A Noether's theorem for finite Hamiltonian systems
Noether's theorem for finite Hamiltonian systems establishes a connection between symmetries and conserved quantities. To derive a first integral from a known symmetry, one can use the vector field generating the symmetry, denoted as ##\mathbf{w}##, and apply the relation ##\mathbf{w}(f) = \{ f, P \}## for an arbitrary function ##f##. The discussion highlights the process of deriving the Hamiltonian from the metric and emphasizes the necessity of identifying a symmetry to utilize Noether's theorem effectively. Participants express confusion about the steps involved in this derivation and the application of the theorem. Understanding these concepts is crucial for successfully applying Noether's theorem in finite Hamiltonian systems.
thaalves
TL;DR Summary
How do I write a first integral knowing a symmetry?
The Noether's theorem for finite Hamiltonian systems says that:
My question is: If I know a symmetry how can I write the first integral?
If ##\mathbf{w}## is the vector field generating the symmetry then I think you can put ##\mathbf{w}(f) = \{ f, P \}## for an arbitrary function ##f##?
In fact my knowledge is very limited in this area, my situation is as follows...
I have the metric, with the metric I can write the Hamiltonian, with the Hamiltonian, can I write the field? if yes, after that do i have to look for a symmetry? Apparently once I have symmetry, Noether's theorem gives me the first integral (his proof in this case), but I'm not getting it.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
