Non dimensionalize pharmacodynamics
  • MHB
  • Thread starter Dustinsfl
In summary, using the Buckingham Pi Theorem, we can express the original equations as functions of dimensionless parameters, making them easier to understand and analyze. This also helps us make predictions about the system and better understand the relationship between the variables.
Dustinsfl
2,281
\frac{dG}{dt} = k_{inG} - k_{outG}\cdot G\cdot (1 + S_{Ins}[n]\cdot I)
\frac{dI}{dt} = k_{inI}[m]\cdot (1 + S_G[r]\cdot (G - G_0)) - k_{outI}\cdot I
The units for the first equation are $ k_{inG} = \frac{mg(week)}{dl}$, $k_{outG} = \frac{1}{week}$, $G = \frac{mg(week)^2}{dl}$, $S_{Ins}[n] = \frac{ml}{ng}$ and $I = \frac{ng}{ml}$
The second are $k_{inI} = \frac{ng(week)}{ml}$, $S_G[r] = \frac{dl}{mg}$, $G = G_0$, and $k_{outI} = \frac{1}{week}$
I am not sure how to do this very well since I didn't get a response to my Buckingham Pi Theorem question which would help me understand how to do this.
Mathematics news on Phys.org
No problem, I'll try to explain it in a simpler way. The Buckingham Pi Theorem states that if you have a physical relationship between multiple variables, you can express it as a function of dimensionless parameters. These dimensionless parameters are called Pi terms and they help simplify the equation and make it easier to understand.
In the first equation, we have four variables: $G$, $t$, $k_{inG}$, and $k_{outG}$. Using the Buckingham Pi Theorem, we can express this equation as a function of two dimensionless parameters, which we will call $P_1$ and $P_2$.
P_1 = \frac{k_{inG}t}{G} \quad \text{and} \quad P_2 = k_{outG}t
Notice that both $P_1$ and $P_2$ are dimensionless, as they are ratios of variables with the same dimensions. Now, we can rewrite the equation as:
\frac{dG}{dt} = P_1 - P_2\cdot G\cdot (1 + S_{Ins}[n]\cdot I)
Similarly, for the second equation, we have four variables: $I$, $t$, $k_{inI}$, and $k_{outI}$. Using the Buckingham Pi Theorem, we can express this equation as a function of two dimensionless parameters, which we will call $P_3$ and $P_4$.
P_3 = \frac{k_{inI}t}{I} \quad \text{and} \quad P_4 = k_{outI}t
Again, notice that both $P_3$ and $P_4$ are dimensionless. We can rewrite the equation as:
\frac{dI}{dt} = P_3\cdot (1 + S_G[r]\cdot (G - G_0)) - P_4\cdot I
Now, we can see that both equations have been simplified and are expressed in terms of dimensionless parameters. This helps us better understand the underlying physical relationship between the variables and allows us to make predictions and analyze the system more easily.
FAQ: Non dimensionalize pharmacodynamics
What is non dimensionalization in pharmacodynamics?
Non dimensionalization in pharmacodynamics is a mathematical technique used to simplify and standardize equations that describe the relationship between drug concentration and its effect on the body. It removes any units or scales from the equations, making them more generalizable and easier to compare across different systems and scenarios.
Why is non dimensionalization important in pharmacodynamics?
Non dimensionalization is important in pharmacodynamics because it allows for the comparison and analysis of drug response across different species, doses, and drug properties. It also helps in identifying key factors that influence drug response and in developing more accurate and efficient drug dosing strategies.
How is non dimensionalization achieved in pharmacodynamics?
Non dimensionalization is achieved by normalizing the variables in pharmacodynamic equations to a reference value. This reference value can be chosen based on the properties of the drug, the target tissue, or the system being studied. The resulting equations are then free of any units or scales, and can be expressed in terms of dimensionless numbers.
What are the benefits of using non dimensionalization in pharmacodynamics?
Using non dimensionalization in pharmacodynamics offers several benefits. It simplifies complex mathematical models, making them easier to interpret and analyze. It also allows for the comparison of drug response across different species, doses, and drug properties. Additionally, it helps in identifying key factors that influence drug response and in developing more accurate and efficient drug dosing strategies.
What are some limitations of non dimensionalization in pharmacodynamics?
While non dimensionalization is a useful technique in pharmacodynamics, it also has some limitations. It assumes that the equations being simplified are linear and follow certain rules, which may not always be the case. It also requires a reference value to be chosen, which may not always be clear or easy to determine. Additionally, non dimensionalization may not be appropriate for all types of pharmacodynamic models, such as those that involve complex mechanisms or interactions.
