Non-constant acceleration kinematics
In summary, the problem involves finding the time it takes for a marble's speed to decrease by half in a certain fluid, where acceleration is proportional to the marble's speed squared. This can be solved by setting up the relationship between velocity and time, integrating both sides, and using the given initial velocity and time to solve for the desired time.
blackrose75
The acceleration of a marble in a certain fluid is proportional to the speed of the marble squared, and is given (in SI units) by a = -3.00v^2 for v > 0. If the marble enters this fluid with a speed of 1.50 m/s, how long will it take before the marble's speed is reduced to half of its initial value?
2. The attempt at a solution
I know that this question appeared here a while ago (found an archive to this exact one from two years ago) but I wasn't too sure with some of the help they gave so I'm asking again if someone would kindly help. I know that it involves a=dv/dt so that I end up with something like (v2-v1)=-3v^2(t-0). That may be wrong, I'm in a high school AP class and am just starting with some basic derivations in my calc class, so it is very possible that there's a flaw in all that (and in some of my terminology or whatnot) but if I'm on the right track my main concern would be the v^2. I saw on another post that someone did
dv/v^2 = -kdt
-1/v = -kt +C
but I'm not sure how they got there (besides it looking like they took the integral)
Again, things may be wrong and I wouldn't be surprised, but any help would be appreciated, thanks.
dv/v^2 = -kdt
-1/v = -kt +C
Welcome to PF.
The solution you are referencing is using acceleration as dv/dt. Since what you are looking for is a value for the difference in time that should be found by employing the difference in velocity of the given problem. You separate the V terms to the V side. (This eliminates I think your main concern.) And then integrate both sides.
That yields the relationship V to dv and t to dt.
-1/V = -k/t + C
Now using this relationship, subtract from one known Vo the other known V1, and with the initial t being 0 you can solve for t1
(-1/1.5) - (-1/ .75) = (-3*0+c) - (-3t1+c) = 3*t1
That's at least how I see the problem.
Thanks for the help, but I'm sorry to say I'm still a little bit lost on that...
FAQ: Non-constant acceleration kinematics
What is non-constant acceleration?
Non-constant acceleration refers to an object's motion where its acceleration is changing over time, as opposed to constant acceleration where the acceleration remains the same throughout the motion.
How is non-constant acceleration calculated?
To calculate non-constant acceleration, you need to know the initial velocity, final velocity, and time interval. The formula for non-constant acceleration is a = (vf - vi)/t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time interval.
What are some examples of non-constant acceleration?
Some examples of non-constant acceleration include a car accelerating from rest, a rollercoaster going up and down hills, and a rocket launching into space. In all of these cases, the acceleration is changing due to external forces acting on the object.
How does non-constant acceleration affect an object's motion?
Non-constant acceleration can greatly affect an object's motion. If the acceleration is increasing, the object will speed up over time. If the acceleration is decreasing, the object will slow down. In both cases, the velocity of the object will change, which will also impact its position and displacement.
How is non-constant acceleration represented on a position-time graph?
On a position-time graph, non-constant acceleration is shown as a curved line instead of a straight line. The steeper the curve, the greater the acceleration. The slope of the curve at any point represents the object's instantaneous velocity, and the area under the curve represents the object's displacement.
