Non-Commutation Property and its Relation to the Real World
In summary: Property isn't quite the right word. "Behavior"? Sure, let's use that. We need to use math that behaves that way.
expos4ever
TL;DR Summary
It seems mysterious to me that properties of mathematical structures appear to dictate the nature of reality
I just learned that if two linear operators do not commute, this means when we use operators to characterize observables in quantum mechanics, the corresponding observables cannot both be definite at the same time. This seems hard to believe to me since I have a strong intuition, perhaps mistaken of course, that "mathematical structures" should not have the power to "dictate" the nature of reality. Let me be more concrete. I am told that the operators for momentum and position do not commute and that this means that, if I understand the argument properly, that nature itself will not allow a "particle" to possess both a position and a momentum simultaneously. I do not understand why these operators do not commute and, perhaps if I did, the mystery would disappear. But, at the moment, I believe, repeat believe, that I am being told that the properties of linear algebra determine something very fundamental about nature. And that seems wildly counterintuitive.
By the way, I am not sure if this post belongs in the linear algebra forum (here) or in the quantum mechanics forum. Moderators will move it, I guess, as they see fit. I also get the impression that this forum does not want "philosophical" matters to be discussed. However, I hope the following paragraph makes it clear that I am trying to stay grounded in the domain of physics.
In any event, am I right to be so astonished? Is there a sense in which the properties of mathematical objects (in this case commuting linear operators) actually dictate the way the world is? Or do I have the cart before the horse? Perhaps one of you will tell me that the reason the linear operators for position and momentum do not commute is because they are "set up that way by we humans" because we already know, from experiments, that these two observables cannot simultaneously have definite values. In that case, the astonishment is far less - there would be no sense in which mathematical structure dictates reality. However, even if experimental evidence determines the nature of these linear operators, it still seems remarkable that linear algebra can so closely model reality. Perhaps, though, this strays into the possibly forbidden territory of philosophy.
This. To understand it a little more deeply, consider: how would you create a particle in a state such that it had both definite momentum and definite position (to perfect accuracy)?
A famous quantum physicist Eugene Wigner was also puzzled about this, and wrote an essay titled "The Unreasonable Effectiveness of Mathematics". You can easily find it via google.
The bottom line is that mathematics is just logic. We choose particular mathematical tools in various circumstances that account closest for known phenomena. The best theories then predict new, hitherto unknown, phenomena, showing that we have a reaonably faithful correspondence between the mathematical model and physical reality.
Likes vanhees71, topsquark and dextercioby
expos4ever said:
TL;DR Summary: It seems mysterious to me that properties of mathematical structures appear to dictate the nature of reality
Do you also believe that the JSWT created all those stars and galaxies? If not then why would you make your absurd statement that I quoted? It is a really absurd statement. Are you just “trolling”, saying something you know is bizarrely unreasonable just to get some traction?
Likes gentzen
Let me use a quote from Bohr, but slightly modified: "Stop telling nature what to do".
Why do you not have these objectives against Newtonian dynamics?
Likes Vanadium 50 and topsquark
If you know what operators are, what these operators in particular are, and what it means to commute or not, then this should be clear. If not, then you should first make sure you understand the definitoins of those terms.
I think it have it backwards. It is the the properties of nature that tells us what the mathematical objects that model it should be. But if you have a good model, then the consequences of that model should also describe something about reality. For example, Euclidean geometry is a good model for small scale gemetry on Earth. Then a pure maths theorem (Pythagoras') says that if you take two sticks of length 3 and 4 units, put two ends at a right angle, then the distance between the other two will be 5 units. And if you do the experiment it is so. Do you find this counterintuitive?
Likes ohwilleke, malawi_glenn, gentzen and 2 others
No, you're not. You're being told that something about nature--something that has been tested in many experiments--is described in math using linear algebra with non-commuting operators. The math isn't dictating reality; reality is dictating the math.
Likes dextercioby, ohwilleke and Dale
Because that's how nature works at the quantum level: many actual measurements do not commute--their results depend on the order in which you make them. So to properly describe nature in this domain, we need to use math that has that property.
Likes ohwilleke and malawi_glenn
Thanks to those who answered courteously and with respect. However, I have decided to leave this forum so I will not be reading any more replies. Thanks again.
Likes malawi_glenn
Does it matter i.e. does $$\left [ horse,cart \right]=0~?$$
  • Haha
Likes Vanadium 50 and berkeman
Or that the angular sum in a triangle is 180 degrees. Well that does not work on large scales of the surface of the Earth, we need to change math then!
Likes dextercioby
Or that the operations of rotation and translation do not commute?? Compare rotation by 90deg and walking a mile to walking a mile and rotating 90deg. The difference is √2 mile!
Well, as much as I like PF the way it is, I think this happens way to often.
  • Skeptical
Likes Rev. Cheeseman
What do you think could have been made different in this case? From what I see, OP was given good replies. Not only in this thread, but in all threads of theirs.
OP was last seen 4 h after their latest post. I think OP will return :)
What do you think could have been different? See post 3.
