Non conservative vector fields
ssrtac
F(x,y,z)=ax P(x,y,z)+ay Q(x,y,z)+az R(x,y,z)
F is vectoral field. ax , ay and az are unit vectors. P , Q ,R are scalar functions.
The question is this:
If F is non-conservative vectoral field ; what are the characteristics of P Q and R?
thanks in advance. have a nice day
This follows from the definition of conservative vector fields in 3-space. Did you check this definition? What exactly are you having trouble with? Look at the definition and see how you can apply each component of the vector field to it.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply . Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
