A Noise in Landau–Zener transition
  • A
  • Thread starter Thread starter kelly0303
    Simulation
kelly0303
Hello! I want to simulate a 2 level system in which the 2 levels are connected by an off-diagonal Hamiltonian term. I can linearly tune the distance between the 2 levels and thus I can transfer population from one to the other using a Landau–Zener transition. However, I want to add noise to this linear sweep. In my case the splitting between the 2 levels is adjusted by changing a magnetic field, but in practice the value of the magnetic field has some noise associated to it (due to noise in the current in the coils used to produce the magnetic field). I want to emphasize that that the noise leads to (small) changes in the magnetic while I do the linear sweep. So not only that the magnetic field is slightly different between different experimental runs, but it varies as a function of time while I perform the sweep. I would like to model this numerically and see the effect of different kind noise amplitude but I am not sure how to start. What is the easiest way to model noise in general and how should I proceed for more realistic representations of noise (any paper/book about this would be really appreciated, too)? In the end I would like to solve the Schrodinger equation associated to this 2x2 system in the presence of noise and extract the transition probability. Thank you!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
