No. of real solutions in polynomial equation
  • MHB
  • Thread starter juantheron
  • Tags
    Polynomial
In summary, to determine the number of real solutions in a polynomial equation, you can use the fundamental theorem of algebra which states that a polynomial equation of degree n has n complex solutions, including both real and imaginary solutions. The degree of the polynomial equation can be used to find the number of real solutions - a quadratic equation (degree 2) can have 0, 1, or 2 real solutions, while a cubic equation (degree 3) can have 0, 1, 2, or 3 real solutions. A polynomial equation cannot have an infinite number of real solutions because it is a function with a finite number of terms and each term can only have a finite number of roots. The discriminant of a quadratic
juantheron
247
The no. of real solution of the equation $\displaystyle 1+\frac{x}{1!}+\frac{x^2}{2!}+\frac{x^3}{3!}+\frac{x^4}{4!} = 0$
Mathematics news on Phys.org
Re: no. of real solution in polynomial equation
Analysis of the discriminant shows that the discriminant is 1/576 which is obviously > 0. So, either there are two pairs of complex conjugate roots or none at all.
So, check if the additional discriminant (\(\displaystyle 8ac - 3b^2\)) is greater or smaller than 0. In this case, it is -1/3 < 0, and hence all the roots are distinct and real.
[sp]$ 1+\frac{x}{1!}+\frac{x^2}{2!}+\frac{x^3}{3!}+\frac{x^4}{4!} = \frac1{4!}(x^4 + 4x^3 + 12x^2 + 24x + 24) = \frac1{4!}\bigl((x^2+2x+2)^2 + 4(x+2)^2 + 4\bigr) >0$ for all real $x$, so the equation has no real solutions.[/sp]
FAQ: No. of real solutions in polynomial equation
How do I determine the number of real solutions in a polynomial equation?
To determine the number of real solutions in a polynomial equation, you can use the fundamental theorem of algebra. This theorem states that a polynomial equation of degree n has n complex solutions, which includes both real and imaginary solutions. Therefore, to find the number of real solutions, you can use the degree of the polynomial equation. For example, a quadratic equation (degree 2) can have 0, 1, or 2 real solutions, while a cubic equation (degree 3) can have 0, 1, 2, or 3 real solutions.
Can a polynomial equation have an infinite number of real solutions?
No, a polynomial equation can only have a finite number of real solutions. This is because a polynomial equation is a function with a finite number of terms, and each term can only have a finite number of roots. Therefore, the total number of real solutions is always finite.
How can I use the discriminant to determine the number of real solutions in a quadratic equation?
The discriminant of a quadratic equation, denoted as Δ, is the part of the quadratic formula under the square root sign: b2 - 4ac. The value of the discriminant can help determine the number of real solutions in a quadratic equation. If Δ > 0, the equation has 2 distinct real solutions. If Δ = 0, the equation has 1 real solution. And if Δ < 0, the equation has 0 real solutions.
Can a polynomial equation have both real and imaginary solutions?
Yes, a polynomial equation can have both real and imaginary solutions. This is because the fundamental theorem of algebra states that a polynomial equation of degree n has n complex solutions, which includes both real and imaginary solutions. For example, a cubic equation can have 3 complex solutions, which could be a combination of real and imaginary numbers.
Is the number of real solutions in a polynomial equation always equal to its degree?
No, the number of real solutions in a polynomial equation is not always equal to its degree. This is because the fundamental theorem of algebra states that a polynomial equation of degree n has n complex solutions, which includes both real and imaginary solutions. Therefore, the number of real solutions can be less than or equal to the degree of the polynomial equation.
