Non-uniform magnetic fields and magnetic moment
In summary, the magnetic field produced by a dipole will always cause the dipole to drift along the line of the dipole.
Wminus
173
29
Hey all, I'm having some issues with electromagnetism here.
Let's say we have a particle with magnetic moment ##\vec{\mu} = \mu_0 \hat{x}## and magnetic field ##\vec{B(x)} = B_0 \frac{x}{a} \hat{x}## where ##\mu_0,B_0,a## are constants.
If we assume that the magnetic field ##B_0## is far, far bigger than the magnetic field produced by the dipole moment itself, we can assume that the potential ##U(x) =- \vec{\mu} \cdot \vec{B(x)}## has a corresponding conservative force field ##\vec{F} =- \nabla U(x) = \nabla ( \vec{\mu}\cdot \vec{B(x)}) = \mu_0 B_0 \frac{1}{a} \hat{x}##...
Which means that this dipole will drift along ##\hat{x} ##! How is this possible? The magnetic force can only be perpendicular to the current from the magnetic moment, it can never point in the same direction as the magnetic field that creates it!
Likes Charles Link and DuckAmuck
Interesting puzzle that you have. Perhaps the solution to your puzzle is that the magnetic field must have some y and/or z components if it is going to have an x-component that varies, because ## \nabla \cdot B=0 ##. In your function for the magnetic field ## B ##, you have a non-zero ## \nabla \cdot B ##...editing...if you make a magnetic field with a gradient such that the flux lines are coming together in the forward x-direction, the y and z components (of B) that are present do push the magnetic moment in the correct direction.
Likes Adesh and Wminus
Note that this magnetic field is unphysical, i.e., it doesn't make sense. You must have ##\vec{\nabla} \cdot \vec{B}=0##, which is one of the very fundamental laws of nature (one of Maxwell's equations).
Likes Wminus
Of course, I forgot about that divB must be 0. You guys are totally right.
Thanks!
Related to Non-uniform magnetic fields and magnetic moment
1. What is a non-uniform magnetic field?
A non-uniform magnetic field is a magnetic field that varies in strength and/or direction at different points in space. This is in contrast to a uniform magnetic field, which has a consistent strength and direction throughout.
2. How is a non-uniform magnetic field created?
A non-uniform magnetic field can be created by placing a magnet near another magnet or a piece of ferromagnetic material, or by creating an electrical current in a wire. It can also occur naturally due to the Earth's magnetic field or other astronomical bodies.
3. What is magnetic moment?
Magnetic moment is a measure of the strength and direction of a magnetic field. It is a vector quantity, meaning it has both magnitude and direction, and is usually represented by the symbol "m". The magnetic moment of a material is dependent on its mass, charge, and distance from the magnetic field.
4. How is magnetic moment related to non-uniform magnetic fields?
In a non-uniform magnetic field, the magnetic moment of a material will experience a torque, or twisting force, causing it to align with the direction of the field. This phenomenon is known as magnetization. The strength of the magnetic moment also affects the strength of the non-uniform magnetic field.
5. What are some real-world applications of non-uniform magnetic fields and magnetic moment?
Non-uniform magnetic fields and magnetic moment have various applications in everyday life, such as in magnetic resonance imaging (MRI) machines, magnetic levitation (maglev) trains, and electric motors. They are also used in scientific research and technological advancements, such as in particle accelerators and magnetic confinement fusion experiments.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
