Non conducting cylinder and conducting cylinder
In summary, a non-conducting cylinder does not allow electric current to flow through it, while a conducting cylinder does. Non-conducting cylinders do not allow electric fields to pass through them, while conducting cylinders can distort or redirect electric fields. A non-conducting cylinder can become conducting through coating, covering, or exposure to high temperatures. Non-conducting cylinders are commonly used as insulators, while conducting cylinders are used in electronic components. Charges will accumulate on the surface of a non-conducting cylinder, while they will distribute evenly throughout a conducting cylinder.
shubham goel
what is difference between uniformly charged non conducting cylinder and conducting cylinder with respect to their charge distribution and conductivity?
You cannot have a uniformly charged conducting cylinder. If it is conducting then the charge will move to the outside and be most dense at the corners.
FAQ: Non conducting cylinder and conducting cylinder
1. What is the difference between a non-conducting cylinder and a conducting cylinder?
A non-conducting cylinder is a cylindrical object made of a material that does not allow electric current to flow through it, such as rubber or plastic. A conducting cylinder, on the other hand, is made of a material that allows electric current to easily flow through it, such as metal.
2. How do non-conducting and conducting cylinders affect electric fields?
Non-conducting cylinders do not allow electric fields to pass through them, while conducting cylinders can distort or redirect electric fields depending on their shape and placement in the field.
3. Can a non-conducting cylinder become conducting?
Yes, a non-conducting cylinder can become conducting if it is coated or covered with a conducting material, or if it is exposed to high temperatures that cause it to become ionized.
4. What are some real-world applications of non-conducting and conducting cylinders?
Non-conducting cylinders can be used as insulators in electrical wiring, while conducting cylinders are commonly used in antennas, capacitors, and other electronic components.
5. How do the charges distribute on a non-conducting and conducting cylinder?
On a non-conducting cylinder, charges will accumulate only on the surface, whereas on a conducting cylinder, charges will distribute evenly throughout the entire object due to the free movement of electrons.
