Normal modes of a rectangular elastic membrane
In summary: I'm not sure how to proceed from here.Use the trig identity ##\cos(\alpha + \beta) = \cos(\alpha)\cos(\beta)-\sin (\alpha) \sin(\beta)## to help you write ##G\cos(\omega t) + H\sin(\omega t)## in the form ##A\cos(\omega t + \phi)##.Use the trig identity ##\cos(\alpha + \beta) = \cos(\alpha)\cos(\beta)-\sin (\alpha) \sin(\beta)## to help you write ##G\cos(\omega t) + H\sin(\omega t)## in the form
ContagiousKnowledge
Consider a thin elastic sheet that spreads from x = 0 to x = x' and y = 0 to y = y' where the sheet's transverse displacement ψ is 0 x=0, y=0, x=x', and y=y'. at Demonstrate that the amplitudes and phase angles in the normal mode expansion are given by $$ A_{i,j} = \sqrt {G^{2}{}_{i,j} + H^{2}{}_{i,j}} $$
and
$$ tan^{-1}(\frac {H_{i,j}} {G_{i,j}}) $$
Confirm that
$$ G_{i,j} = \frac {4} {x'y'} \int_{0}^{y'} \int_{0}^{x'} \psi(x, y, 0) sin(\frac {\pi i} {x'}x)sin(\frac {\pi j} {y'}y) dx dy $$
$$ H_{i,j} = \frac {4} {x'y' \omega_{i,j}} \int_{0}^{y'} \int_{0}^{x'} \frac {\partial \psi(x, y, 0)} {\partial t} sin(\frac {\pi i} {x'}x)sin(\frac {\pi j} {y'}y) dx dy $$
$$ \frac {\partial^2 \psi} {\partial t^2} = v^2( \frac {\partial^2 \psi} {\partial x^2} + \frac {\partial^2 \psi} {\partial y^2} ) $$
Let's try inputting a solution of the following form into the two-dimensional wave equation: $$ \psi(x, y, t) = X(x)Y(y)T(t) $$
Solving using the method of separation of variables yields
$$ \frac {v^2} {X(x)} \frac {\partial^2 X(x)} {\partial x^2} + \frac {v^2} {Y(y)} \frac {\partial^2 Y(y)} {\partial y^2} =\frac {1} {T(t)} \frac {\partial^2 T(t)} {\partial t^2} =-\omega^2$$
$$ T(t) = A_{i,j}cos(\omega_{i,j} t) + B_{i,j}sin(\omega_{i,j} t)$$
$$ X(x) =Ccos(k_{x} t) + D_{i,j}sin(k_{x} t) $$
$$ Y(y) =Ecos(k_{y} t) + Fsin(k_{y} t) $$
where
$$ \frac {1} {X(x)} \frac {\partial^2 X(x)} {\partial x^2} = -k_{x}^2 $$
$$ \frac {1} {Y(y)} \frac {\partial^2 Y(y)} {\partial y^2} = -k_{y}^2 $$
The boundary conditions ψ(0, y, t) = ψ(x, 0, t) = 0 tells us that C=E=0.
the conditions ψ(x', y, t) = ψ(x, y', t) = 0 tell us that
$$ k_{x} = \frac {\pi i} {x'}, $$
$$ k_{y} = \frac {\pi j} {y'} $$
$$ \omega = \pi v \sqrt {\frac{i^{2}}{x'^{2}}+\frac{j^{2}}{y'^{2}}} $$
From this, we can ascertain the particular solution for given i and j
$$ \psi(x, y, t) = [G_{i,j}cos(\omega_{i,j} t) + H_{i,j}sin(\omega_{i,j} t)]sin(\frac {\pi i} {x'}x)sin(\frac {\pi j} {y'}y)$$
$$ G_{i,j}=A_{i,j}D_{i}F_{j}, H_{i,j}=B_{i,j}D_{i}F_{j} $$
Since the wave equation is linear, the general solution is a superposition of all normal modes.
$$ \psi(x, y, t) = \Sigma_{i=0,\infty} \Sigma_{j=0,\infty}[G_{i,j}cos(\omega_{i,j} t) + H_{i,j}sin(\omega_{i,j} t)]sin(\frac {\pi i} {x'}x)sin(\frac {\pi j} {y'}y) $$
$$ \psi(x, y, 0) = \Sigma_{i=0,\infty} \Sigma_{j=0,\infty}G_{i,j}sin(\frac {\pi i} {x'}x)sin(\frac {\pi j} {y'}y) $$
$$ \frac {\partial \psi(x, y, 0)} {\partial t} = \Sigma_{i=0,\infty} \Sigma_{j=0,\infty} \omega_{i,j} H_{i,j}sin(\frac {\pi i} {x'}x)sin(\frac {\pi j} {y'}y) $$
I've omitted some math because entering it with latex was taking a long time, but I have arrived at the correct expressions for G and H. I don't know how to proceed from here.
ContagiousKnowledge said:
$$ T(t) = A_{i,j}cos(\omega_{i,j} t) + B_{i,j}cos(\omega_{i,j} t)$$
Did you mean to use a cosine function in both terms?
An expression of the form ##G\cos \omega t + H\sin \omega t## may be expressed in terms of an amplitude ##A## and a phase angle ##\phi## as ##A \cos (\omega t + \phi)## or ##A \cos (\omega t - \phi)##. The choice of + or - in front of ##\phi## is a matter of convention. ( I don't know which convention you use in your course.) Can you derive expressions for ##A## and ##\phi## in terms of ##G## and ##H##?
No, I did not intend to use cosine for both terms.
