MHB Noetherian Modules - Bland - Proposition 4.2.3 - (3) => (1)
  • Thread starter Thread starter Math Amateur
    Modules
The discussion focuses on understanding why the union of an ascending chain of submodules of a module M is itself a submodule. It is clarified that while the union of arbitrary submodules may not be closed under addition, an ascending chain guarantees closure because any two elements from the union can be found in a common submodule within the chain. This is due to the property that if one submodule contains another, any elements from both will also belong to the larger submodule. The participants emphasize that this closure under addition is essential for the union to qualify as a submodule. Overall, the ascending chain condition is crucial for ensuring the union remains a submodule of M.
Math Amateur
MHB
I am reading Paul E. Bland's book, "Rings and Their Modules".
I am trying to understand Chapter 4, Section 4.2 on Noetherian and Artinian modules and need help with the proof of $$ (3) \Longrightarrow (1) $$ in Proposition 4.2.3.
Proposition 4.2.3 and its proof read as follows:
The first line of the proof of $$ (3) \Longrightarrow (1) $$ reads as follows:
"If $$ M_1 \subseteq M_2 \subseteq M_3 \subseteq \ ... \ $$ is an ascending chain of submodules of M then $$\bigcup_{ i = 1 }^{ \infty } M_i $$ is a finitely generated module of $$M$$. ... ... "
My question is as follows:
How do we know that if
... ... $$ M_1 \subseteq M_2 \subseteq M_3 \subseteq \ ... \ $$ is an ascending chain of submodules of $$M$$
then
... ... $$\bigcup_{ i = 1 }^{ \infty }$$ is a finitely generated module of $$M$$ ...
That is ... why exactly does this follow?
Peter
Hi Peter,
$\cup_{i=0}^{\infty}M_{i}$ is a submodule of $M$.
The point 3) states that every submodule of $M$ is finitely generated.
Fallen Angel said:
Hi Peter,
Thanks Fallen Angel ... ... so the union of submodules is a submodule ... ... including the union of an infinite set of submodules?
Thanks for the help!
Peter***EDIT***
PROBLEM! I now believe that the union of a set of modules is not necessarily a module!
You're right Peter, but the union of an ascending chain of submodules of an $R$-module $M$ is a submodule of $M$.
Thanks Euge ... ...
But ... why/how does the fact that the submodules are in an ascending chain, make a difference?
Peter
Peter said:
Thanks Euge ... ...
Peter
Sorry, but I don't understand the question. You cannot guarantee closure under addition holds for $\cup M_i$ if the sequence $M_i$ is not increasing. For example, the subset $A := 2\Bbb Z \cup 3\Bbb Z$ of $\Bbb Z$ is not closed under addition since $2, 3 \in A$ but $2 + 3 = 5 \notin A$. Therefore, $2\Bbb Z \cup 3\Bbb Z$ is not a submodule of $\Bbb Z$. For an infinite sequence counterexample, let $p_i$ represent the $i$-th prime, and let $B = \bigcup_{i = 2}^\infty p_i\Bbb Z$. Then $3, 5 \in B$, but $5 + 3 = 8 \notin B$ since $8$ is not divisible by any odd prime. So $B$ is not a submodule of $\Bbb Z$.
Thanks Euge ... I think you have answered my question ...
I was asking if you could explain further exactly why the union of an ascending chain of submodules of an R-module M is a submodule of M ... but I think you have done this ... actually, still reflecting on what you have written ...
It seems that you are saying that the union of a set of submodules is often not a submodule because addition is not closed in the union ... ... BUT ... when we are dealing with an ascending chain, then closure under addition is assured ...
Thanks again for your help ... ..
Peter
Yes it is, the key of the question is as follows, given $a,b \in \displaystyle\cup_{i=0}^{\infty}M_{i}$ we got that there exists $n,m$ with $a\in M_{n}$, $b\in M_{m}$, without loss of generality we can assume $n\geq m$.
Then, the chain condition assures you that $a,b\in M_{n}$ since $M_{m}\subseteq M_{n}$ and $M_{n}$ is a module :D
