Non-canonical form into canonical transformation 1-d partial dif.
In summary, the conversation discusses using the subtraction trick U(tilda) = U−U1 to reduce problems with non-canonical boundary conditions to canonical ones. The problems include a heat equation and a wave equation with dissipation and a perturbation on one end. The goal is to find the simplest u1's that solve each problem. The poster is using the equation U1(x,t)= a(t)+(x-c).b(t) to find the u1's but is struggling to find U(tilda). They are also searching for additional resources to help with the problem.
photomagnetic
Problem 29. Use the subtraction trick U(tilda) = U−U1 to reduce the following problems
with non-canonical boundary conditions to the canonical ones and write down the
equations in terms of the variable ˜u (do not solve them). Note that there are
infinitely many u1’s that solve each problem—try to find the simplest ones.
(a) Heat equation
ut = Uxx , x ∈ [0, l] ,
with the following boundary conditions
(a.1) u(0, t) = U(l, t) = A ,
(a.2) Ux(0, t) = 0 , U(l, t) = A ,
(a.3) U(0, t) = A , U(l, t) = B ,
(a.4) Ux(0, t) = Ux(l, t) = A ,
(a.5) Ux(0, t) = A , Ux(l, t) = B .
(b) Wave equation with dissipation and a perturbation on one end
Utt + aUt = c
2Uxx , x ∈ [0, l]
I am using
then U(x,t)=U(tilda)(x,t)+U1(x,t)
I can find the U1's but not U(tilda)
is that enough to transform them into canonical form?
I'm googling like a mad man but no luck so far. can't find any good sources.
you don't have to answer the question but a little help would be nice.
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
I've found the correct method.
Thanks anyway.
FAQ: Non-canonical form into canonical transformation 1-d partial dif.
1. What is a non-canonical form?
A non-canonical form is a mathematical expression or equation that does not follow the standard or traditional format. In the context of canonical transformations, a non-canonical form refers to a set of partial differential equations that cannot be transformed into canonical form using a single transformation.
2. What is a canonical transformation?
A canonical transformation is a change of variables in a system of equations that preserves the canonical form of Hamilton's equations. In other words, the transformed equations still follow the standard form of Hamilton's equations, which is crucial in studying the dynamics of a system.
3. Why do we need to transform non-canonical forms into canonical forms?
Transforming non-canonical forms into canonical forms is important because it allows us to apply techniques and methods from Hamiltonian mechanics to solve problems that involve non-canonical systems. This also helps to simplify the equations and make them more manageable for further analysis.
4. What is the process of transforming a non-canonical form into a canonical form?
The process of transforming a non-canonical form into a canonical form involves finding a suitable canonical transformation that can map the non-canonical equations to the standard form of Hamilton's equations. This usually requires solving a system of partial differential equations and applying certain mathematical techniques.
5. What are some applications of non-canonical form into canonical transformation 1-d partial dif.?
One of the main applications of transforming non-canonical forms into canonical forms is in the study of classical mechanics and Hamiltonian dynamics. This is also useful in various fields such as quantum mechanics, statistical mechanics, and control theory. It can also be applied in solving problems involving non-integrable systems and in understanding the behavior of chaotic systems.