I am accustomed to using -ϕ to indicate a wave moving in the positive direction and +ϕ for a wave moving in the negative direction.
As for deriving expressions for the amplitude and phase angle for the normal modes in terms of G and H, could you elaborate a little more on what you are asking of me? I know that it is possible to derive such expressions because it is stated in the problem; I assume your question was rhetorical. My ultimate goal is to figure out how one would derive these expressions.
OK
I've been playing with this algebra for a while and I'm afraid I don't see how to rewrite the expression in that form.
$$ Gcos( \omega t - \phi) + Hsin( \omega t - \phi) = G[cos( \omega t)cos( \phi ) + sin( \omega t)sin( \phi )] + H[sin( \omega t)cos( \phi ) - cos( \omega t )sin( \phi )] $$
Which can be rewritten as
$$ [Gcos( \phi ) - Hsin( \phi )]cos( \omega t) + [Gsin( \phi ) + Hcos( \phi)]sin( \omega t) $$
although this doesn't seem particularly useful. I have tried rearranging the expression in numerous ways. Presumably, we will have to square both sides of the equation eventually since H and G are both squared in the given expression for amplitude. I tried squaring the expression in its current form, but the result is fairly convoluted and doesn't appear to simplify to anything useful.
I apologize if I'm missing something simple.
Apply the trig identity to ##A\cos(\omega t + \phi)## and compare with ##G\cos \omega t + H\sin \omega t##.
@TSny Again, I've been rearranging trig functions for a long time, but it hasn't been very productive.
$$ Acos(\omega t + \phi) = A[cos(\omega t)cos(\phi) - sin(\omega t)sin(\phi)] = Gcos(\omega t) + Hsin(\omega t) $$
$$ A = \frac{Gcos(\omega t) + Hsin(\omega t)}{cos(\omega t)cos(\phi) - sin(\omega t)sin(\phi)} $$
We could try setting ϕ to different values to generate more expressions
$$ \phi = 0 $$ $$ A = G + Htan(\omega t) $$
$$ \phi = \frac{\pi}{2} $$ $$ -A = Gtan(\omega t) + H $$
Although, we could have derived this without using the cos(a + b) identity, and this doesn't seem to bring me closer to the answer regardless.
Among other attempts, I've also tried substituting the given expression for A directly hoping to find something that clearly resembles Gcos(ωt)+Hsin(ωt), but to no avail.
$$ Acos(\omega t + \phi) = \sqrt{G^{2} + H^{2}}[cos(\omega t)cos(\phi) - sin(\omega t)sin(\phi)] = \sqrt{(G^{2} + H^{2})(cos^{2}(\omega t)cos^{2}(\phi) - 2cos(\omega t)cos(\phi)sin(\omega t)sin(\phi) + sin^{2}(\omega t)sin^{2}(\phi))}$$
Look at the second equality. What is the coefficient of ##\cos \omega t## on each side of this equality? What is the coefficient of ##\sin \omega t## on each side of this equality?
@TSny
$$ Acos(\phi)cos(\omega t) = Gcos(\omega t) $$ $$ G = Acos(\phi) $$
$$ -Asin(\omega t)sin(\phi) = H sin(\omega t) $$ $$ H = -Asin(\phi) $$
$$ \sqrt{G^{2} + H^{2}} = \sqrt{A^{2}cos^{2}(\phi) + A^{2}sin^{2}(\phi)} = A $$
Okay, I should have seen that; thank you for your help. Now, as for ϕ
$$ \frac{H}{G} = \frac{-sin(\phi)}{cos(\phi)}$$
I think ϕ should have been negative, which is the default since a negative ϕ conventionally indicates a wave moving in the positive direction. This would get red of the negative sign in the final expression, and the resultant expression would prove that
$$ arctan(\frac{H}{G}) = \phi $$
This question was much simpler than I thought. Thank you for your help.
OK. Good.
I've never heard of choosing the sign of ##\phi## based on the direction of travel of a wave. But, go with the convention for your course. In this problem, you are dealing with standing waves (normal modes) rather than traveling waves. ##\phi## is just a phase angle associated with the time dependence of the standing wave.
Related to Normal modes of a rectangular elastic membrane
1. What are normal modes of a rectangular elastic membrane?
Normal modes of a rectangular elastic membrane refer to the different patterns of vibration that the membrane can exhibit when it is subjected to a force or disturbance. These modes are characterized by a specific frequency and shape of vibration.
2. How are normal modes of a rectangular elastic membrane determined?
The normal modes of a rectangular elastic membrane can be determined by solving the equations of motion for the membrane, taking into account its physical properties such as tension, density, and geometry. This results in a set of eigenvalue equations, which can be solved to determine the frequencies and corresponding mode shapes of the membrane.
3. What is the significance of normal modes of a rectangular elastic membrane?
The normal modes of a rectangular elastic membrane have practical applications in engineering and science. They can be used to analyze and predict the behavior of structures and materials that exhibit similar vibration patterns, such as drums, plates, and membranes. They also provide insight into the fundamental properties of elastic materials.
4. Can the normal modes of a rectangular elastic membrane be observed?
Yes, the normal modes of a rectangular elastic membrane can be observed using various experimental techniques, such as strobe lighting or high-speed cameras. These techniques allow us to visualize the different modes of vibration and study their properties.
5. How do the normal modes of a rectangular elastic membrane affect its resonance?
The normal modes of a rectangular elastic membrane play a crucial role in determining its resonance behavior. When the frequency of an external force matches one of the natural frequencies of the membrane, it will vibrate with a larger amplitude, resulting in resonance. The mode shape also affects the distribution of energy within the membrane and can influence its response to external forces.
