Nonhomogeneous diff equations method of undeterined coeff.
To solve the differential equation y'' - 2y' - 3y = 3te^-t using the method of undetermined coefficients, the characteristic equation yields roots r = -1 and r = 3, leading to a complementary solution y = c1e^-t + c2e^3t. Since e^-t is already a solution, the particular solution yp must be multiplied by t, resulting in yp = (At^2 + Bt)e^-t. The discussion emphasizes the need to include polynomial terms up to the degree of the non-homogeneous part, and it clarifies that the constant term "C" is unnecessary as it cancels out. The final solution requires careful substitution to ensure accuracy in deriving yp.
iamtrojan3
Find the general solution to the diff equation using undetermined coefficients
y''-2y'-3y = 3te^-1
r^2 - 2r -3 = 0
r = -1, 3
so y = c1 e^-t + c2e^3t + yp
since e^-t already exists as a solution, i have to multiply my Yp by t to make sure i don't' end up with the same solution.
So my Yp with the unknown coeffcient should be,
yp = At^2e^-t
should it be (At^2+bt+c)e^-t instead or something else? I've done it both ways and came up with wrong answers.
I know what to do after figuring out yp, its just i can't get it right with ideas i have right now.
Any help is greatly appreciated.
Thank you!
y''-2y'-3y = 3te^-1
r^2 - 2r -3 = 0
r = -1, 3
yp = At^2e^-t
Thank you!
Yes, go with (At2 + Bt + C)e-t for your particular solution. Show us your work, and we'll figure out what's going wrong.
thanks for responding, Let's see if i have the yp's correct
yp = (At^2+Bt+c)e^-t
y'p = (2At + B)e^-t -(At^2+Bt+c)e^-t
y''p = 2Ae^-t - (2At + B)e^-t - (2At+B)e^-t -(At^2+Bt+c)e^-t
In general, it you have a power of t on the right side, you will need to try a polynomial up to that power. If your right side were te^{at} and e^{at} were not already a solution, you would try (At+ B)e^{at}. Since, here, e^{at} is a solution, multiply that by t: try (At^2+ Bt)e^{at}.
You should find that you do NOT need that "c". (Using it will just give C= 0.)
You can add those two middle terms and the last term should be "+".
y"/= 2Ae^-t- 2(2At+ B)e^-t+ (At^2+ Bt+ C)e^-t
Thanks a lot HallsofIvy, it seems i just subbed in wrong for y''p and the "c" ended up canceling out anyways.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
