. From the density of rationals, we have that there are $q_1, q_2 \in \mathbb{Q}$ such that $2- \epsilon_1< q_1< 2$ and $2- \epsilon_2< q_2< 2 $.
But then $(q_1, q_2 ) \in ((1,1), (2,2))$ and $ (2- \epsilon_1, 2-\epsilon_2) \subset (q_1, q_2)$. Thus $(2- \epsilon_1, 2-\epsilon_2)$ cannot be the maximum.
In general, can we find an open and bounded interval $D$ such that a function $f$ has a maximum in it?
evinda said:
Hello! (Wave)
Hi evinda! (Mmm)
Suppose we pick $D$ to be an open ball.
How would that work out? (Wondering)
Wouldn't the maximum be some value in $\mathbb R$ instead of a point (or a subset)? (Wondering)
For the $D$ you suggest, we would only have 2 values for $f$.
Let's call them $f_1 = f(1,1)$ and $f_2 = f(2,2)$.
Whichever of them matches the maximum, the corresponding $\overline x$ will be in $D$. (Worried)
What open ball could we pick for example? (Thinking)
So could we compute $f_1 = f(1,1)$ and $f_2 = f(2,2)$ although the intervals of the space $D=((1,1), (2,2))$ are open?
Say the open unit ball around the origin:
$$D=\{(x,y) : x^2+y^2 < 1 \}$$
Perhaps I misunderstood.
What did you mean by $D=((1,1), (2,2))$? (Wondering)
If it represents the straight line between the points $(1,1)$ and $(2,2)$ without its endpoints, that would also do just fine. (Nod)
Then the range of the given $f$ would be the interval $(2,4)$, so its maximum would be $4$, except that is not included in the range.
How do we know that it is an open ball? (Thinking)
I don't know.. I am a little confused right now. Should we find a space $D \subset \mathbb{R}^2$ of the form $D=((x_1, x_2))$ ? (Sweating)
It's the definition of an open ball. Quoting you in your other thread:
evinda said:
$B_d(x, \epsilon) := \{ y \in \mathbb{R}^n: d(x,y)< \epsilon\}$ -> open ball with center $x$ and radius $\epsilon$.
To see that the ball is indeed open, we can check if we can find a mini-ball around each point in the ball that is completely inside the ball... (Thinking)
Let's start with your notation $D=((x_1, x_2))$... what does it mean? (Wondering)
I like Serena said:
It's the definition of an open ball. Quoting you in your other thread:To see that it the ball is indeed open, we can check if we can find a mini-ball around each point in the ball that is completely inside the ball... (Thinking)
How can we determine if we can find a mini-ball around each point in the ball that is completely inside the ball?
Which points $(x,y)$ do we check to see if they satisfy the relation $x^2+y^2<1$ , picking $D=\{ (x,y): x^2+y^2<1\} $? (Thinking)
That the values that the function $f$ can take belong to the interval $(x_1,x_2)$ ? Or am I wrong? (Thinking)
Let's pick a point $(x_1,y_1)$ that is an element of the ball $D$.
That is, it satisfies $x_1^2+y_1^2<1$.
Now the question is, can we find an $\epsilon > 0$ so small that the disk around the point $(x_1,y_1)$ with radius $\epsilon$ fits completely inside $D$?
Which $\epsilon$ could be pick to achieve that? (Wondering)
I don't think so. (Worried)
We're running into the ambiguity what $(x_1,x_2)$ means. Is it a point in $\mathbb R^2$ or is it an open interval from $x_1$ to $x_2$?
When this happens, we often need to deduce from the context what was intended.
In this case $D$ is a subset of $\mathbb R^2$, so I'd interpret $(x_1,x_2)$ as a point unless it is specifically mentioned that it is an interval. Moreover, from your opening post we can also deduce that $(x_1,x_2)$ must be a point.
Ideally, we always state explicitly what is intended. (Nerd)
Either way, the extra set of parentheses in $D = ((x_1,x_2))$ has no known meaning to me.
I can only guess what it might mean. (Doh)
So do we have to check if there is an $\epsilon>0$ such that $(x_1- \epsilon)^2+(y_1-\epsilon)^2<1$?
So if we pick $D=\{ (x,y): x^2+y^2<1 \}$ in order to show that $f(x_1,x_2)=x_1+x_2$ doesn't have a maximum in $D$ how can we proceed?
Can we assume that $f$ has a maximum in $D$ at the point $(\overline{x_1}, \overline{x_2})$?
If so, then $\overline{x_1}+\overline{x_2}$ is the greatest value for which $\overline{x_1}+\overline{x_2}<1$.
How could we continue?
Yup. (Thinking)
The maximum on the closure of $D$ is at $P = (\frac 12 \sqrt 2, \frac 12 \sqrt 2)$ and has the value $\sqrt 2$.
However, that point is on the boundary and does not belong to $D$ itself.
Any point in $D$ will always have a value that is slightly less, and whichever point we pick, we can always pick a point closer to $P$, which has a higher value.
In other words, $D$ does not have a maximum.
It does have a supremum, which is $\sqrt 2$.
I like Serena said:
Yup. (Thinking)
Could we pick for example $\epsilon=x_1$ ? (Thinking)
How do we deduce this?
Could you explain it further to me?
Not generally.
