Nonuniform circular motion problem.
In summary, we are given a problem where a car is moving on a circular track, with a speed that varies with time according to v = ct, and we are asked to show that the angle between the velocity vector and acceleration vector is 45 degrees at a specific time. By using the formula for centripetal acceleration and the given radius, we can determine the tangential and normal components of the acceleration. By setting these components equal to each other, we can solve for the time t when the angle between the velocity and acceleration vectors is 45 degrees. This time is given by t=√b/c, and by plugging this value into the formula for the tangential component, we can see that it is equal to the
feathermoon
A car moves on a circular track of constant radius b. If speed of car varies with time t according to v = ct, where c is a positive constant, show that the angle between the velocity vector and the acceleration vector is 45 degrees at time t=√b/c. (Hint: At this time the tangential and normal components of the acceleration are equal in magnitude.
r= ib sin(ωt) + jb cost(ωt)
r=r[itex]_{e}r[/itex]
a=v^2/b
Few ideas:
r=1/2ct^2, v=ct, a=c
At time t=√b/c, [itex]_{a}r[/itex]=[itex]_{a}t[/itex], so v^2/b=c?
I just really need a hint to get started in the right direction is all.. :[
Seems to me that if you can show that the tangential and normal components are equal, you are done. And you've just about done that.
Since they give you the answer, all you have to do is plug in the value and determine the angle with respect to the tangent.
I'm just worried because I found the tangential component, v^2/b as a hint online, and I don't know how it was arrived at.
Thanks for your reply too, once I read it I saw what you meant immediately. I guess I just needed a nudge.
At first I thought I had to find equations of motion and position for it to finish this problem, and I couldn't think of a way to go from either r in polar or Cartesian to an absolute value v=ct. So I was worrying a lot.
Compare the standard motion equation v = u + at to the expression v = ct to see what c means.
Centripetal acceleration is given by a = v2/R and you are given the size of the radius.
It is just a case of combining those formulae/expressions really.
FAQ: Nonuniform circular motion problem.
What is nonuniform circular motion?
Nonuniform circular motion is the movement of an object along a circular path with varying speed. This means that the object is not moving at a constant rate around the circle, but is instead speeding up or slowing down at different points in the motion.
What causes nonuniform circular motion?
Nonuniform circular motion can be caused by various factors, such as changes in the force acting on the object, changes in the radius of the circular path, or the presence of external forces like friction. These factors can alter the speed and direction of the object's motion, resulting in nonuniform circular motion.
How is nonuniform circular motion different from uniform circular motion?
Uniform circular motion is the movement of an object along a circular path at a constant speed. In contrast, nonuniform circular motion involves changes in speed, making it a more complex type of motion. Additionally, uniform circular motion has a constant centripetal acceleration, while nonuniform circular motion has a non-constant centripetal acceleration.
How is nonuniform circular motion calculated?
To calculate nonuniform circular motion, we can use the equations for centripetal acceleration and centripetal force, along with any other relevant equations for acceleration or velocity. These equations take into account the changes in speed and direction of the object, as well as the forces acting on it.
What are some real-life examples of nonuniform circular motion?
Some examples of nonuniform circular motion in everyday life include a car going around a curved road, a rollercoaster going through loops and turns, and a satellite orbiting the Earth. These objects experience changes in speed and direction as they move along a circular path, demonstrating nonuniform circular motion.
