MHB Normal Extensions and Normal Subgroups
  • Thread starter Thread starter Kiwi1
    Normal
Kiwi1
I have answered Q1-Q3. I am unsure of my answer for Q4 and am stuck on Q5.
Notation: \(I^*=Gal(K:I)\). That is the subgroup of G=Gal(K:F) that fixes I.
Q4.
I2 is conjugate to I1.
iff \(\exists i \in G:I_2=i(I_1)\)
iff \( I^*_2=[i(I_1)]^*=iI_1^*i^{-1}\) by Q3.
iff \( I^*_2=iI_1^*i^{-1}\)
iff \( I^*_2=\phi_i(I_1^*)\) where \(\phi_i\) is the function conjugate by i.
iff \(I_1^*\) is conjugate to \(I_2^*\)
Q5. I have lots of ideas but keep going in circles.
Suppose \(I_2\) is a normal extension of \(I_1\) then
\(I_2\) is the root field of some a(x) over \(I_1\)
and we have the isomorphism \(\phi \) defined by:
\(I_2 \cong \frac{I_1[x]}{<a(x)>}\)
Now I gloss over the fact that phi is an isomorphism when I need an automorphism. I take phi to mean that I_1 and I_2 are conjugate. Therefore using Q4 \(I^*_2\) and the fixer of the RHS of my isomorphism are conjugate. That is there exists an automorphism pi such that:
\(I_2^* \cong \left(\frac{I_1[x]}{<a(x)>}\right)^*\)
again I am glossing over the difference between isomorphism and automorphism.
Now since these two fixers are conjugate I can write
there exists \(x \in I_1\) such that \(I^*_2 \cong x \left(\frac{I_1[x]}{<a(x)>}\right)^* x^{-1}\)
Now x and \(x^{-1}\) both fix the coefficients of a(x) and \(I_1^*[x]\) so:
there exists \(x \in I_1\) such that \(I^*_2 \cong \left(\frac{I_1[x]}{<a(x)>}\right)^* \)
So \(I^*_2\) is a normal subgroup of \(I^*_1\)
I know I have 'cheated' at various points but am I on the right track to finding a solution? I need to reverse the order of my argument so that this argument complements Q1.
Solved it!
Suppose \(I_2\) is a normal extension of \(I_1\). Then there exists a(x) such that:
\(I_2 \cong \frac{I_1[x]}{<a(x)>} \supseteq I_1\). Now this isomorphism fixes \(I_1\) so by Theorem (i) the isomorphism is in fact an automorphism.
So by problem 4:
\(I_2^* \cong \left(\frac{I_1[x]}{<a(x)>}\right)^* \subseteq I_1^*\) is an automorphism so:
\(I_2^* \subseteq I_1^*\) and \(I_2^* = \left(\frac{I_1[x]}{<a(x)>}\right)^*\)
but is \(I_2^*\) a NORMAL subgroup?
Let \(\pi\) be any \(\pi \in I_1^*\) then
\(\pi I_2^* \pi^{-1} = \pi \left(\frac{I_1[x]}{<a(x)>}\right)^* \pi^{-1}= \left( \pi \left(\frac{I_1[x]}{<a(x)>}\right)\right)^* \) (using problem 3)
but \(\pi\) fixes all \(I_1\) and therefore fixes the coefficients of \(I_1[x]\) and a(x), therefore:
\(\pi I_2^* \pi^{-1} = \left(\frac{I_1[x]}{<a(x)>}\right)^* = I_2^*\)
so indeed \(I_2^*\) a NORMAL subgroup of \(I_1^*\). The reverse direction follows directly from Question 1.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
