Non-Isomorphic Abelian Groups of Order 54 and the Isomorphism of Factor Groups
  • Thread starter GatorPower
  • Tags
    Groups
In summary, using the fundamental theorem for abelian groups, it is determined that there are three non-isomorphic abelian groups of order 54: Z2 x Z3 x Z3 x Z3, Z2 x Z9 x Z3, and Z2 x Z27. When considering the factor group Z6 x Z18 / <(3,0)>, it is found that the group is not cyclic and does not contain an element of order 9, making it isomorphic to the second group, Z2 x Z9 x Z3. A similar approach is used to determine that the factor group Z6 x Z8 / <(2,0)> is isomorphic to Z8 x Z2. To make
GatorPower
Determine how many non-isomorphic (and which) abelian groups there are of order 54.
Determine which of these groups the factor group Z6 x Z18 / <(3,0)> is isomorphic to.
Fundamental theorem for abelian groups gives:
54 = 2*3^3 and then the groups are
Z2 x Z3 x Z3 x Z3
Z2 x Z9 x Z3
Z2 x Z27
For the second part: <(3,0)> = { (0,0), (3,0) } so we get that the order of our group is (6*18)/2 = 54 as expected. But how do I decide which group it is isomorphic to? I have tried looking at cosets like (1,0) + <(3,0)> but don't seem to get anywhere...
You could ask yourself the following questions:
- Is my group cyclic?
- Do I have elements of order 9?
Answer these questions for the three groups you've found, and for the factor group in question. From the answer, you can discriminate between the groups...
The two first groups are not cyclic, only Z2 x Z27.
One does not have an elt of order 9 since 18/9 = 2 but <(3,0)> + (0,2) does not have order 9 seeing that (27,18) = (3,0)
Our group is not cyclic, and does not contain an elt of order 9 so hence it is isomorphic to the first group. Correct?
I don't quite understand this part of your argument. What does (27,18)=(3,0) have to do with <(3,0)>+(0,2) and order 9?
I think I have thought about something wrong. There is in fact an element of order 9 which is (0,2) in the factor group. Then the factor group must be isomorphic to the SECOND one.
These elements do equal (0,0)+<(3,0)> when added 9 times! Note that
(27,18)+<(3,0)>=(0,18)+(27,0)+<(3,0)>=(0,18)+<(3,0)>=(0,0)+<(3,0)>...
So it is the second one? What kind of strategies does one use on this kind of problems? My book is pretty bad at explaining this..
Yes, it is the second one. For these kinds of problem, find some properties with discriminate between groups (like order, abelianness,...). Then check which of the properties the group in question has, and make your conclusions from that!
Another problem: Order is now 16 and the factor group is Z6 x Z8 / <(2,0)>.
(0,1) + <(2,0)> has order 8, so the only possible isomorphism is to Z8 x Z2 or Z16. But Z16 is cyclic, and the factor group is not so the isomorphism is to Z8 x Z2. Correct?
That seems to be correct!
Another question! Factor group Z6 x Z8 / <(2,0)>.
(0,1) + <(2,0)> has order 8, so we have two possible isomorphisms to Z8 x Z2 and Z16.
Seeing that the factor group don't have any elements with order 16 we decide it is isomorphic to Z8 x Z2. Correct?
Correct! Maybe you can make it easier on yourself and prove this result:
If N is a normal subgroup of G, then [tex]\frac{G\times H}{N\times \{0\}}\cong (G/N)\times H[/tex]. This would also solve all your exercises...
Thank you =)
Related to Non-Isomorphic Abelian Groups of Order 54 and the Isomorphism of Factor Groups
1. What is an Abelian group?
An Abelian group is a mathematical structure consisting of a set of elements and a binary operation (usually denoted as "+") that satisfies the following properties: closure, associativity, identity element, inverse element, and commutativity. In simpler terms, an Abelian group is a set of numbers or objects that can be combined using addition and still maintain the same result regardless of the order in which the elements are combined.
2. What does it mean for an Abelian group to be commutative?
The commutative property in an Abelian group means that the order in which elements are combined using the binary operation does not affect the result. In other words, for any two elements a and b in the group, a+b = b+a. This property is named after the mathematician Niels Henrik Abel, who was the first to study these types of groups.
3. What are some examples of Abelian groups?
Some examples of Abelian groups include the set of integers with addition as the binary operation, the set of real numbers (excluding 0) with multiplication as the binary operation, and the set of complex numbers (excluding 0) with multiplication as the binary operation. Other examples include finite groups such as the group of all rotations of a square and the group of all symmetries of a cube.
4. How are Abelian groups related to other mathematical concepts?
Abelian groups are closely related to other mathematical concepts such as rings, fields, and vector spaces. In fact, an important property of a ring is that its underlying additive structure is an Abelian group. Similarly, a field is a special type of ring where the underlying Abelian group is also commutative. Vector spaces, which are used in linear algebra, are also an example of an Abelian group.
5. What are some applications of Abelian groups?
Abelian groups have many applications in mathematics and other fields such as physics and chemistry. They are used to study symmetry, group theory, and abstract algebra. In physics, Abelian groups are used to describe the properties of particles and their interactions. In chemistry, they are used to study molecular symmetry and molecular orbitals. Abelian groups are also used in cryptography and coding theory.
