Nonhomogeneous 2nd order dif question?
In summary, the general solution to the equation y''-2y'-3y = 0 is all solutions to the homogeneous equation plus the particular solution yp = Ae3t. The particular solution is yp = Ate3t and you solve for the constant A that works. The solution for the nonhomogeneous equation is y''-2y' -3y = 3e2t and you solve for the particular solution yp = At2e-t.
footballxpaul
30
y''-2y''-3y=3e^2t find the general solution
I have tried Ate^t, Ate^2, Ate^3
none have worked they all leave extra variables that don't match up.
is there another combination I could try?
You need to do this in two parts:
Find the solutions to the homogeneous equation y'' - 2y' -3y = 0.
Find a particular solution to the nonhomogeneous equation y'' - 2y' -3y = 3e2t.
Your general solution will be all solutions to the homogeneous equation plus the particular solution.
For your homogeneous equation, a basis for your solution set is {e3t, e-t}.
For a particular solution, you would ordinarily try a solution of the form yp = Ae3t, but that won't work in your nonhomogeneous equation, since this is a multiple of one of the solutions of the homogeneous equation. Instead, try yp = Ate3t, and solve for the value of A that works.
opps wrote the wrong right side down.
its y''-2y'-3y=-3te^-t
i got the e^3t and e^-t already, the right side is still tricky
I keep getting 6At(e^-t)-12A(t^2)(e^-t)=-3t(e^-t)... and that was using A(t^3)(e^-t)
or
2A(e^-t)-6At(e^-t)=-3t(e^-t) with using A(t^2)(e^-t)
or
-2A(e^t)=-3t(e^-t) using At(e^-t)
I can't see what I am doing wrong? is there an error I missed or just a method I haven't used yet?
That makes us even. I misread the function on the right side of your original DE. I thought you had it as 3e3t, but what you had originally was 3e2t, and you have changed that now to -3te-t.
What I said about the solution to the homogeneous equation is still valid. For your particular solution, try yp = At2e-t and solve for the constant A. In other words, with this function, calculate yp'' - 2yp' - 3yp = -3te-t. Group all of your terms by their power of t: t0, t, and t2. The coefficient of the t0 terms has to be zero, as does the coefficient of the t2 terms. The coefficient of the t term has to be -3.
Your general solution will be y(t) = c1e3t + c2e-t + Ate-t (with a specific value in place of A).
thats my problem everything that should cancel isn't canceling.
is what I am left with. What do I do with the 2A?
How about this: yp = Ate-t + Bt2e-t? I confess I'm a little rusty on this.
hey don't worry about it, thanks for the help. Ill try that I think that might work
FAQ: Nonhomogeneous 2nd order dif question?
What is a nonhomogeneous 2nd order differential equation?
A nonhomogeneous 2nd order differential equation is a mathematical equation that involves a function, its derivatives, and other terms that are not proportional to the function or its derivatives. In other words, the coefficients of the function and its derivatives are not constant.
How is a nonhomogeneous 2nd order differential equation different from a homogeneous one?
In a homogeneous 2nd order differential equation, all the terms are proportional to the function and its derivatives. This means that the coefficients of the function and its derivatives are constants. In contrast, a nonhomogeneous 2nd order differential equation has additional terms that are not proportional to the function or its derivatives.
What are some real-life applications of nonhomogeneous 2nd order differential equations?
Nonhomogeneous 2nd order differential equations are commonly used in physics, engineering, and other fields to model real-life phenomena such as oscillations, vibrations, and electrical circuits. They are also used in economics and finance to model growth and decay processes.
How do you solve a nonhomogeneous 2nd order differential equation?
There are various methods for solving nonhomogeneous 2nd order differential equations, such as the method of undetermined coefficients, variation of parameters, and Laplace transforms. The specific method used depends on the form of the equation and the initial conditions.
What are the initial conditions for a nonhomogeneous 2nd order differential equation?
The initial conditions for a nonhomogeneous 2nd order differential equation are the values of the function and its first and second derivatives at a specific point. These conditions are necessary to find a unique solution to the equation.
