Non-selfadjointness and solutions
In summary: Thanks!In summary, the two operators Q and Q' give the solution (in ##QQ'\Psi=0##):\begin{equation} \psi(x)= \frac{1} {4} e^{-2i\gamma x/\hbar}+\frac{3}{4}+\frac{i \gamma x }{2 \hbar}\end{equation}
SemM
Hi, I have the two operators:
\begin{equation}
Q = i\hbar \frac{d}{dx} - \gamma
\end{equation}\begin{equation}
Q' = -i\hbar \frac{d}{dx} - \gamma
\end{equation}
where ##\gamma## is a constant. Both of these are not self-adjoint, as they do not follow the condition:
\begin{equation}
\langle {Q}x, y \rangle = \langle x, {Q}^{*}y \rangle,
\end{equation}
thus being non-Hermitian.
This gives , for the system ##QQ' = 0## a non-selfadjoint solution, which cannot be normalized, or used to derive expectation values.
What can I do?
Thanks!
Both Q and Q' are hermitian. Whether they are self adjoint or not depends on the domain of definition, but normally, they can be chosen to be self-adjoint.
Likes dextercioby
For Hermiticity one has to follow the given condition:
\begin{equation}
\langle \phi \vert Q \vert \psi \rangle = \langle Q \phi \vert \psi \rangle
\end{equation}doing this on ##Q##, with ##\phi = x## and ##\psi = x^2## we have:
\begin{equation}
\langle \phi \vert Q \vert \psi \rangle = \int x (i\hbar \frac{d}{dx} - \gamma)x^2 dx = \int i\hbar 2x^2-\gamma x^3 dx
\end{equation}
\begin{equation}
\langle Q \phi \vert \psi \rangle = \int (i\hbar \frac{d}{dx} x - \gamma x) x^2 dx = \int i\hbar x^2 - \gamma x^3 dx
\end{equation}So:
\begin{equation}
\langle \phi \vert Q \vert \psi \rangle \ne \langle Q \phi \vert \psi \rangle
\end{equation}unless, I have done something wrong with prioritizing x^2 over x in the first integral, given that d/dx is to the left of x^2.The same accounts for ##Q'##, only with the minus sign . So I cannot see how these two operators are self-adjoint. Indeed, the solution to ##QQ'= 0## gives a non-square-integrable function, which is discontinuous in ##\mathscr{H}## and gives therefore non-trivial expectation values. That should further confirm that these operators ##Q\ and\ Q'## are not hermitian.
Neither x nor ##x^2## are functions in the hilbert space, hence the integrals do not exist. So your statement that the two integrals are different is pointless.
You have to use partial integration on functions which at least vanish at ##\pm \infty## to show the equivalence.
Likes SemM and dextercioby
Thanks Dr Du! I can't imagine a reason for why such a critical point has never been given in relation to these points in the textbooks, as an example. I see indeed that they are not infinetly differentiable.
Would ##e^{-x}## and ##e^{-3x}## be sufficient?
Thanks!
Diverge at - infinity, don't they?
Likes SemM
Sorry, I can't see that. I see that they approach zero in an interval [a, b]. Although, I could always look up in a book, an example would make this discussion come to a completion also for other readers. Do you have an example?
Thanks!
The discussion is most easy for functions defined on the interval ##[ -\infty, \infty]##. Then you might consider for example ##\exp(x^2), x*\exp(x^2)## or the like. On the interval ##[0, \infty]##, the momentum operator (and hence your Q) are in deed not self-adjoint and cannot be made so. On the finite interval ##[a,b]##, the operators are self adjoint when they are defined, e.g., on the periodic functions f(a)=f(b).
Likes dextercioby
So, in QM, working in intervals, we can consider them as self-adjoint, only and if, we use an interval. However, if it was an infinite interval , they are not self adjoint. Is this your conclusion basically?
Thanks!
Printing...
thanks Dr Du!
Thanks!
First, I want to note that this discussion is specific to the momentum operator. Other operators require a discussion on it's own.
I forgot to say that the momentum operator is or can be made self-adjoint for functions defined on the range ##[-\infinity, \infinity]##, which is the most important case.
