Normal distribution question: determine sigma
In summary, the lengths of a certain species of worm follow a normal distribution with a standard deviation of 3.84 cm.
muffymuff
The lengths of a certain species of worm follow a normal distribution. Thirty percent of the worms are at least
16cm long, and 15% of the worms are less than 10cm long. Find, to 2 decimal places, the standard deviation of
the lengths of the worms.
Mathematics news on Phys.org
Hello and welcome to MHB! :D
We normally ask that our users show their progress (work thus far or thoughts on how to begin) when posting questions. This way our helpers can see where you are stuck or may be going astray and will be able to post the best help possible without potentially making a suggestion which you have already tried, which would waste your time and that of the helper.
So, let's look at what we've been given. First, we are told:
Thirty percent of the worms are at least 16 cm long.
This tells us that the $z$-score corresponding to the $x$-value of 16 cm has an associated area of 0.2. This is because 70% of the data will be to the left of it, and so 20% is between the mean and this value. Consulting a table, we then find the $z$-score is about 0.525. And so using the equation:
\(\displaystyle z=\frac{x-\mu}{\sigma}\)
We obtain:
\(\displaystyle 0.525=\frac{16-\mu}{\sigma}\)
Now, let's look at the other information we are given:
Can you obtain a second equation, so that you have two equations and two unknowns and both can be determined?
If "15% of the worms are less than 10cm long" then we need the $z$-score associated with an area of:
\(\displaystyle .5-0.15=0.35\)
and consulting a table, we find this is about $-z=1.037$ (we negate $z$ because we are below the mean), and so we may write:
\(\displaystyle 1.037=\frac{\mu-10}{\sigma}\)
Recall we found:
Multiplying both equations by $\sigma$ and then adding, we obtain:
\(\displaystyle 1.562\sigma=6\implies \sigma\approx3.84\text{ cm}\)
FAQ: Normal distribution question: determine sigma
What is the normal distribution?
The normal distribution is a probability distribution that is symmetric and bell-shaped, with the highest frequency of values occurring in the middle and decreasing as you move away from the center. It is often used to model natural phenomena, such as heights or weights of a population.
How is the standard deviation, sigma, related to the normal distribution?
The standard deviation, sigma (σ), is a measure of how spread out the data is in a normal distribution. It measures the average distance of all the data points from the mean, or center, of the distribution.
How do you determine sigma from a normal distribution?
To determine sigma from a normal distribution, you can use the formula σ = √(variance). The variance is calculated by taking the average of the squared differences between each data point and the mean.
What is the significance of sigma in the normal distribution?
Sigma is significant in the normal distribution because it helps us understand how spread out the data is and how likely it is for a data point to fall within a certain range of values. It is also used in various statistical tests and calculations.
Can sigma ever be negative in a normal distribution?
No, sigma cannot be negative in a normal distribution. This is because the standard deviation is always a positive value, as it measures the distance of data points from the mean. A negative value would indicate that the data points are on the opposite side of the mean, which is not possible in a normal distribution.
