Non-standard choices for confidence intervals
In summary: If you care about it, then you should be able to justify it.In summary, the usual way to construct a confidence interval for a normally distributed random variable with unknown mean μ and known standard deviation σ is to use the standard error in the mean. However, it is possible to choose a different procedure for constructing a confidence interval, as long as it satisfies the requirement of covering μ at the desired confidence level. This can include using a one-sided interval or a non-symmetric interval. Ultimately, the choice of confidence interval construction should be based on the specific hypothesis being tested and can be justified as long as it accurately reflects the desired confidence level.
VantagePoint72
821
34
Suppose I have a normally distributed random variable with unknown mean μ and known standard deviation σ. Based on n samples of the RV, I'd like to compute an estimate of μ and a confidence interval at confidence level P%.
The usual way of doing this would be to use the standard error in the mean: if my sample mean is ##\bar{X}## and P is the total Gaussian probability between standard scores -Z and Z, then a confidence interval ##(\bar{X}- Z\sigma/\sqrt{n}, \bar{X}+ Z\sigma/\sqrt{n})## does the job. That is, if I repeat this sampling process many times then I can expect about P% of these confidence intervals to cover μ.
Am I "allowed" to choose a different procedure for constructing confidence intervals? Suppose my chosen confidence level is 30% and ##\sigma/\sqrt{n} = 1##. There is 30% (or close enough) probability that a given trial will yield a sample mean between ##\mu## and ##\mu + 0.85##, which I computed with the Gaussian CDF. Thus, the interval ##(\bar{X} - 0.85, \bar{X})## will cover μ about 30% of the times I do this n-sample experiment. So, it satisfies the requirement to be a 30% confidence interval.
Is there anything I'm missing about the definition of a confidence interval that doesn't allow me to do this construction? Obviously, the symmetric version based on the the standard error in the mean has nicer properties and does a better job of capturing the reliability of the estimator. If I don't care about that, though, am I free to make this slightly perverse construction instead?
Yes, if someone just says "I want a confidence interval" then any interval will technically do. It is often assumed however when people say confidence interval and are talking about Gaussian random variables that they are talking about the interval which is symmetric about the sample mean.
Likes 1 person
You may make a confidence interval any way you like. Usually the standard method is most useful, but if you have a good reason to due things otherwise then go ahead.
Likes 1 person
I once taught statistics, and one of the main points was one-sided vs. two-sided confidence intervals. It depends on what hypothesis you are testing.
As a scientist, it is important to understand the principles and assumptions behind statistical procedures. In this case, the standard error in the mean is based on the central limit theorem, which states that the sampling distribution of the mean will approach a normal distribution as the sample size increases. This allows for the construction of a symmetric confidence interval using the standard error in the mean.
While it is true that you can construct a confidence interval using any probability level and the corresponding standard deviation, it is important to consider the implications of this choice. In your example, a 30% confidence interval may seem appealing because it covers a larger range, but it also has a higher chance of not containing the true population mean. This means that your estimation of the mean may be less accurate and reliable.
Furthermore, the central limit theorem assumes that the underlying random variable is normally distributed. If this assumption is not met, then the confidence interval may not have the expected properties and may not accurately represent the true population mean.
In conclusion, as a scientist, it is important to carefully consider the assumptions and principles behind statistical procedures and choose the appropriate method for constructing confidence intervals. While you are free to choose a non-standard approach, it is important to understand the potential implications and limitations of doing so.
Related to Non-standard choices for confidence intervals
What are non-standard choices for confidence intervals?
Non-standard choices for confidence intervals refer to alternate methods or approaches for calculating confidence intervals, apart from the traditional methods such as the t-distribution or z-distribution. These methods may be useful when the assumptions of the traditional methods are not met or when dealing with non-normal data.
What are the advantages of using non-standard choices for confidence intervals?
Some advantages of using non-standard choices for confidence intervals include:
  • They may be more accurate for non-normal data
  • They may provide more precise estimates for small sample sizes
  • They may be more robust to outliers
  • They may provide better coverage for extreme values
What are some examples of non-standard choices for confidence intervals?
Some examples of non-standard choices for confidence intervals include:
  • Bootstrapping
  • Permutation tests
  • Non-parametric methods
  • Bayesian inference
How do I choose the appropriate non-standard confidence interval method for my data?
The choice of non-standard confidence interval method will depend on the nature of your data and the assumptions of the traditional methods. It is important to consider the distribution of your data, sample size, and any potential outliers before deciding on a method. Consulting with a statistician or performing sensitivity analyses can also help in selecting the appropriate method.
Are non-standard confidence intervals as reliable as traditional methods?
It is important to note that the reliability of non-standard confidence intervals will depend on the assumptions and the validity of the method chosen. Some non-standard methods may be more robust and reliable for certain types of data, while others may be less reliable. It is important to carefully assess the assumptions and limitations of any method before using it for confidence interval estimation.
