Normal modes in a acoustic chamber
In summary, the Resonance chamber was used to investigate different variables such as the material the pipe is made of, the amount of damping, and the effect it has on the resonant frequencies. The Resonance chamber was found to be best at recording the resonant frequencies of the material with the most amount of absorption. The Resonance chamber was also found to be helpful in investigating the effects of damping on resonant frequencies. However, the resonant frequencies were found to change slightly when the amount of damping was changed. Additionally, the resonant frequencies of the material were found to be related to the aborbtion coefficent of the material. However, the resonant frequencies were not found to be related to the length
Myrddin
25
Have a project to do on an acoustic resonance chamber, a loudspeaker attached to a perspex box with a copper pipe, there was a microppohne inside the chamber connected to oscillloscope. We investigating a few variables in most detail was route [1]
[1]damping by chainging materials in the chamber carpet foam etc.
[2] using a birch plywood as the ceiling and seeeing the effects
[3] changing pipe size
in [1] the resonant frequencies were recorded for different materials, then reonance curve plotted to find quality factor, reverberation time, abosorption coefficent, we found the carpet was best absorber. But the resonance posistions changed slight WHY is this? can't find any detail explination anywhere, is it simply due to the change in dimensions caused by introducing the damping material?
[2] Found the birch plywood had quich high aborbtion coefficent, have deduced this is beceause the energy was transferred out of the system by causing the plywood to vibrate thus transferring sound outside? is this the principle on some musical instruments work
[3] This is the trickiest bit that i don't understand and our results are very inconsistent. Seem to find that the changing pipe doesn't add or removed and resonant frequency but seems to change the amplitude. Such that the smaller pipe has a section of frequencies of very high amplitude resonance, and the longer pipe produces the same resosnances but a different section of the resonance have very high amplitude?
Any help/explination/ guidance will be grateful! otherwise will end up doing this on xmas eve
still not done !
Have worked on part 1) and 2) hopefully enough for the project, going to do detail of how our results of damping are shown in use of special materials in theatres and qudiotoriums etc, and talk about musical instruments for 2).
Any help with 3) would still be grateful as the material I am finding is basic nodes in a pipe are similar to that on a string etc but can't find anything for the explination of pipes of different length have difference sections of high amplitude resonances : /
Seem as though there's no acousticians in the house !
I would first like to commend you on your project and the effort you are putting into investigating different variables in the acoustic resonance chamber. It is always important to understand the underlying principles and variables in any scientific experiment.
Regarding the first variable you investigated, changing materials in the chamber, it is expected that the resonant frequencies would change slightly due to the change in dimensions caused by the introduction of the damping material. This is because the resonant frequencies are dependent on the size and shape of the chamber. The absorption coefficient also depends on the material properties, so it is not surprising that the carpet was the best absorber in your experiment.
For your second variable, using birch plywood as the ceiling, your deduction is correct. The plywood absorbs sound energy by vibrating and transferring it outside the system. This is similar to how some musical instruments work, where the vibrations of the instrument's body amplify and project the sound.
The third variable, changing pipe size, can be tricky to understand. It is possible that the change in pipe size does not directly add or remove any resonant frequencies, but it can affect the amplitude of the resonant frequencies. This is because the pipe acts as a resonator, amplifying certain frequencies. The smaller pipe may have a different resonant frequency range than the longer pipe, which could explain the difference in amplitude for the resonances you observed.
In conclusion, it is important to consider all variables and their effects when conducting experiments in an acoustic resonance chamber. The dimensions, materials, and even the shape of the chamber can all affect the resonant frequencies and amplitudes. I suggest further research and experimentation to better understand the results you observed. Good luck with your project!
Related to Normal modes in a acoustic chamber
1. What are normal modes in an acoustic chamber?
Normal modes in an acoustic chamber refer to the different patterns or modes of vibration that can occur within the chamber. These vibrations are caused by sound waves bouncing off the walls, ceiling, and floor of the chamber and creating standing waves.
2. How do normal modes affect the acoustics of a chamber?
Normal modes have a significant impact on the acoustics of a chamber. They can cause certain frequencies to be amplified or attenuated, resulting in uneven sound distribution and potential acoustic issues such as echo or resonance.
3. How can normal modes be controlled or minimized in an acoustic chamber?
To control or minimize normal modes in an acoustic chamber, various acoustic treatments can be applied to the walls, ceiling, and floor. These treatments can include sound-absorbing materials, diffusers, and bass traps, which help to reduce the strength of standing waves and create a more balanced acoustic environment.
4. Are there any mathematical equations or models for predicting normal modes in an acoustic chamber?
Yes, there are mathematical equations and models that can be used to predict the normal modes in an acoustic chamber. These models take into account the dimensions and materials of the chamber, as well as the frequency of the sound waves being produced.
5. How do normal modes differ in a large versus a small acoustic chamber?
The normal modes in a large acoustic chamber are typically lower in frequency and have longer wavelengths compared to those in a small chamber. Additionally, the number of normal modes in a large chamber is typically higher, leading to more complex acoustic behavior.
