maxim
- 6
- 1
- TL;DR Summary
- ideas on how to realize a 600-700 mm linear displacement system for a sensor in a strong magnetic field, controlled by a motor stepper
Dear mechanical expert
I have to realize a linear displacement system for a Hall sensor that has to slide along the central axis of a narrow cylinder and with which high intensity magnetic field measurements (1-14 Tesla) have to be made.
The field is produced by a commercial vertical magnet (Oxford 600/51 Superconducting Magnet).
The sensor is a Lakeshore HGCA-3020 (diameter: 6.4 mm, length: 5.1 mm)
The linear displacement is along the z axis of the magnetic field, and the maximum expected excursion is about 60-70 mm starting from the center of the magnetic field (highest field point, T = 14 Tesla), downward.
I'm looking for a compatible solution to this data, but I need some suggestions because:
1) all components must be absolutely non-magnetic in order not to interfere with the measurements and not to get stuck in the magnet.
2) All the mechanical moving parts must be contained in a cylinder 550 mm long and < 40 mm diameter
3) The Lakeshore HGCA-3020 sensor must move while remaining centered along the z axis of the cylinder (where B measurements will be made)
4) Each reading point must be associated with the sensor position along the z axis, in order to reconstruct the "profile" of the magnetic field B(z)
For point 1) one can use non-magnetic metals such as some steels, copper or bronze with which to build worm screws and, of course, all types of plastic, polymeric and / or Teflon material. In my opinion the main problem arises for the actuators, because they have to work in the presence of a strong magnetic field, of the order of 1-2 Tesla.
For point 2), on the other hand, I need some ideas both to create the supporting skeleton of the structure and to create the actual linear movement.
Since good precision in moving is required, is it better to use a stepper motor or a linear actuator?
And where can I find these components?
Point 3) suggests that a worm screw in the center of the cylinder cannot be used, because the Hall sensor must be located exactly in that seat. Thus I imagined that a solution based on linear actuators is more suitable.
The main question is: are there linear displacement actuators (linear step motors) capable of covering the distance of 60-70 cm?
Point 4) is fundamental: how can I keep track of the displacement during the measurement?
What I've found in the market:
TSM17Q-1AG motor+drive+encoder+controller
