Non Symetrical Parabola Question
  • Thread starter Husker70
  • Tags
    Parabola
In summary, the conversation is about a problem involving a mug sliding off a bar counter and hitting the floor. The height of the counter is given as .860m and the distance traveled by the mug is 1.4m. Using the equations yf= yi + vyit-1/2gt2 and Vx = x/t, the vertical velocity is calculated to be -7.42 m/s and the horizontal velocity is calculated to be 3.34 m/s. The angle θ with the floor is then found to be tan-1(4.11/3.34). The use of these equations is discussed, as well as the importance of understanding the relationships between acceleration, time, and velocity in solving problems
Husker70
90
In a local bar , a customer slides an empty beer mug down the counter for a refill. The bartender is just deciding to go home and rethink his life. He does not see the mug, which slides off the counter and strikes the floor 1.40m from the base of the counter. If the height of the counter is .860m. (a) with what velocity did the mug leave the counter and (b) what was the direction of the mug's velocity just before it hit the floor?
(a) I got the correct answer for this by using the equation
I got 3.3 m/s
(b) I would assume that since I know the height of the bar at .860m and the distance
traveled of 1.4m
(b) The angle would make sense to me to be the tangent of opposite over adjcent but
I get 31.6 degrees, but from the book the answer is -50.9
Not sure what I'm doing wrong.
Thanks,
Kevin
I got 3.3 m/s
traveled of 1.4m
Let's see what is the title of this problem?
Does that suggest anything about what path the mug takes from bar top to floor? A triangle? Think more expansively.
What vertical velocity does it achieve? And how long to get there after leaving the bar top?
vy2/(2*a) = Height
Height = 1/at2
Now you have the vertical velocity and you can figure the horizontal velocity from Vx = x/t those are the two components when it hits. (Of course Vx is the speed it leaves the counter.)
The Root Sum of the Squares then of the two components is the total magnitude and the two components determine direction (angle θ).
That's beginning to make more sense.
I used VyF=Vyi-gt
So I get Vyf = 3.3m/s-(9.8m/s2).42s
Vyf = -.82m/s
Time I got by using Yf=Yi+Vyi(t)-1/2gt2
I then solved for t and get .42s
Not sure where to go from here.
Kevin
Scratch the last. I didn't do that right
I get Vyf to be -7.42 m/s
and Vyi to be 3.3 m/s
Are these right?
Kevin
Are these right?
Kevin
Answering these questions solves your problem.
How much time for the mug to drop to the floor?
Height = 1/2at2
.86 = 1/2 (9.8) t2
t = .419 sec
X Distance= 1.4 m
Horizontal velocity = 1.4/.419 = 3.34 m/s
Vertical velocity:
V2 = 2*a*x
V2 = 2*9.8*.86 = 4.11 m/s
Angle θ with the floor:
tan-1(4.11/3.34) = Angle θ
Thank you for the help.
I used the equation Vyf = Vyi -gt and got -7.42 m/s
Your equation makes a lot of sense but I couldn't find that one.
I'm not sure how to tell when to use which one. Is mine for a symetrical
parabola.
Is there an easy way to find the y value on a symetrical parabola. I have a total
diatance, the disatance at which I need the height, the initial velocity, and the initial
angle?
Thanks again,
Kevin
parabola.
angle?
Thanks again,
Kevin
Basically there are a couple of useful relationships, and it is likely more useful to understand these, because they allow you to partition a problem into pieces and combine what you need to solve for.
V = a* t
Acceleration times time is velocity.
V = x/t
Definition of velocity
x= 1/2 at2
the distance a body at rest falls related to time
V2 = 2ax
relates the max velocity from rest under constant acceleration.
Now using those you can add initial conditions and develop more complex models based on what the question asks. But those are always a good place to start expanding the things you know about a problem as you move toward a solution.
Taking the more general form of these equations requires you to be careful about which time and which velocity is initial and final and can sometimes create more confusion than using the simpler forms and adding the terms that are relevant.
FAQ: Non Symetrical Parabola Question
What is a non-symmetrical parabola?
A non-symmetrical parabola is a type of parabola that is not symmetrical around a specific axis or point. In other words, the left and right sides of the parabola are not mirror images of each other.
How is a non-symmetrical parabola different from a symmetrical parabola?
A symmetrical parabola has an axis of symmetry, meaning that the left and right sides are mirror images of each other. In contrast, a non-symmetrical parabola does not have an axis of symmetry and the left and right sides are not mirror images.
How can I identify a non-symmetrical parabola?
A non-symmetrical parabola will have a different shape on the left and right sides. It may also have a different vertex, or highest point, compared to a symmetrical parabola.
What real-life examples can demonstrate a non-symmetrical parabola?
A non-symmetrical parabola can be seen in many natural and man-made objects, such as bridges, arches, and satellite dishes. It can also be observed in projectile motion, such as a thrown ball with air resistance.
How is a non-symmetrical parabola useful in science?
Non-symmetrical parabolas are useful in various fields of science, including physics, engineering, and astronomy. They can be used to model and predict the behavior of objects in motion, such as projectiles or satellite orbits. They also have practical applications in designing structures that can withstand forces and stresses from different directions.
