Normal force in rotational motion
In summary, the normal force in rotational motion is affected by the location of the axis of rotation. If the axis is at the centre of mass, the normal force remains equal to +mg. However, if the axis is at the rim, the normal force will vary as the disk rotates due to the acceleration of the centre of mass. At its lowest point, the normal force will exceed +mg due to the rotation of the disk. This force can be calculated by balancing the radial component of the gravitational force and the centripetal force. For small perturbations, the normal force can be approximated using SHM, but for larger perturbations, the circular error must be taken into account.
cavis
Hi there,
I've got a conceptual question about the normal force as applied to rotational motion. Suppose you have an object like a uniform disk. If the disk were set up so that its axis of rotation were about its centre of mass, it would just sit there and the normal force would be equal to +mg.
What happens if the disk is instead hinged so that its axis of rotation is at its rim (see attached image)? Here if the disk is held horizontally and then released, it'll experience an angular acceleration and start to rotate. Ultimately were it frictionless, it would oscillate back and forth.
My question is what happens to the normal force in this situation? Does it remain equal to mg since ultimately the hinge isn't accelerating? Or, does the normal force decrease since the centre of mass of the disk is accelerating downwards. Or am I totally confused?
Thanks!
Chris.
The normal force is the force due to axis rod which supports the disk? If so,
this will be initially lower than mg, since the disk accelerates downwards. Continually, as the disk rotates and falls down, the acceleration decreases and so the normal force increases. When the disk is at its lowest position, the normal force will be at its maximum value, which is greater than mg (due to rotation of the disk).
Thanks, Jano. This helps. Just to clarify, if the disk we just suspended at its lowest point without rotating, the hinge force would be equal to mg? But, since it's rotating and a radially directed centripetal force is required, the hinge force must exceed mg? Do I have that correct? If I interpret your response correctly, then, the force at the hinge will have a magnitude that varies in quite a complicated manner as the disk undergoes its rotational motion?
Thanks for your help, again.
Chris.
Not too complicated: just the force needed to balance the radial component of the gravitational force, + centripetal force. What will make it complicated for large perturbations is the 'circular error', i.e. the extent to which it is not SHM. For small perturbations, taking the SHM approximation, the hinge force will be something like A-Bθ2.
That's right. Exact variation can be found as a function of the angle, but probably it won't be the simplest function possible.
Related to Normal force in rotational motion
1. What is normal force in rotational motion?
Normal force in rotational motion is the force that an object exerts perpendicular to its surface when in contact with another object. It is always directed away from the surface of contact and is a result of the interaction between the two objects.
2. How is normal force related to rotational motion?
In rotational motion, normal force is responsible for creating the necessary centripetal force that keeps an object moving in a circular path. It is also important in maintaining the stability and balance of an object in motion.
3. How is normal force calculated in rotational motion?
Normal force in rotational motion is calculated using the equation Fn = mω²r, where Fn is the normal force, m is the mass of the object, ω is the angular velocity, and r is the distance between the object and the center of rotation.
4. What happens to normal force in rotational motion when the angular velocity increases?
When the angular velocity increases, the normal force also increases in order to maintain the necessary centripetal force. This can be seen in situations such as a car rounding a curve at high speeds, where the normal force increases to prevent the car from sliding off the road.
5. Can normal force in rotational motion be negative?
Yes, normal force in rotational motion can be negative. This occurs when the object is in a state of free fall or when the centripetal force is not enough to keep the object in motion. In these cases, the normal force would be directed towards the center of rotation instead of away from it.
