Non-Linear optics vs The 2nd Law of Thermodynamics
In summary, the experiment results in the ball getting colder due to the 2nd law of thermodynamics being circumvented.
  • #36
heheh, ok. typos'r'us.
Science news on Phys.org
  • #37
Next: are you familiar with Boltzmann?
  • #38
I noticed the name while auditing some articles on black bodies.
  • #39
Boltzmann distribution?
  • #40
hmmm27 said:
yes, and by that standard of measurement, at some frequencies it could be greater than one.
I think this is the key. It is never greater than 1. A perfect absorber is 1 and you can't do better than perfect. And the coefficient is the same for emission and absorption.
The maximum peak of an emitter can only bring the emission coefficient up to 1, not beyond. Meaning that (without doing work on it) a system at a given temperature cannot emit more energy at any frequency than a blackbody at that same temperature.
hmmm27 said:
noting that bb emissions have nothing to do with bb absorptions
They have everything to do with each other. That is the whole point of the hyperphysics page. The absorption coefficient is always exactly equal to the emission coefficient. They are the same thing. That is necessary for the 2nd law and follows from QM, as described in the hyperphysics page.
hmmm27 said:
I don't see why that would hold true as a basic premise, though agreed at non-fluorescent-specific emission frequencies
The reason this holds true as a basic premise is explained in the hyperphysics page. It holds for all frequencies, including the fluorescent-specific emission frequency.
hmmm27 said:
How does the "thermal flux" being "large" have anything to do with it ?
In any radiative heat interaction there is energy going both ways. There is energy going from the cold object to the hot object. But there is more energy from the hot object to the cold object. So it isn't enough to point out that there is energy flux from cold to hot, you also have to consider the flux backwards and compare how large they are.
My rough estimation shows the thermal flux to be about 20 times greater than the fluorescent flux.
  • #41
Mmmm... a formula that shows the particle distribution of energy levels at a given temperature. Interesting, you'd think that some levels wouldn't be a completely linear sequence.
I understand the concept of AC referring to a specific atom or molecule: simply a measurement of how many photons are absorbed compared to the total that impinge in some manner. If they're all absorbed, then "1". If half are reflected or transparented, then 0.5 . Easy. (though there may be some question for a future time about the "transparented" bit, which doesn't have any bearing, currently)
(oh, I wrote "atom or molecule" because I had ac/ec confused with "gray body" which involves gross surface structure)
EC seems a bit more complex : a measurement of photons emitted... in comparison to what ? The number of the appropriate level drops that occur without a photon being produced ? (ie: resulting in energy of some kind being passed somewhere else). How could that be measured ? or is it inferred from the AC. As far as AC=EC, while the interesting actions are symmetrical: photon absorbed<>photon produced... the other ones: reflection or energy transfer, don't seem to be (to me, at this point), though it certainly is an attractive proposition.
[a later point and it does make sense: pardon the crudity of explanation but the whatever that stops a photon from being absorbed is the same thing that the energy bounces off of and decided to go somewhere else, instead. okay, it doesn't make complete sense, barely partial sense, but it's a start]
What is interesting and could be relevant later on is that a photon can hit a molecule, be absorbed, then either be re-emitted (different photon, same frequency) or changed into vibration. EC determines that probability, also determines it for a relaxation of either kind (emit photon or warm the surroundings) achieved from a level, caused by vibration instead of a photon. So the probability of an impinging photon directly resulting in an emitting photon is EC2
That was quite a bit of work. I hope I'll need it.
Dale said:
The maximum peak of an emitter can only bring it up to blackbody, not beyond.
Which is where I'm stuck up to my arse, obviously. Why does the combination of a pre-existing spectral line and thermal radiation not cause a bump on top of the bb curve.
How can I, or why can't I, cut/paste nested quotes ?
I meant that absorption distribution has nothing to do with emission distribution, except in terms of power equalization.
At the fluorescence wavelength the material is a good emitter, and hence also a good absorber.
So the fluorescing mechanism is non-sequitur to the act of absorption and emission if taken as separate processes. It simply notes that a bumping up results only in a partial relaxation due to some internal mechanism or relationship.
Okay, that's not "simple" in any respect. Is there something special about the half-level ?
According to some earlier ramblings of mine , "fluorescence" therefore doesn't actually need an incoming photon: it could be caused by an internal energy transfer to reach the higher energy state, then fall to the half-level.
So, let's be on the same page and note that the first paragraph has nothing to do with the second.