I have been back on this site primarily to exchange some PMs. If you guys want this to be a place where people who are not as knowledgeable as most of you are feel welcome, well, I think you could be a tad more charitable. Let me be clear: it is not just the one post that I am concerned with. It is the fact that, based on things I have learned outside this thread, there appears to be a belief that such rudeness is "the price of doing business", as it were.
I do not buy that for a second.
In any event, I may indeed stick around, but only because my interest in physics eclipses my dignity.
  • Skeptical
Likes Motore
In my experience most physicists value the truth above all else. Personally I consider it a mark of great respect if someone goes to the often considerable trouble of figuring out why I am wrong. I treat such comments as gifts, and. where I come from "you don't look a gift horse in the mouth".
This is particularly the norm in technical matters and may seem rude to the uninitiated. It truly is not intended that way, but if you ask a truly ill-considered question, don't expect a soft rebuke and your dignity is not really the point. But good open minded inquiries are always welcomed.
Likes Vanadium 50, Motore, malawi_glenn and 4 others
This is a kinder, gentler form of exactly the thing I am talking about. You, of course, have zero evidence that my question was ill-considered. It may seem that way from your perspective, but it is patently unfair to imply anything of the sort on my part.
My question was genuine, I got flamed (if that is the right word) and you are making it seem this was deserved. And yet you clearly have no grounds for such a conclusion.
A politely worded question deserves an answer, not a rebuke, soft or otherwise. And to say "my dignity is not the point" is further evidence of the problem here - I would very much consider the dignity of the other person in any reply I would offer.
  • Skeptical
Likes Motore
...and given that so many have applauded this dismissive post, I am done. If your goal was to scare off someone who wants to learn, mission accomplished.
The question itself is evidence. Please note that "ill-considered" and "genuine" can both be true of the same question. You intended the question as an honest question; you say so, and I'm willing to take you at your word. But there was an obvious alternative (the one I described in posts #5 and #6 and that others gave examples) to the "astonishing" inference that you drew, that you did not consider. If another poster thinks you should have considered that obvious alternative, then to them, your question is ill-considered.
Empathy goes both ways. If you are asking for empathy for your honest attempt at asking a question, you should be willing to grant empathy to others' honest descriptions of how they see the question.
Likes martinbn and malawi_glenn
expos4ever said:
[...] I may indeed stick around, but only because my interest in physics eclipses my dignity.
I have been where you are now. Many rapid learning experiences for me have involved my dignity getting trashed. Eventually, I learned to stow my ego in the basement and just concentrate on trying to learn. Becoming proficient in some area of maths+physics is an excellent way to restore one's inner sense of dignity. :oldsmile:
HTH.
Likes PeterDonis, topsquark, Mondayman and 3 others
@expos4ever I am confused. What exactly in the replies caused you such grief?
FAQ: Non-Commutation Property and its Relation to the Real World
What is the non-commutation property in quantum mechanics?
In quantum mechanics, the non-commutation property refers to the fact that certain pairs of observables, represented by operators, do not commute. This means that the order in which you apply these operators matters. Mathematically, if \( \hat{A} \) and \( \hat{B} \) are two operators, they commute if \( \hat{A}\hat{B} = \hat{B}\hat{A} \). If \( \hat{A}\hat{B} \neq \hat{B}\hat{A} \), then they do not commute. This is fundamental in quantum mechanics and has significant implications for the measurement and behavior of quantum systems.
How does non-commutation affect measurements in quantum mechanics?
Non-commutation affects measurements in quantum mechanics by introducing uncertainty. According to the Heisenberg Uncertainty Principle, if two observables do not commute, it is impossible to measure both with arbitrary precision simultaneously. For example, position and momentum are a well-known pair of non-commuting observables. The more precisely you measure one, the less precisely you can measure the other. This intrinsic uncertainty is a direct consequence of the non-commutation property.
Can you provide a real-world example where non-commutation is significant?
A real-world example of non-commutation's significance is in the technology behind quantum computing. Quantum bits, or qubits, exploit the principles of superposition and entanglement, both of which are deeply rooted in non-commutative properties of quantum operators. The non-commutation of certain quantum gates is essential for the functioning of quantum algorithms, which can solve specific problems much faster than classical algorithms.
How is non-commutation related to the concept of spin in quantum mechanics?
Non-commutation is closely related to the concept of spin in quantum mechanics. The spin operators for a particle along different axes (e.g., \( \hat{S}_x \), \( \hat{S}_y \), and \( \hat{S}_z \)) do not commute with each other. This means that you cannot simultaneously know the spin components of a particle along different axes with certainty. The non-commutation of spin operators is fundamental to understanding phenomena such as spin precession and the behavior of particles in magnetic fields.
What mathematical tools are used to study non-commutation in quantum mechanics?
Several mathematical tools are used to study non-commutation in quantum mechanics. Key among them are commutators, which are defined as \( [\hat{A}, \hat{B}] = \hat{A}\hat{B} - \hat{B}\hat
