No. of real solutions in exponential equation
  • MHB
  • Thread starter juantheron
  • Tags
    Exponential
In summary, the equation $3^x+4^x+5^x=x^2$ has a unique real solution. This can be proven by analyzing the behavior of the left and right sides of the equation, using the Intermediate Value Theorem and Rolle's Theorem. The left side grows much faster than the right side, leading to the conclusion that they intersect only once.
juantheron
247
no. of real solution of the equation $3^x+4^x+5^x = x^2$
Mathematics news on Phys.org
Re: no. of real solution in exponential equation.
The RHS grows superexponentially whether the LHS is quadratic. So, for obvious reasons, they intersects each other at most finitely often. A more close inspection of the behaviour would lead to the fact that they do indeed intersect ones.
PS I have no formal proof of this piece of problem, unfortunately.
Balarka
That argument looks correct to me. As $x$ goes from $-\infty $ to $0$, the LHS increases from $0$ to $12$, and the RHS decreases from $\infty$ to $0$. So the graphs must cross exactly once. For $x>0$ the LHS increases (very fast!) from $12$ to $\infty$ and the RHS increases much more slowly. If you differentiate both functions I am sure you will find that the LHS increases faster than the RHS for all positive $x$.
Re: No. of real solution in exponential equation
Hint:
[sp]Considering the function $y=3^x+4^x+5^x-x^2$, use the Intermediate Value Theorem to show that there is at least one solution, then use Rolle's Theorem to show that it is unique.[/sp]
Opalg said:
I am sure you will find that the LHS increases faster than the RHS for all positive x
That is evident, as I mentioned before, since LHS grows superexponentially, i.e., \(\displaystyle << 5^x\) whereas the RHS is quadratic. I think this is sufficient to prove the fact.
PS I see eddybob just posted a rigourus argument of the fact here :D
FAQ: No. of real solutions in exponential equation
How do I find the number of real solutions in an exponential equation?
The number of real solutions in an exponential equation can be found by setting the equation equal to zero and then solving for the variable. The number of distinct solutions found will be the number of real solutions in the equation.
Can an exponential equation have more than one real solution?
Yes, an exponential equation can have more than one real solution. This means that there can be multiple values of the variable that satisfy the equation when it is set equal to zero.
What if the exponent in the exponential equation is a fraction or a negative number?
The number of real solutions in an exponential equation is not affected by the exponent being a fraction or a negative number. The same process of setting the equation equal to zero and solving for the variable can be used to find the solutions.
Are complex solutions considered when finding the number of real solutions in an exponential equation?
No, when finding the number of real solutions in an exponential equation, only real solutions are considered. Complex solutions, which involve the imaginary unit i, are not included in the count.
Is there a maximum number of real solutions in an exponential equation?
No, there is no maximum number of real solutions in an exponential equation. The number of real solutions can vary depending on the specific equation and the values of the variables.
