Non-physicist needs your help torquing a nut!
  • B
  • Thread starter AlanSta
  • Tags
    Torque
In summary, the article discusses a situation where a non-physicist seeks assistance in applying torque to a nut, emphasizing the importance of understanding the principles of torque and mechanical advantage for effective problem-solving in practical scenarios.
AlanSta
TL;DR Summary
Zero understanding in physics, need to torque a nut (500Nm) by applying my weight (62.5kg) at a certain distance of the wrench (81.5cm?). And I need you to correct me.
Hello, as you can tell by the title I don’t work with anything physics related nor do I study it. I’m trying to figure out if I can torque a nut without a torque wrench, and I have ZERO understanding in physics.
And I need your help to tell me that I’m wrong.
I want to try to torque the nut by applying my weight on a wrench at a certain distance from the socket.
From what I’ve read the torque calculation consists of: Distance (r), Force (F) and Torque (T). And that force is Weight x Acceleration.
First the Force.
I would be standing on the wrench so it would be acceleration of gravity which is 9.81m/s2, and my weight with clothes aprox. 62.5kg.
62.5kg x 9.81m/s2 = 613N
The torque that I want to achieve is 500Nm, I used a Torque Calculator for this one, since I don’t know the equation and this is what I got.
Distance (r) 81.5cm
Force (F) 613N
Torque (T) 500Nm
Now if I’m somewhat close to correct, then if I apply my weight 81.5 cm from the center of the socket then I will achieve torque of 500Nm?
How wrong am I?
Welcome to PF.
AlanSta said:
How wrong am I?
You are correct.
500 / ( 62.5 * 9.81 ) = 0.815 m
AlanSta said:
TL;DR Summary: Zero understanding in physics, need to torque a nut (500Nm) by applying my weight (62.5kg) at a certain distance of the wrench (81.5cm?). And I need you to correct me.
The equation is rather simple:
T = Fd
where ##T## is torque, ##F## force, and ##d## the lever arm.
AlanSta said:
500Nm
That must be a pretty big nut! What does it go on?
Hi @AlanSta. Welcome to PF!
In addition to what's already been said, it may be worth noting that the wrench needs to be horizontal - or reasonably near horizontal - when you do it.
That's because, for the calculation to be correct, the force (your weight acting vertically downwards) needs to be perpendicular to the wrench.
If the force and wrench aren't perpendicular, the calculation is slightly more complicated.
Edit - typo's
It doesn't need to be though, as long as one remembers that it is the horizontal distance that is the lever arm. If the wrench is too long, simply turn it until the horizontal projection has the required length.
Good point. But there could be health and safety implications if trying to do this (perhaps without assistance) whilst balancing on (or hanging from) a long non-horizontal wrench!
Edit: I originally typed 'wench' before correcting it to 'wrench'. Which I found amusing!
Welcome, Alan!
Consider that while you stand on the wrench, the end or socket in contact with the nut will tend to slip out of position.
More, the more your force is off the same vertical plane of the nut.
Normally, we hold the socket in place with one hand and apply force with the other.
Also, jumping on the wrench will greatly increase the torque reaching the nut.
In many cases, the torque is specified with dry or oiled threads and always, I'd say, everything should be corrosion free. But that may be telling my grandmother how to suck eggs. But, like at sea, it's better to be told twice than not at all.
I'll never forget learning this lesson. My friend and I couldn't for the life of us get the lug nuts loose on his VW. His neighbor came from across the street and performed this magic trick for us.
Likes Lnewqban
FAQ: Non-physicist needs your help torquing a nut!
What is torque and why is it important for tightening nuts?
Torque is a measure of the rotational force applied to an object, in this case, a nut. It is important for tightening nuts because it ensures that the nut is secured properly without over-tightening, which can lead to stripping threads or damaging components. Proper torque helps maintain the integrity of the assembly and prevents loosening due to vibrations.
How do I determine the correct torque specification for a nut?
The correct torque specification for a nut can usually be found in the manufacturer's documentation, service manuals, or engineering specifications for the particular application. If the specifications are not available, general guidelines based on the size and grade of the nut and bolt can be used, or a torque chart can be referenced for common applications.
What tools do I need to torque a nut properly?
To torque a nut properly, you will need a torque wrench, which is a tool designed to measure the amount of torque being applied. Additionally, you may need a socket or wrench that fits the nut, and possibly a breaker bar if the nut is particularly tight. It's important to use a calibrated torque wrench to ensure accuracy.
What is the proper technique for using a torque wrench?
To use a torque wrench properly, first, set the desired torque value on the wrench according to the specifications. Then, attach the appropriate socket to the wrench and place it on the nut. Apply steady pressure while turning the wrench until it clicks or signals that the set torque has been reached. Always pull the wrench in a smooth, controlled manner, and avoid jerking or releasing pressure before the click.
What should I do if I over-torque a nut?
If you over-torque a nut, it is important to assess the situation carefully. If the nut has stripped threads or if the bolt has been damaged, you may need to replace the affected components. If the nut is still usable, you can try to loosen it slightly and then re-torque it to the correct specification. Always inspect for any signs of damage before reassembling.
78K
