Noether's currents under dilatations (scaling transformations)
In summary, the homework statement asks for a solution to the equations for Noether's currents in a scaling dimension of one. The attempt at a solution is to calculate the dilatation and the field's scaling dimension using knowledge of the coordinates transformation.
askalot
Hello,
1. Homework Statement
Suppose we have the following Lagrangian density, in ## 3 + 1## dimensions:
$$L = \frac{1}{2}\partial_{\mu}\phi \partial^{\mu}\phi - g \phi^4$$
Under the dilatation (scaling transformation): ##x \rightarrow \lambda x^{\mu}, \phi (x) \rightarrow \lambda^{-1} \phi(\lambda^{-1} x)##, we should calculate the resulting conserved currents.
Noether's currents' definition formula:
$$D^{\mu} = \frac{\partial L}{\partial (\partial_{\mu} \phi)}\delta\phi - F^{\mu}$$
$$\partial_{\mu} F^{\mu} = \delta L$$
The answer would be a simple application of the general Noether's currents' definition formula, if I knew how to calculate: ##\delta\phi## and ##F^{\mu} ##.
Thank you in advance,
askalot.
I guess ##\delta \phi= (\partial \phi/\partial \lambda) d\lambda##.
askalot said:
Hello,
askalot.
If the coordinates transform like
[tex]\bar{x}^{\mu} = e^{-\epsilon} x^{\mu} \approx (1-\epsilon) x^{\mu} ,[/tex]
i.e.,
[tex]\delta x^{\mu} = -\epsilon \ x^{\mu} ,[/tex] the fields transform according to
[tex]\bar{\varphi}(\bar{x}) = e^{\epsilon \Delta} \ \varphi(x) ,[/tex] where [itex]\Delta[/itex] is the scaling dimension of the field ([itex]\Delta = 1[/itex] for scalar field). If you expand both sides to first order in [itex]\epsilon[/itex], you find
[tex]\delta \varphi (x) \equiv \bar{\varphi}(x) - \varphi (x) = \epsilon \left( \Delta + x^{\mu} \partial_{\mu} \right) \varphi (x) .[/tex]
Okay, now you do the substitution into the Noether current of dilatation [tex]D^{\mu} = \frac{\partial \mathcal{L}}{\partial (\partial_{\mu} \varphi)} \delta \varphi + \delta x^{\mu} \mathcal{L} .[/tex]
FAQ: Noether's currents under dilatations (scaling transformations)
What are Noether's currents?
Noether's currents refer to the conserved quantities in a physical system that arise from the symmetry of the system. They were first introduced by mathematician Emmy Noether in her work on the relationship between symmetries and conservation laws in physics.
What are dilatations (scaling transformations)?
Dilatations, or scaling transformations, refer to changes in the size or scale of a physical system. This can include changes in distance, time, or any other physical quantity that can be scaled. In mathematical terms, dilatations involve multiplying all coordinates by a constant factor.
How are Noether's currents related to dilatations?
Noether's theorem states that for every continuous symmetry of a physical system, there exists a corresponding conserved quantity, or Noether current. Dilatations are one type of symmetry, and therefore, there are specific Noether currents associated with them.
Why are Noether's currents under dilatations important?
Noether's currents under dilatations have significant implications in physics because they allow us to understand and predict conserved quantities in various physical systems. They also provide a deeper understanding of the relationship between symmetries and conservation laws.
How are Noether's currents under dilatations used in practical applications?
Noether's currents under dilatations have practical applications in various fields of physics, such as particle physics, fluid dynamics, and field theory. They are used to calculate and predict conserved quantities, which are essential in understanding the behavior and dynamics of physical systems.