Likes SemM
Thanks, indeed the main three operators are:
position, x,
Momentum:
\begin{equation}
i\hbar \frac{d}{dx}
\end{equation}
Kinetic energy:
\begin{equation}
-\frac{\hbar^2}{2m} \frac{d^2}{dx^2}
\end{equation}
The operators Q and Q' give the solution (in ##QQ'\Psi=0##):
\begin{equation}
\end{equation}with I.C. ##\psi(0)=1## and ##\psi'(0)=0##This solution gives non-trivial values for the kinetic operator, infinite non-existing value for the momentum operators, and for the position operator, a very large value.
I am basically stuck with this state, and can't really do anything with it to give sound physical answers, or I can try to alter the initial conditions, but that does not change this state much, and the problematic terms remain.
I forgot to say that the momentum operator is or can be made self-adjoint for functions defined on the range ##[-\infinity, \infinity], which is the most important case.
Dr Du, should this formality criterion for adjointness:
\begin{equation}
\langle \mathcal{T}\phi, \psi \rangle = \langle \phi, \mathcal{T}^{*}\psi \rangle,
\end{equation}be ONLY applied to admissible functions in Hilbert space in order to tell if T is adjoint of not?
Thanks!
When do you call a function admissible?
When it is :
1. Square integrable
2. Continuous everywhere
3. Single-valued
4. Infinitely differentiable
This is not sufficient. Confer to the section 3 of the article by Bonnet for a counterexample and to the beginning of chapter 4 for a general definition of a self-adjoint operator.
Thanks. In QM, these are known as the four main properties of admissible of a wavefunction. I will look at this chapter you mention, and get back to you!
Thanks!
SemM said:
In QM, these are known as the fundamental prescriptions of a wavefunction.
Who says so? Even the eigenfunctions of the hydrogen atom are not even differentiable at the origin. Even discontinuous wavefunctions appear in physical applications.
Likes dextercioby and SemM
It is given in the book Molecular Quantum Mechanics, Friedman Atkins. But let me scan that page and make sure I am not saying anything wrong. http://www.fjordforsk.no/scan_MWM.pdf.
In any case, your point, which is intriguing, makes my question even more difficult to answer (and to pose). I will go through your article suggestion tomorrow.Thanks
Atkins, ok...
Likes dextercioby
DrDu said:
Atkins, ok...
Dr Du,on p 5 in the arxiv article you posted, the authors seem to cancel out the momentum operator by some non-shown operation:
\begin{equation}
-i\hbar \int_0^L dx\frac{d}{dx}[\overline {\psi(x)} \phi(x)] = -i\hbar [\overline {\psi(L)} \phi(L) - \hat {\psi(0)} \phi(0)
\end{equation}
Is that correct? Where does the d/dx term go?
Thanks
(why are some putting the integral dx in front of the expression, and not as correctly done, at the end (far right)?)
I am not sure here this is so c'mon. I would have written first as:
\begin{equation}
-i\hbar \int_0^L \frac{d}{dx}[\overline {\psi(x)} \phi(x)] dx
\end{equation}
the use the product rule:
\begin{equation}
-i\hbar \int_0^L u'v dx
\end{equation}
where ##u'## is ##d/dx \psi## and v is ##\phi##
Related to Non-selfadjointness and solutions
1. What is non-selfadjointness and how does it affect solutions?
Non-selfadjointness refers to a mathematical property of operators that do not satisfy the self-adjoint condition, meaning that they are not equal to their own adjoint. This can affect solutions in various ways, such as causing them to be non-unitary or non-normal.
2. What are some examples of non-selfadjoint operators?
Some examples of non-selfadjoint operators include the derivative operator, the Laplace operator, and the Schrödinger operator. These operators are commonly used in physics and engineering to describe physical systems.
3. How does non-selfadjointness impact the eigenvalue problem?
In the case of a non-selfadjoint operator, the eigenvalue problem becomes more complex. The eigenvalues may be complex numbers rather than real numbers, and the eigenvectors may not form a complete set. This can make it more difficult to find solutions to the problem.
4. Can non-selfadjoint operators have real eigenvalues?
Yes, non-selfadjoint operators can have real eigenvalues. However, they can also have complex eigenvalues, which is not possible for selfadjoint operators. In some cases, non-selfadjoint operators may have a mix of real and complex eigenvalues.
5. How is the concept of non-selfadjointness used in practical applications?
Non-selfadjoint operators are commonly used in physics and engineering to model systems that are not symmetric or Hermitian. They are also used in quantum mechanics to describe systems with time-dependent Hamiltonians. In practical applications, the study of non-selfadjointness allows for a more comprehensive understanding of physical systems and their behavior.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
