No. of real roots of Quadratic equation
In summary: Similarly, it will decrease from $+\infty$ to $-\infty$ in the interval $(\pi,\pi+e)$, and therefore it must have exactly one zero in that interval. So overall, we can say that the function $f(x)$ has exactly two zeros in the interval $(e,\pi+e).$ To see this, we can consider the behavior of the function as $x$ approaches $e$ from the left, and also as $x$ approaches $\pi+e$ from the right. As $x$ approaches $e$ from the left, the function $f(x)$ decreases from $+\infty$ to $0$. Then at the point $x=e$ it has
juantheron
247
The no. of Real Roots of the equation $\displaystyle \frac{\pi^e}{x-e}+\frac{e^\pi}{x-\pi}+\frac{\pi^{\pi}+e^{e}}{x-\pi-e} = 0$
My try:: Let $\displaystyle f(x) = \frac{\pi^e}{x-e}+\frac{e^\pi}{x-\pi}+\frac{\pi^{\pi}+e^{e}}{x-\pi-e}$
Now we will take a interval $x\in \left(e\;,\pi\right)$ and $x\in \left(\pi\;,\pi+e\right)$
$\bullet$ If $x\in (e,\pi),$ Then $(x-e) > 0$ and $(x-\pi) < 0$
So $f(x) = $
Similarly
$\bullet$ If $x\in (\pi,\pi+e),$ Then $(x-\pi) > 0$ and $(x-\pi-e) < 0$
So $f(x) = $
y Question is How Can I check Sign of $f(x)$ in Given Interval and Is Iam Thinking Right.
If Not please explain me,
Thanks
Mathematics news on Phys.org
Re: no. of real roots of Quadratic equation
Have you considered looking at the discriminant?
So $f(x) = $
Similarly
So $f(x) = $
Thanks
It looks to me as though you are thinking along the right lines here. Each of the three functions $\dfrac{\pi^e}{x-e}$, $\dfrac{e^\pi}{x-\pi}$, $\dfrac{\pi^{\pi}+e^{e}}{x-\pi-e}$ is a decreasing function, except at the points where it has a discontinuity. For example, the first of those functions, $\dfrac{\pi^e}{x-e}$, decreases from $0$ to $-\infty$ in the interval $(-\infty, e)$, and then decreases from $+\infty$ to $0$ in the interval $(e,\infty).$
When you add the three functions together, their sum $f(x)$ will also be a decreasing function everywhere except at its points of discontinuity. So for example it will decrease from $+\infty$ to $-\infty$ in the interval $(e,\pi)$, and therefore it must have exactly one zero in that interval.
FAQ: No. of real roots of Quadratic equation
How do you determine the number of real roots of a quadratic equation?
The number of real roots of a quadratic equation can be determined by looking at the discriminant, which is represented by the expression b2 - 4ac. If the discriminant is greater than zero, the equation will have two real roots. If the discriminant is equal to zero, the equation will have one real root. And if the discriminant is less than zero, the equation will have no real roots.
Can a quadratic equation have more than two real roots?
No, a quadratic equation can only have a maximum of two real roots. This is because a quadratic equation is a polynomial of degree two, which means it can have a maximum of two solutions.
What if the discriminant is equal to zero?
If the discriminant is equal to zero, it means that the quadratic equation has one real root. This is also known as the "double root" or "repeated root" because the two solutions are the same value.
Is it possible for a quadratic equation to have no real roots?
Yes, it is possible for a quadratic equation to have no real roots if the discriminant is less than zero. In this case, the solutions will be complex numbers, which cannot be represented on a real number line.
Can a quadratic equation have imaginary roots?
Yes, a quadratic equation can have imaginary roots if the discriminant is less than zero. In this case, the solutions will be complex numbers, which involve the use of the imaginary unit i (where i2 = -1).
