No solution with E=v0 for step potential
In summary: Yes, this is a general solution to the Schrodinger equation. With appropriate boundary conditions, it will be a solution that is bounded and has a rapid falloff as ##x \to \pm \infty##.
hnicholls
49
Is it the case that there is no general solution for the step potential with E = V0?
This seems as though it must be the case as there are only certain energy eigenvalues which would be allowed and, therefore, we cannot for all possible values for the potential barrier find allowed energy eigenvalues.
This would be appear to be reflected in the inconsistent solutions for the wave function in interval 2 (right of the step potential x > 0).
Wave equation for interval 2: Ψ2 = A2eik2x + B2e-ik2x 0 < x < ∞
Wave number for interval 2
k2 = [2m/ħ2 (E - V2)]1/2 Interval 2 ; x > 0 V2 = E
k2 = [2m/ħ2 (0)]1/2 = 0
The angular frequency in this eigenfunction corresponds to the wave number k2 and is:
ω2 = 0 = 0
Thus, the terms in the eigenfunction correspond to the following:
A2 – incident wave (momentum 0)
B2 – reflected wave (momentum 0)
Producing the following wave equation for interval 2: Ψ2 = A2 + B2
0 < x < ∞
This result is inconsistent with the solution to the TISE for interval 2
(-ħ2/2m)d2/dx2Ψ2(x) + v(x)Ψ(x)2 = EΨ(x)
where v(x)Ψ(x)2 = EΨ(x)
So, d2/dx2Ψ2(x) = 0
In order for d2/dx2Ψ2(x) to equal 0
d/dx Ψ(x)2 = A2 and Ψ(x)2 = A2x + B2
What exactly are you asking? You give the general solution to the Schrodinger equation for this situation:
As you found, the general solution to this differential equation is *not* given by a linear combination of exponentials.
As another example, you could try solving
[tex]\frac{d^2 y}{dx^2} + 2 \frac{dy}{dx} + y = 0[/tex]
Well, for any E you can find a pair of linearly independent solutions to the Schrodinger equation, as you did above. Whether you want to call that E "allowed" then depends on what boundary conditions you want to impose on the wave function. We pretty much always require that the wave function be bounded as ##x \to \pm \infty##. This leads to quantization of energy levels--rules out most E's--if E is less than the potential at infinity. But all E's greater than or equal to the potential at infinity are allowed; these are the "scattering states." For example in your case for ##E=V_0## there is the constant solution, which does not blow up at infinity.
Sometimes we require the solutions to be square-normalizable as part of an especially rigorous approach. This effectively requires a rapid falloff of the wave function as ##x \to \pm \infty##. Then the only true energy eigenstates are bound states.
Thank you for the response.
I am still confused as to the wave function
Ψ2 = A2 + B2
is this also a general solution to the Schrodinger equation for this situation?
Is this equivalent to Ψ2 = A2x + B2
with appropriate boundary conditions?
Related to No solution with E=v0 for step potential
1. What is a step potential?
A step potential is a sudden change in potential energy, often represented by a step-like graph. This can occur in various physical systems, such as in quantum mechanics when a particle encounters a sudden change in potential energy barrier.
2. Why is there no solution with E=v0 for step potential?
For a step potential, the Schrödinger equation (which describes the behavior of quantum particles) has a form of a differential equation. When solving this equation for a potential energy barrier, there are certain conditions that must be met for a solution to exist. If the particle's energy, E, is equal to the barrier's height, v0, there are no solutions that satisfy the conditions of the equation.
3. Can a particle with energy equal to the barrier's height pass through a step potential?
No, a particle with energy equal to the barrier's height cannot pass through a step potential. This is because in quantum mechanics, a particle's energy is directly related to its momentum. If the particle's energy is equal to the barrier's height, its momentum is zero, and it cannot overcome the potential barrier.
4. How does the height of the barrier affect the behavior of a particle in a step potential?
The height of the barrier affects the behavior of a particle in a step potential by determining whether a particle can pass through the barrier or not. If the particle's energy is greater than the barrier's height, it can pass through with a certain probability. However, if the particle's energy is equal to the barrier's height, it cannot pass through and will be reflected back.
5. Are there any real-life applications of step potentials?
Yes, step potentials have several real-life applications. One example is in semiconductor devices, where step potentials are used as barriers to control the flow of electrons. They are also used in particle accelerators to accelerate particles to high energies. Additionally, step potentials are used in various experiments in quantum mechanics to study the behavior of particles in different potential energy barriers.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
