Non-zero current from a completely filled band
In summary, the conversation discusses the concept of band theory, specifically the idea that a completely filled band will not contribute any current due to the average velocity being zero. This is justified by a plot of a parabolic bandstructure and the observation that for every electron with a positive velocity, there is another with an equal but opposite velocity. However, this symmetry may only be true to a second approximation in the bandstructure Taylor expansion, as an asymmetric bandstructure would result in a non-zero average velocity and generate a current. At absolute zero, this approximation is very accurate but small differences may occur above the top of the valence band. The conversation also mentions that this concept is applicable to different angles in the crystal and reminds the listener of the meaning
nmbr28albert
In band theory, one of the first things that is always stated is that a completely filled band, such as the valence band at low temperatures, will not contribute any current because the average velocity will equal zero. This is usually justified by showing a plot of a parabolic bandstructure around k = 0 and stating that for every electron of a certain positive velocity, there is another electron with an equal but opposite direction velocity. In general however, isn't the bandstructure symmetric only to a second approximation in the bandstructure Taylor expansion? For an asymmetric bandstructure, it seems that the average velocity will automatically be non-zero for a completely filled band and generate a current. What am I missing?
This is correct - and the symmetry may be diffreent in different angles in the crystal.
However - at absolute zero the approximation is very very good. The small differences from a quadratic profile occur above the top of the valence band.
Remember what "valance band" means?
Related to Non-zero current from a completely filled band
What is a completely filled band?
A completely filled band refers to the energy levels of electrons in a material. In a solid material, electrons occupy energy levels called bands, and a completely filled band means that all the energy levels are occupied by electrons.
Can a completely filled band have a non-zero current?
Yes, a completely filled band can have a non-zero current. This is because even though all the energy levels are occupied, the electrons can still move in response to an external electric field, creating an electric current.
How is a non-zero current created in a completely filled band?
A non-zero current in a completely filled band is created when electrons in the band are excited into higher energy levels by an external electric field. These excited electrons then move and create an electric current.
Why is a non-zero current from a completely filled band important?
A non-zero current from a completely filled band is important because it allows for the flow of electricity in a material. This is crucial for many technological applications, such as in electronic devices and power generation.
Can a completely filled band have a negative current?
Yes, a completely filled band can have a negative current. This can occur when the direction of the electric field is opposite to the direction of electron movement, resulting in a negative current. This phenomenon is known as electron flow or electron drift.
  • Atomic and Condensed Matter
  • Electrical Engineering
  • Other Physics Topics
  • Quantum Interpretations and Foundations
