Normal series and composition series
In summary: Basically, to find them all, all you need to do is find every subgroup of $D_4$ of index 2, and every subgroup of those subgroups of index 2. There are 3 subgroups of index 2, one is cyclic, and two are isomorphic to $V$, the Klein 4-group. There is only one composition series for the cyclic subgroup of order 2, which is $1\leq \langle a\rangle \leq D_4$. For the two subgroups isomorphic to $V$, we can have the following composition series: $$1\leq \langle s^2\rangle \leq \langle s^2, a\rangle
mathmari
MHB
5,049
Hey! :eek:
I want to find a normal series of $D_4$ and all the composition series for $D_4$.
I have done the following:
$D_4=\langle a , s\mid s^4=1=a^2, asa=s^{-1}\rangle$
A subgroup of $D_4$ is $\langle s\rangle=\{s, s^2, s^3, s^4=1\}$, that is normal in $D_4$, since $[D_4:\langle s\rangle]=\frac{|D_4|}{|\langle s\rangle|}=2$.
Therefore a normal series of $D_4$ is $$D_4\geq \langle s\rangle \geq 1$$ A composition series for $D_4$ is $$1=S_0\leq S_1\leq S_2\leq \dots \leq S_k=D_4$$ where $S_i\trianglelefteq S_{i+1}$ and $S_{i+1}/S_i$ is a simple group.
A subgroup of $D_4$ is $\langle s\rangle$. We have that $|D_4/\langle s\rangle |=\frac{|D_4|}{\langle s\rangle |}=2$.
Since the order of the quotient is the prime $2$, the group $D_4/\langle s\rangle$ is simple, and $\langle s\rangle \trianglelefteq D_4$.
A subgroup of $\langle s\rangle$ is $\langle s^2\rangle=\{s^2, s^4=1\}$. We have that $|\langle s\rangle/\langle s^2\rangle |=\frac{|\langle s\rangle |}{\langle s^2\rangle |}=2$.
Since the order of the quotient is the prime $2$, the group $\langle s\rangle /\langle s^2\rangle$ is simple, and $\langle s^2\rangle \trianglelefteq \langle s\rangle$.
We have that $|\langle s^2\rangle /1|=|\langle s^2\rangle |=2$, so $\langle s^2\rangle$ is simple and $1 \trianglelefteq \langle s^2\rangle$.
Therefore, a composition series for $D_4$ is $$1\leq \langle s^2\rangle \leq \langle s\rangle \leq D_4$$ right? (Wondering)
But how can we find all the composition series? (Wondering)
mathmari said:
Hey! :eek:
8 is a power of two, that should be a BIG clue, right there.
So find the "other" subgroups of order 4 (there are two more).
What information do we get from that? (Wondering)
The other two subgroups of order $4$ are $\langle a, s^2\rangle=\{a, s^2, as^2, 1\}$ and $\langle s^2, as\rangle=\{s^2, as, as^3, 1\}$, right? (Wondering)
The only ways we can go down is by "halfsies". (All the factor groups in a composition series will have order 2).
Mhm...so each of these looks promising as the start of a composition series...do you think you can take them "all the way"?
When we had a group of order a power of $3$, all the factor groups in a composition series would have order $3$, right? (Wondering)
In post #1 all the factor groups in $1\leq \langle s^2\rangle \leq \langle s\rangle \leq D_4$ have order $2$, right? (Wondering)
Why isn't this a composition series? (Wondering)
What do you mean? (Wondering)
Who said it wasn't?
I mean keep going.
So are the following some the composition series?
$$1\leq \langle s^2\rangle \leq \langle s\rangle \leq D_4 \\ 1\leq \langle s^2\rangle \leq \langle s^2, a\rangle \leq D_4 \\ 1\leq \langle s^2\rangle \leq \langle s^2, as\rangle \leq D_4 $$
Other subgroups of order $2$ are $\langle a\rangle=\{a, a^2=1\}$, $\langle as^2\rangle=\{as^2, 1\}$, $\langle as^3\rangle=\{as^3, 1\}$, $\langle as\rangle=\{as, 1\}$.
Therefore, other composition series are the following:
$$1\leq \langle a\rangle \leq \langle s^2, a\rangle \leq D_4 \\ 1\leq \langle as^2\rangle \leq \langle s^2, a\rangle \leq D_4 \\ 1\leq \langle as^3\rangle \leq \langle s^2, as\rangle \leq D_4 \\ 1\leq \langle as\rangle \leq \langle s^2, as\rangle \leq D_4$$
right? (Wondering)
How do we know if we have found all composition series? (Wondering)
right? (Wondering)
There is only one composition series for the cyclic subgroup of index 2.
Each of the other subgroups isomorphic to $V$ yield 3 composition series each (one for each element of order 2 they contain).
That gives 7 in all. You've listed 7, so those are them.
Great! Thank you very much! (Happy)
FAQ: Normal series and composition series
What is a normal series?
A normal series is a sequence of subgroups of a group, where each subgroup is normal in the next subgroup and the last subgroup is the whole group. This means that each subgroup is a normal subgroup of the previous subgroup, and the last subgroup is a normal subgroup of the whole group.
What is a composition series?
A composition series is a normal series where each factor group is simple, meaning it has no nontrivial normal subgroups. In other words, a composition series breaks down a group into its simplest components.
How are normal series and composition series related?
Normal series and composition series are related in that a composition series is a special type of normal series, where each factor group is simple. Every group has a composition series, but not every group has a normal series that is also a composition series.
What is the difference between a normal series and a composition series?
The main difference between a normal series and a composition series is that a composition series has factor groups that are simple, while a normal series does not necessarily have this requirement. Additionally, a composition series provides a more detailed breakdown of a group's structure, while a normal series simply shows how subgroups are related.
Why are normal series and composition series important?
Normal series and composition series are important because they help us understand the structure of a group and its subgroups. They also provide a way to classify groups and determine their properties. Additionally, composition series are useful in studying factor groups and understanding the relationship between different groups.
