No Non-Constant Entire Function $f(z)$ with $Re(f(z))<0$
  • MHB
  • Thread starter Amer
  • Tags
    Function
In summary: So f is constant.In summary, the conversation discusses the non-existence of a non-constant entire function with a real part less than 0. The proposed solution involves using a circle in the right half plane and Liouville's theorem to show that such a function must be constant. However, the proof is deemed sloppy and a more precise theorem is presented, along with a cleaner proof. This theorem states that the image of an entire function is a dense set, and if the real part of the function is less than 0, then the function must be constant.
Amer
259
Show that there is no non constant entire function f(z) such that $Re(f(z)) < 0 $
My solution, suppose there exist a non constant function with $Re(f(z)) < 0 $
Take the circle $|w - w_0| = r $ we choose $w_0, r$ such that the circle is in the right half plane like this
$f(z) $ is entire, and $|f(z) - w_0| > r $ for all z
Let
$g(z) = \dfrac{1}{f(z) - w_0} $, g is entire function since the denominator dose not vanish ( =/= zero ) and g(z) is bounded
$ |g(z) | = \dfrac{1}{ |f(z) - w_0|} < \dfrac{1}{r}$
By Liouville's theorem, any bounded entire function must be constant so g(z) is constant, f(z) is constant Contradiction.
But my Pro said my solution is not Ok, where is the mistake ?
Thanks
For one thing your proof is a sloppy. What is $w_0$? You never define it. What is $r$? How are you defining them?
Here is a more precise way to say what you want to say. We will greatly generalize your theorem.
Definition: A subset $D$ of $\mathbb{C}$ is called dense if and only if the closure of $D$ is $\mathbb{C}$. In other words, every point of $p\in \mathbb{C}$ has the property that the disk $\Delta(p,r) $ intersects $D$ for every $r>0$.
In fancy language,
$$ \forall p\in \mathbb{C},~ \forall r > 0,~ \Delta(p,r) \cap D \not = \emptyset$$
Negating this statement tells us that if $D$ is not dense then,
$$ \exists p\in \mathbb{C}, \exists r > 0, ~ \Delta(p,r)\cap D = \emptyset $$
Theorem: If $f:\mathbb{C}\to \mathbb{C}$ is an entire function which is non-constant then the image of $f$ is dense set of $\mathbb{C}$.
Corollary: Given the same as above in theorem, if $\text{Re}(f) < 0$ then $f$ must be constant. (Your problem).
Now we prove the theorem.
Proof: Suppose it aint true that the image $I$ is dense. Then there is a $p\in \mathbb{C}$ and $r>0$ such that the disk $\Delta(p,r) \cap I = \emptyset$. This means for any $w\in I$ we have that $w\not \in \Delta(p,r) \implies |p-w|\geq r$. Since $I$ is the image set it follows that $|p-f(z)|\geq r$ for all $z\in \mathbb{C}$. Now define the function,
$$ g(z) = \frac{1}{f(z) - p} $$
This function $g$ is entire and as you said,
$$ |g(z)| = \frac{1}{|f(z)-p|} \leq \frac{1}{r} $$
Thus, $g$ is a bounded as you said forces $f(z)$ to be constant by Liouville which is a contradiction.
Thanks, I picked them in the picture!.
I picked $w_o $ and $r$ such the points $w$ that satisfies $|w - w_o| = r $ are in the right half plane.
for exmaple $w_o = (2,2) $ and $r = 1$
Thanks again.
In fact I build my work after I read that the Image of the Entire function is dense.
Your proof is very clean and clear.:D
Consider the following function
\(\displaystyle g(z)=e^{f(z)}=e^{Re(f(z))}e^{iIm(f(z))}\)
Then this function is entire and
\(\displaystyle |g(z)|\leq e^{Re(z)} \leq 1\)
By Liouville theorem $g$ is constant hence $g'=0$
\(\displaystyle g'=f'(z) e^{f(z)}= 0\) hence we have $f'(z)=0$
for your question. Your solution is on the right track, but there are a few mistakes that need to be corrected.
First, when you say "take the circle $|w-w_0|=r$," you should specify that this is a circle in the complex plane, not in the right half plane. The complex plane is the entire domain of f(z), so we want to choose a circle that encompasses the entire domain.
Second, in your definition of g(z), you have written $g(z) = \dfrac{1}{f(z) - w_0}$, but it should be $g(z) = \dfrac{1}{f(z)} - w_0$. This is because we want to show that $g(z)$ is bounded, not $f(z)-w_0$.
Third, in your statement of Liouville's theorem, you wrote "any bounded entire function must be constant." This is not quite correct. The correct statement is "any entire function that is bounded on the entire complex plane must be constant." This is an important distinction, because there are bounded entire functions that are not constant on the entire complex plane. For example, $f(z) = \sin(z)$ is bounded on the entire complex plane, but it is not constant.
Finally, when you say "g(z) is constant, f(z) is constant Contradiction," this is not a complete sentence and it is not clear what you are trying to say here. I believe you are trying to say that since g(z) is constant, f(z) must be constant, and this is a contradiction because we assumed that f(z) is not constant. This is correct, but it would be clearer if you wrote it out in a full sentence.
Overall, your solution is on the right track, but it needs to be clarified and corrected in a few places. I hope this helps!
FAQ: No Non-Constant Entire Function $f(z)$ with $Re(f(z))<0$
What is an entire function?
An entire function is a complex-valued function that is analytic at every point in the complex plane. This means that it can be represented by a power series that converges for all complex numbers.
Why can't an entire function have a non-constant real part?
If an entire function has a non-constant real part, then it must have a non-constant imaginary part as well. This means that the function cannot be analytic at every point in the complex plane, which contradicts the definition of an entire function.
Why does the real part of an entire function have to be greater than or equal to 0?
This is a consequence of the Cauchy-Riemann equations, which state that the real and imaginary parts of a complex function must satisfy certain partial differential equations. For an entire function, these equations must hold at every point in the complex plane, which means that the real part cannot be less than 0.
Can an entire function have a non-constant real part if the imaginary part is zero?
No, this is not possible. If the imaginary part of an entire function is zero, then the real part must be constant. This is because the Cauchy-Riemann equations require the partial derivatives of the real and imaginary parts to be equal, and if the imaginary part is zero, then these derivatives must also be zero, meaning the real part is constant.
Is there any exception to the statement "No Non-Constant Entire Function $f(z)$ with $Re(f(z))<0$"?
No, there are no exceptions. This statement is a fundamental result in complex analysis and is true for all entire functions. It is a consequence of the Cauchy-Riemann equations and the fact that entire functions are infinitely differentiable, which rules out any non-constant functions with a negative real part.
