Norm of a Linear Transformation .... Another question ....
In summary: R}^n## to ##T##, we get row vectors from ##\mathbb{R}^m##.In the second case, we have ##T \in \mathbb{M}(m,n,\mathbb{R})##, i.e. ##T## is represented by an ##(m \times n)-## matrix, if we apply column vectors from ##\mathbb{R}^n## to ##T##, we get column vectors from ##\mathbb{R}^m##.As long as we keep it clear what we are doing, either case is fine, but we should not mix them.
Math Amateur
MHB
3,998
48
I am reading Hugo D. Junghenn's book: "A Course in Real Analysis" ...
I am currently focused on Chapter 9: "Differentiation on ##\mathbb{R}^n##"
I need some help with the proof of Proposition 9.2.3 ...
Proposition 9.2.3 and the preceding relevant Definition 9.2.2 read as follows:
In the above proof Junghenn let's ##\mathbf{a}_i = ( a_{i1}, a_{i2}, \ ... \ ... \ , a_{in} ) ##
and then states that##T \mathbf{x} = ( \mathbf{a}_1 \cdot \mathbf{x}, \mathbf{a}_2 \cdot \mathbf{x}, \ ... \ ... \ , \mathbf{a}_n \cdot \mathbf{x} ) ## where ##\mathbf{x} = ( x_1, x_2, \ ... \ ... \ x_n )##(Note: Junghenn defines vectors in ##\mathbb{R}^n## as row vectors ... ... )Now I believe I can show ##T \mathbf{x}^t = [a_{ij} ]_{ m \times n } \mathbf{x}^t = ( \mathbf{a}_1 \cdot \mathbf{x}, \mathbf{a}_2 \cdot \mathbf{x}, \ ... \ ... \ , \mathbf{a}_n \cdot \mathbf{x} )^t ## ...
... ... as follows:##T \mathbf{x}^t = [a_{ij} ]_{ m \times n } \mathbf{x}^t = \begin{pmatrix} a_{11} & a_{12} & ... & ... & a_{1n} \\ a_{21} & a_{22} & ... & ... & a_{2n} \\ ... & ... & ... & ... & ... \\ ... & ... & ... & ... & ... \\ a_{m1} & a_{m2} & ... & ... & a_{mn} \end{pmatrix} \begin{pmatrix} x_1 \\ x_2 \\ . \\ . \\ x_n \end{pmatrix}####= \begin{pmatrix} a_{11} x_1 + a_{12} x_2 + \ ... \ ... \ + a_{1n} x_n \\ a_{21} x_1 + a_{22} x_2 + \ ... \ ... \ + a_{2n} x_n \\ ... \\ ... \\ a_{m1} x_1 + a_{m2} x_2 + \ ... \ ... \ + a_{mn} x_n \end{pmatrix}####= \begin{pmatrix} \mathbf{a}_1 \cdot \mathbf{x} \\ \mathbf{a}_2 \cdot \mathbf{x} \\ . \\ . \\ \mathbf{a}_n \cdot \mathbf{x} \end{pmatrix}##
##= ( \mathbf{a}_1 \cdot \mathbf{x}, \mathbf{a}_2 \cdot \mathbf{x}, \ ... \ ... \ , \mathbf{a}_n \cdot \mathbf{x} )^t ##
So ... I have shown##T \mathbf{x}^t = [a_{ij} ]_{ m \times n } \mathbf{x}^t = ( \mathbf{a}_1 \cdot \mathbf{x}, \mathbf{a}_2 \cdot \mathbf{x}, \ ... \ ... \ , \mathbf{a}_n \cdot \mathbf{x} )^t##...How do I reconcile or 'square' that with Junghenn's statement that##T \mathbf{x} = ( \mathbf{a}_1 \cdot \mathbf{x}, \mathbf{a}_2 \cdot \mathbf{x}, \ ... \ ... \ , \mathbf{a}_n \cdot \mathbf{x} )## where ##\mathbf{x} = ( x_1, x_2, \ ... \ ... \ x_n )##(Note: I don't think that taking the transpose of both sides works ... ?)
Hope someone can help ...
Peter
Peter
Proposition 9.2.3 does not seem to be displayed ... so I am reloading the image... as follows
Peter
What you have written is correct. The mistake is not your calculation, but the interpretation of the text.
##T \in \mathcal{L}(\mathbb{R}^n,\mathbb{R}^m)## which says nothing about basis, coordinates or matrices. If we want to write it as such, with matrices and vectors, we have to make a choice:
Case 1:
$$ x \longmapsto x \cdot T = (x_1,\ldots ,x_n) \cdot \begin{bmatrix} a_{11} &\ldots &a_{1m} \\ \vdots && \vdots \\a_{n1} & \ldots & a_{nm} \end{bmatrix} = [x \cdot \begin{bmatrix}a_{1i} \\ \vdots \\ a_{ni}\end{bmatrix}]_i= \text{ row times column }$$
Case 2: $$ x \longmapsto T \cdot x = \begin{bmatrix} a_{11} &\ldots &a_{1n} \\ \vdots && \vdots \\a_{m1} & \ldots & a_{mn} \end{bmatrix} \cdot \begin{bmatrix} x_1 \\ \vdots \\ x_n \end{bmatrix}= [(a_{i1}, \ldots , a_{in}) \cdot x ]_i= \text{ row times column }$$
In both cases we have "row times column", because this is how matrices are multiplied. It doesn't change.
