Non-consecutive forces with block and string
In summary, a 4-kg block attached to a 2 m string rotates on a horizontal surface with a co-efficient of friction of .25. The work done by the force of friction in each revolution of the block can be found using the equation Wnc=(KEf-KEi)+(PEf-PEi). However, the distance around the circle is not provided, so the answer cannot be calculated. The block is tied to a string pinned to the circle's center, and this allows for the calculation of the work done by friction.
BrainMan
279
a 4-kg block is attached to a string 2 m in length rotates on a horizontal surface. (a) If the co-efficient of friction between the block and the surface is .25, find the work done by the force of friction in each revolution of the block.
Wnc= (KEf-KEi)+ (PEf-PEi)
KEi+PEi=KEf+PEf
I attempted to find the work done by friction by multiplying the co-efficient of friction by the weight of the object and then multiplying that by the total distance around the circle. Unfortunately I couldn't find the distance around the circle based on the information provided. The answer to this problem was -123 J
Is the block tied to a string that is pinned to the circle's center?
I'm not sure
It works that way so I get it now. Thanks!
I would suggest that to find the work done by friction in each revolution of the block, we need to first calculate the total distance traveled by the block in one revolution. This can be done by using the formula for circumference of a circle, which is 2πr, where r is the radius of the circle. In this case, the radius would be equal to the length of the string, which is 2m.
Once we have calculated the distance traveled in one revolution, we can then use the formula for work, which is W = Fd, where W is work, F is the force applied and d is the distance traveled. In this case, the force applied would be the frictional force, which can be calculated by multiplying the co-efficient of friction (0.25) by the weight of the block (4 kg x 9.8 m/s^2 = 39.2 N).
Therefore, the work done by friction in one revolution would be W = (0.25 x 39.2 N) x (2π x 2m) = 49.1 J.
Since the question asks for the work done in each revolution, we can conclude that the work done by friction in each revolution of the block would be 49.1 J.
Related to Non-consecutive forces with block and string
1. What are non-consecutive forces?
Non-consecutive forces refer to a system in which the forces acting on an object are not applied in a straight line, but rather at different points on the object.
2. How does a block and string system involve non-consecutive forces?
In a block and string system, the force of tension in the string acts at a different point on the block than the force of gravity. This creates a non-consecutive force system for the block.
3. What is the purpose of studying non-consecutive forces in a block and string system?
Studying non-consecutive forces in a block and string system allows us to understand and predict the motion of the block, as well as the tension and acceleration of the string.
4. How do you calculate the tension in a string in a non-consecutive force system?
The tension in a string can be calculated using the equation T = mg + ma, where T is the tension, m is the mass of the block, g is the acceleration due to gravity, and a is the acceleration of the block.
5. Can non-consecutive forces in a block and string system ever be equal?
Yes, if the block is at rest or moving at a constant velocity, the forces acting on it must be balanced. In this case, the tension in the string will be equal to the force of gravity acting on the block.
11K
