No Picture on the CRT Television
In summary, CRT televisions may experience a loss of picture due to issues with the power supply, connection, or internal components. These issues can sometimes be resolved by unplugging the TV, checking connections, or seeking professional repair. Faulty cables can also cause picture issues. It is possible to have sound but no picture on a CRT television, and the lifespan of these TVs can vary but can last up to 10 years on average.
McHeathen
32
All of a sudden the picture on my Panasonic CRT television disappeared, but the sound remained. The most common cause of the picture disappearing is a faulty tube and the warning sign of this can be seen for some while.
So it can't be the tube. There was a funny burning type smell from the back of the set. Something must have been overheating. Any explanations, please?
Probalby dust on the high voltage parts causing a short circuit. Luckily it didn't start a fire.
Related to No Picture on the CRT Television
1. Why is there no picture on my CRT television?
There could be several reasons for this issue. It could be a problem with the TV's power supply, the connection between the TV and the cable/satellite box, or an issue with the TV's internal components.
2. How can I fix the picture on my CRT television?
If the issue is with the power supply, try unplugging the TV for a few minutes and then plugging it back in. If the issue is with the connection, make sure all cables are securely connected. If these solutions do not work, it may be necessary to have a professional repair the TV.
3. Can the lack of picture on my CRT television be caused by a faulty cable?
Yes, a faulty cable can cause a loss of picture on your CRT television. Check all cables and connections to ensure they are not damaged or loose.
4. Is it possible to have sound but no picture on a CRT television?
Yes, it is possible to have sound but no picture on a CRT television. This could be due to an issue with the TV's video components or the source of the TV's signal.
5. How long should a CRT television last before experiencing picture issues?
The lifespan of a CRT television can vary, but on average it can last up to 10 years before experiencing picture issues. However, factors such as usage and maintenance can also affect the lifespan of a CRT television.
  • Electrical Engineering
16K
  • General Discussion