In the first case, we have ##T \in \mathbb{M}(n,m,\mathbb{R})##, i.e.##T## is represented by an ##(n \times m)-## matrix, if we apply row vectors from the left on the matrix of ##T##. Some authors prefer this convention as ##\mathcal{L}(\mathbb{R}^n,\mathbb{R}^m)## has the same order as ##\mathbb{M}(n,m,\mathbb{R})\,.##
In the second case, we have ##T \in \mathbb{M}(m,n,\mathbb{R})##, i.e.##T## is represented by an ##(m \times n)-## matrix, if we apply column vectors from the right on the matrix of ##T##. This is the more common notations, although ##\mathcal{L}(\mathbb{R}^n,\mathbb{R}^m)## and ##\mathbb{M}(m,n,\mathbb{R})## reversed the order of ##n## and ##m##.
The difference is not ##T##, because we haven't changed the linear transformation at all. The difference is how we write it in matrix form, how ##T## is represented by a matrix.
Now Junghenn writes it the same way as you did: vectors on the right, but as column. He did not choose row vectors here, in fact he didn't even care about it. On the right ##x## is automatically a column, and ##x^\tau## a row. Even the notation ##\mathbf{a_i} \cdot \mathbf{x}## is row times column, so it should have been ##\mathbf{a_i}^\tau \cdot \mathbf{x}##, resp. vice versa if really written as rows with probably hundreds of ##{}^\tau## throughout the book, but as it is clear, I'd say it's a forgivable sloppiness here. As long as you write ##T\cdot x## then it better should be meant as a column, for otherwise it would have to be ##T\cdot x^\tau##. However, here's the crux: As long as I write ##Tx## I have no matrices nor vector components, only a linear transformation on an element of a vector space, so I don't have to bother, how you like to represent them in coordinates: the transposition mark isn't needed! But the proof is about coordinates, so the point at which it switches from a general concept to a coordinate based concept isn't quite clear and some transposition marks may have been forgotten.
Long story short:
  • your calculation is right
  • it's always row times column
  • we have a choice whether ##x \mapsto T(x)## is represented by "coordinates of ##T##" times "coordinates of ##x##" or by "coordinates of ##x##" times "coordinates of ##T##"
  • ##x \mapsto T \cdot x## in coordinates means ##x## is a column vector
  • strictly speaking we have a little sloppy notation as the vector product is ##a_i \cdot x := \langle a_i ,x \rangle = a_i^\tau \cdot x## with columns
  • ##(T\cdot x)^\tau = x^\tau T^\tau \neq x^\tau T##
And now I hope I haven't confused ##n,m##, left, right, row, column, ##{}^\tau,{}^{no\,\, \tau}## or anything else which can be confused. Btw. this is one reason why I don't like coordinates. Much too much business about nothingness!
Likes Math Amateur
Thanks fresh_42 ...
Most helpful ... would never have understood that from the text ...
THanks again ...
Peter
Math Amateur said:
Thanks fresh_42 ...
THanks again ...
Peter
I just saw, that I did confuse the notation a bit the way I wrote the vectors in the cases - of course o_O - and I hope I corrected it now without making even more mistakes. Now the rule for notation is: Case 1 means the vectors which are not explicitly written, i.e. only by ##"x"## are rows, and in case 2 they are columns.
Math Amateur said:
Thanks fresh_42 ...
THanks again ...
Peter
Yes, you want the product ##VW## (with ##V,W## as ## n \times 1 ##, resp. ## 1 \times k ## matrices) to be a scalar. Then you want ##VW## to be a ## 1 \times 1 ## matrix. As Fresh pointed out, matrix dimension is given by ## (m \times n )(n \times p)##= ## m \times p ##.
Likes Math Amateur
WWGD said:
A good trick is to use " Dimensionality": you want your product of matrices ( incl. vectors as ## n \times 1 ## matrices) to be a scalar. Then you want ##VW## to be a ## 1 \times 1 ## matrix.
... and ##(n \times m) \cdot (m \times p) = (n \times p)##.
Likes Math Amateur
Yes, sorry, I was about to edit that in.
Likes Math Amateur
Related to Norm of a Linear Transformation .... Another question ....
1. What is the norm of a linear transformation?
The norm of a linear transformation is a measure of its size or magnitude. It represents the maximum amount by which the transformation can stretch or scale a vector.
2. How is the norm of a linear transformation calculated?
The norm of a linear transformation can be calculated by finding the square root of the sum of the squared values of each component in the transformation's matrix.
3. What does the norm of a linear transformation tell us?
The norm of a linear transformation can provide information about the transformation's behavior, such as how much it stretches or shrinks vectors and how much it rotates or reflects them.
4. How does the norm of a linear transformation relate to other properties?
The norm of a linear transformation is closely related to other properties, such as the eigenvalues and eigenvectors of the transformation's matrix. It can also be used to calculate the determinant and trace of the matrix.
5. Can the norm of a linear transformation be negative?
No, the norm of a linear transformation is always a positive value. It represents the magnitude or size of the transformation, which cannot be negative.
  • Topology and Analysis
  • Linear and Abstract Algebra
