MHB Non-recursive formula for the $n$th term of a linear homogeneous recurrence
The discussion focuses on deriving a non-recursive formula for the nth term of a linear homogeneous recurrence defined by specific initial conditions and a recurrence relation. The approach utilizes generating functions to encode the recurrence into a sum, leading to the formulation of the generating function a(z). By substituting the initial values into the derived equation, the generating function is expressed as a rational function. Through partial fraction decomposition and application of a series expansion theorem, the nth term is ultimately expressed as a combination of powers involving characteristic roots. The final formula for the nth term is a_n = (-√3 - 1)^n + (√3 - 1)^n.
Nono713
MHB
Just an easy one to start off with, find a non-recursive formula for the $n$th term of the following linear homogeneous recurrence:
$$a_0 = 2, ~ ~ a_1 = -2, ~ ~ a_n = -2 a_{n - 1} + 2 a_{n - 2} ~ ~ \text{for} ~ n \geq 2$$​
Hint:
You can use generating functions to solve this problem.
Mathematics news on Phys.org
The characteristic roots are:
$$r=-1\pm\sqrt{3}$$
and so the closed form is:
$$a_n=k_1(-1+\sqrt{3})^n+k_2(-1-\sqrt{3})^n$$
Using the given initial values, we may write:
$$a_0=k_1+k_2=2$$
$$a_1=k_1(-1+\sqrt{3})+k_2(-1-\sqrt{3})=-(k_1+k_2)+\sqrt{3}(k_1-k_2)=-2+\sqrt{3}(k_1-k_2)=-2$$
Thus:
$$k_1=k_2=1$$
$$a_n=(-1+\sqrt{3})^n+(-1-\sqrt{3})^n$$
But how did you work out those characteristic roots? Show your working :cool:
(I don't actually know what characteristic roots are - are they that easy to derive? I approached this with generating functions myself)
The associated auxiliary equation is:
$$r^2+2r-2=0$$
Use of the quadratic equation gives the characteristic roots.
We essentially assume a solution of the form:
$$a_n=r^n$$ where $$r\ne0$$
and so substitution into the recursion gives:
$$r^n=-2r^{n-1}+2r^{n-2}$$
Dividing through by $$r^{n-2}$$ and rearranging in standard quadratic form gives the characteristic or auxiliary equation above.
Let $a(z) = \sum_{i = 0}^\infty a_i z^i = a_0 + a_1 z + a_2 z^2 + \cdots$ be a generating function such that $a_n$ corresponds to said recurrence. Consider:
$$a(z) + 2 z a(z) - 2 z^2 a(z)$$
The reason we do this is because when we multiply $a(z)$ by $z$, we increment every exponent in the generating function by $1$, and then $a_1$ is paired with $z^2$, $a_2$ is paired with $z^3$, and so on. So we see that the sum above is just the recurrence relation, encoded into a sum of generating functions. Let's write down the first few terms of these three different generating functions:
\begin{array}{|c|cccl|}
\hline
a(z) &a_0 &a_1 z &a_2 z^2 &\cdots \\
2 z a(z) &~ &2 a_0 z &2 a_1 z^2 &\cdots \\
-2 z^2 a(z) &~ &~ &- 2 a_0 z^2 &\cdots \\
\hline
\text{Sum} &a_0 &(a_1 + 2a_0) z &0 &\cdots \\
\hline
\end{array}
We note the resulting coefficients for $z^2, z^3, \cdots$ are zero, since $a_n = -2 a_{n - 1} + 2 a_{n - 2}$ for $n \geq 2$. It follows that:
$$a(z) + 2 z a(z) - 2 z^2 a(z) = a_0 + (a_1 + 2 a_0) z$$
Rearranging, we obtain:
$$a(z) \left ( 1 + 2 z - 2 z^2 \right ) = a_0 + (a_1 + 2 a_0) z$$
Now we may plug in the initial values $a_0 = 2$, $a_1 = -2$ into the equation:
$$a(z) \left ( 1 + 2 z - 2 z^2 \right ) = 2 + 2 z$$
To finally obtain an expression for $a(z)$, our original generating function:
$$a(z) = \frac{2 + 2z}{1 + 2 z - 2 z^2}$$
By partial fraction decomposition, we can deduce that:
$$a(z) = \frac{\alpha}{\alpha + 2z} + \frac{\beta}{\beta - 2z} = \frac{1}{1 + \frac{2}{\alpha} z} + \frac{1}{1 - \frac{2}{\beta} z}$$
Where $\alpha = \sqrt{3} - 1$ and $\beta = \sqrt{3} + 1$. We can then use the theorem that:
$$\frac{1}{1 - nz} = \sum_{i = 0}^\infty n^i z^i$$
This yields:
$$a(z) = \sum_{i = 0}^\infty \left ( - \frac{2}{\alpha} \right )^i z^i + \sum_{i = 0}^\infty \left ( \frac{2}{\beta} \right )^i z^i = \sum_{i = 0}^\infty \left [ \left ( - \frac{2}{\alpha} \right )^i + \left ( \frac{2}{\beta} \right )^i \right ] z^i$$
And we can then just read off the coefficient of $z^i$ to evaluate the recurrence at $a_i$. We conclude:
$$a_n = \left ( - \frac{2}{\alpha} \right )^n + \left ( \frac{2}{\beta} \right )^n = \left ( - \frac{2}{\sqrt{3} - 1} \right )^n + \left ( \frac{2}{\sqrt{3} + 1} \right )^n$$
Which, after simplifying the fractions, becomes:
$$a_n = \left ( - \sqrt{3} - 1 \right )^n + \left ( \sqrt{3} - 1 \right )^n$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