Suppose $(x_1,y_1) = (0.9, 0)$, then if we pick $\epsilon=0.9$ the resulting disk won't fit inside $D$. (Worried)
How would you find the maximum of a regular function, say $f: x \mapsto x^2$, on the interval $[-1,2]$? (Wondering)
I like Serena said:
Not generally.
So can't we find an $\epsilon$ for the general case? (Thinking)
We find that $f$ is decreasing for $x<0$ and increasing for $x>0$, so it achieves its maximum for $x=2$.
What is the distance of $(x_1, y_1)$ to the edge of $D$? (Wondering)
Perhaps we can use that as $\epsilon$.
Yep!
And what is the maximum if the interval is $(-1,2)$? (Wondering)
With edge of $D$ do you mean the circle with center $(0,0)$ and radius $1$?
I like Serena said:
Yep!
There is no maximum, only a supremum at the point $x=2$.
So does it hold that any function does not have a maximum on an open and bounded interval, but just a supremum? (Thinking)
Yes. (Sweating)
How about $f: x \mapsto 2-x^2$. Does it have a maximum on $(-1,2)$? (Wondering)
I like Serena said:
Yes. (Sweating)
How can we find the distance? (Sweating)
No, $f$ has just a supremum at the point $x=-1$.
The distance of $(x_1,y_1)$ to the origin is $\sqrt{x_1^2+y_1^2}$.
The distance of the origin to any point on the boundary of $D$ is $1$. (It's a unit disk.)
Therefore the distance of $(x_1,y_1)$ to the boundary is $1-\sqrt{x_1^2+y_1^2}$.
If we pick that as $\epsilon$ we're good to go.
Let's see... (Thinking)
$f(-1)=2-(-1)^2=1$, but $f(0)=2-0^2=2$. Isn't that bigger? (Wondering)
I haven't really understood why the distance of $(x_1,y_1)$ to the boundary is $1-\sqrt{x_1^2+y_1^2}$. (Sweating)
Yes, so $f$ achieves its maximum at the point $x=0$.
Let's consider the real line and suppose we have some $0\le x<1$.
The distance from $0$ to $x$ is $|x|$, while the distance from $x$ to $1$ is $1-|x|$. Yes? (Thinking)
The same holds in any number of dimensions: the distance from $\mathbf 0$ to $\mathbf x$ is $||\mathbf x||$, while the distance from $\mathbf x$ to the boundary of the unit ball is $1-||\mathbf x||$. (Thinking)
Aha! So not all functions have their maximum or supremum on the boundary! (Smirk)
A ok. And in our case do we take the euclidean norm? (Thinking)
But how do we deduce in our case when we have the function $f(x_1,x_2)=x_1+x_2$ and $D=\{ (x,y): x^2+y^2<1\}$ that the maximum is on the boundary? Because of the fact that the fuction is increasing? (Thinking)
Yes.
It's a linear function.
Linear functions always have their maximum at the boundary. (Nerd)
To find where, we can go 2 ways:
1. Parametrize the boundary, substitute, and find the maximum.
2. Use symmetry considerations to find the maximum.
For approach 1 that means substituting $x=\cos\phi, y=\sin\phi$ in $f(x,y)$, take the derivative with respect to $\phi$, set it to zero, and solve. (Thinking)
For approach 2 that means that we consider that f(x,y) is symmetric in x and y. (Thinking)
I like Serena said:
Yes.
So is it like that?
$$f(x,y)=f(\phi)= \cos \phi + \sin \phi$$
$$f'(\phi)=-\sin \phi+ \cos \phi$$
$$f'(\phi)=0 \Rightarrow \sin \phi= \cos \phi \Rightarrow \phi=\frac{\pi}{4} \text{ or } \phi=-\frac{3 \pi }{4}$$
So, $x=y= \frac{\sqrt{2}}{2}$.
Is it a general methodoly to find the maximum of a linear function?
evinda said:
So is it like that?
Good! (Smile)
It's a general methodology to find the maximum of any function on a boundary.
For a linear function we can make it easier for ourselves if we pick a boundary that consists of line segments, such as the unit square. Then the maximum must be on a corner. (Mmm)
FAQ: No Max for Functions: Examples & Explanations
What is the concept of "No Max for Functions"?
"No Max for Functions" refers to the idea that there is no upper limit or maximum value for a function. This means that the output of a function can continue to increase without ever reaching a limit.
How is "No Max for Functions" different from "No Max for Numbers"?
The concept of "No Max for Functions" is related to the behavior of a function, while "No Max for Numbers" refers to the concept of infinity in mathematics. "No Max for Functions" means that the output of a function has no upper limit, while "No Max for Numbers" means that numbers can continue to increase without limit.
What are some examples of functions with no maximum value?
Some examples of functions with no maximum value include exponential functions, logarithmic functions, and trigonometric functions. These functions can continue to increase or decrease without ever reaching a maximum value.
How can "No Max for Functions" impact real-world applications?
In real-world applications, "No Max for Functions" can be used to model situations where there is no limit to growth or change. For example, it can be used to predict population growth, stock market trends, or the spread of infectious diseases.
Are there any limitations to the concept of "No Max for Functions"?
While the concept of "No Max for Functions" is a useful mathematical concept, it may not always accurately reflect real-world situations. In some cases, there may be practical limitations or constraints that prevent a function from increasing without limit.
