No resultant force means no external force?
In summary: The conveyor belt exerts a horizontal force on the sand, if that's what you mean by "friction force".hmm. okay!
makeAwish
128
Hmm. I'm quite confused with this:
Does no resultant force means no external force?
i.e. if there is an external force, there is a resultant force?
Like say, sand falls onto a moving conveyor belt at the rate of 5.00 kg/s. The conveyor belt is supported by frictionless rollers and moves at a constant speed of 0.750m/s under the action of a constant horizontal external force Fext supplied by the motor that drives the belt.
so the friction force is the force required for the sand to move at same speed as the belt right? then can i say there is no resultant force acting on the sand?
anyway i duno if this is considered as h/w qns.. sorry.
Not at all. Consider a book sitting on your desk. The net force is zero, yet both gravity and the desk exert forces (external forces) on the book.
Note that the sand must be accelerated from zero speed to the speed of the belt. That requires a force.
yah, so that force is the friction force?
hmm. okay!
then since they are moving at same speed can i say there is no resultant force on the system?
What system?
the system of sand and belt?
It's unclear what you mean by "sand and belt" as your system. All the sand?
Focus on a section of the belt alone. Since its speed remains fixed, the net force on it must be zero.
The falling sand is being accelerated by the belt, so there must be a net force on that sand during its acceleration.
Oh. okay sorry, i was actually referring to the sand on belt and the belt itself. for this, is no net force?
Strictly speaking, the belt DOES slow down a bit as the sand particles fall on it. As the belt exerts a force to speed up the sand, the sand exerts an equal and opposite force on the belt slowing it down.
Since the belt maintains a constant speed, the net force on it is zero. Since the sand exerts a force on the belt, the mechanism must exert an equal and opposite force on the belt to maintain its constant speed.
Ya. But i think, the belt should slow down for a very small interval of time before getting 'reinforcements' from the motor to maintain the speed.
First lesson:
NEVER, EVER, break the PREMISE given in the exercise!
You are GIVEN that the velocity is constant, so that is what you are to assume for the remainder of the exercise.
Besides, STRICTLY speaking, you'd have to take into account relativistic and quantum mechanical effects, at least after you have included the gravitational effects from the planets impinging upon the scenario.
How do you know that these would be insignificant compared to the error source you happened to mention?
Related to No resultant force means no external force?
1. What is meant by "no resultant force"?
Resultant force refers to the overall force that is the result of combining all the individual forces acting on an object. It takes into account the magnitude and direction of each force to determine the net effect on the object.
2. Why does "no resultant force" mean no external force?
When all the individual forces acting on an object are balanced and cancel each other out, there is no resultant force. This means that the object is not experiencing any unbalanced external forces, as they are all counteracting each other.
3. Is it possible to have no resultant force but still have external forces acting on an object?
Yes, it is possible for an object to have multiple external forces acting on it, but for them to be balanced in a way that results in no resultant force. For example, if an object is being pushed with equal force from opposite directions, the forces will cancel each other out and there will be no resultant force.
4. What happens to an object when there is no resultant force?
When there is no resultant force on an object, it will either be at rest or moving at a constant velocity in a straight line. This is because there is no net force to accelerate it in any particular direction.
5. How does Newton's first law of motion relate to "no resultant force means no external force"?
Newton's first law states that an object at rest will remain at rest, and an object in motion will remain in motion at a constant velocity, unless acted upon by an unbalanced external force. This means that if there is no resultant force on an object, it will either remain at rest or continue to move at a constant velocity without the need for an external force.