Re: the first: with the premise I walked in with (and haven't fully let go of) - that a fluorescent spike and dip would be added to a thermal curve in some manner, rather than be incorporated into it - it's trivial to design a theoretical contraption using bandpass filter(s), that sequesters (more) heat at one end. Using that premise, before equilibrium is reached, the temperature of C as measured from F (through the filter) is hotter than the temperature of F as measured from C(ttf). At equilibrium - when the power flows are the same, F as measured at F is hotter than C measured at C. Rinse and repeat for the relationship between F and H. (Cold side, Fluorescer, Hot side)
Re: the second: good to know. Without reference it's meaningless of course (it was Rhodamine101 fluorescing from/to 576/600nm, 300K I think. There was an interesting sidenote concerning "Karstens, who merely showed that QY is independent of temperature", without specifying the temperature range tested at, nor stating if QY reading was normalled by excluding predicted bb radiation at those temperatures. I don't have my 1871 J.Phys.Chem handy to check the original).At which point it looks like I'm in violation of forum rules, if massively misunderstanding something counts as a "personal theory".
  • #42
Yes, your description sounds good to me.
In comparison to a blackbody. The point is that at a given temperature and wavelength (without work) a material cannot absorb half of what a blackbody does without also emitting half of what a blackbody does.
At thermal equilibrium and without work, I think that is right.
The bump isn't a wavelength that has a higher emissivity than a blackbody surrounded by wavelengths with equal emissivity. It is a wavelength with emissivity close to a blackbody surrounded by wavelengths with much lower emissivity. The material has an available energy transition at the fluorescence wavelength, so it emits and absorbs well at that wavelength, but not at nearby wavelengths.
OK, I misunderstood. I was talking about absorption and emission coefficients and you were talking about absorption and emission spectra.
Not that I am aware of, except that it is a relatively big jump with no available intermediate transitions. The lack of intermediate levels is what makes the material have reduced absorption and emission at nearby wavelengths.
  • #43
in comparison to a black body
Well... that's wrong, innit : it should be "compared to the total number of relaxations", no ?
The contraption description is now a forum-friendly
An enclosed system, consisting of a cold end with a thermal mass, and a hot end with a fluorescer, separated by a filter, bandpass at the fluorescer's absorption wavelength.
  • #44
No, it is correct. Compared to a blackbody, which is a perfect absorber and the best thermal emitter possible.
hmmm27 said:
The contraption description is now a forum-friendly "An enclosed system, consisting of a cold end with a thermal mass, and a hot end with a fluorescer, separated by a filter, bandpass at the fluorescer's absorption wavelength".
If the fluorescent relaxation state was more persistent, then upshifts could happen as well as downshifts.
No. Since the fluorescent material absorbs well at the absorption wavelength it also emits well at that wavelength. So the fluorescent material heats up the cold thermal mass.
  • #45
Short answer: That's specifically in reference to the last paragraph, as applied to the first, right ? I edited that out seeing your response, after you quoted it, but before you edited your response to include it. Or something like that. The two paragraphs weren't actually related.
I deleted it, pending further rumination on energy states. What I jotted down looks like a very elegant answer, but I've no basis to put it forward 'cuz I know squat about how energy states develop as temperatures rise. Could you recommend a web resource on the subject, that uses English as much as Greek ? (ie: formulas thoroughly explained).
If the short answer doesn't apply, then the long answer is where I try to explain that if the fluorescence is the only absorber at a certain wavelength then (given the normal lack of upshifts in the mechanism), the emission coefficient of the absorption wavelength should be the inverse of the quantum yield of the fluorescence.
Again, thank you for taking the time to converse.
  • #46
Sorry about that. For multi-part replies sometimes I add the parts by edit, but usually I try to do that soon enough that it doesn't cause exactly that problem.
I just realized that in your previous comment (the one I said "No, ..." to earlier today) you may have meant upshift in energy and I was thinking of upshift in temperature. So I am not sure what you mean by that.
hmmm27 said:
Could you recommend a web resource on the subject,n
I am partial to Susskinds lectures. Here is the first in the series
  • #47
This explanation isn't really based on anything except elegance, but should be mildly entertaining.
For normal fluorescing, let's call the energy states a,b,c for base, excited and relaxed.
Normal fluorescence goes a>b>c, then a dissipation back to a. Absorption is at the a,b gap (difference in energy levels), emission at the b,c gap.
If the c state were more persistent - didn't leak as much; stuck around awhile, whatever - then there could be b>c>a fluorescence where absorption is at the b,c gap and emission at the a,c gap. Which is a symmetric reversal of normal fluorescence.
If the number of emissions of each type fit into the bb spectrum, there would be no (net) biasing of the distribution spectrum.
So, if an increase in temperature causes the aforementioned to happen, then everybody's happy (except maybe the guy who built the contraption that just lost its ambient greenhouse-effect capability).
Elegant. Also convenient... too convenient.
