Normal subgroups, quotient groups
In summary: Therefore, P is a group homomorphism. In summary, the conversation discusses a group G and a subgroup K, and a map P from G to Z*p x Z*p defined by P(G) = (a, c). The task is to prove that P is a group homomorphism. The method suggested is to show that P(G1)P(G2) = P(G1G2) for any G1 and G2 in G, which can be done by using the definition of P and the properties of matrix multiplication. The attempt at a solution is deemed correct.
kimberu
Let G be the group {[tex]
\begin{bmatrix}{a}&{b}\\{0}&{c}\end{bmatrix}
[/tex] | a, b, c are in [tex]Z_p[/tex] with p a prime}
Then let K = {[tex]
\begin{bmatrix}{1}&{b}\\{0}&{1}\end{bmatrix}
[/tex] | b in [tex]Z_p[/tex]}
The map P: G --> Z*p x Z*p is defined by
P( [tex]
[/tex] ) = (a, c)
prove P is a group homomorphism.
I thought it would suffice to show that P(G1)P(G2)=P(G1G2) for some G1 G2 in G, and that this is true since (a1,c1)(a2,c2)=(a1a2,c1c2) -- Is this correct
Thank you so much for any help!
</p>Homework Equations P(G1)P(G2)=P(G1G2) The Attempt at a Solution Yes, this is correct. To prove that P is a homomorphism, you must show that P(G1)P(G2)=P(G1G2) for any G1 and G2 in G. Since P is defined by P( \begin{bmatrix}{a}&{b}\\{0}&{c}\end{bmatrix} ) = (a, c), this means that P(G1)P(G2)=(a1,c1)(a2,c2)=(a1a2,c1c2). Since G1G2= \begin{bmatrix}{a1a2}&{b1+c1b2}\\{0}&{c1c2}\end{bmatrix}, it follows that P(G1G2)=(a1a2,c1c2), which is exactly what we wanted to show.
Related to Normal subgroups, quotient groups
1. What is a normal subgroup?
A normal subgroup is a subgroup of a group where every element of the original group commutes with every element of the subgroup. In other words, if we take an element from the original group and an element from the subgroup, their product will be in the subgroup. This property is denoted as N ◁ G, where N is the normal subgroup and G is the original group.
2. How can we determine if a subgroup is normal?
There are a few ways to determine if a subgroup is normal. One way is to check if the left and right cosets of the subgroup are equal. Another way is to check if the subgroup is the kernel of a homomorphism. Additionally, if the subgroup is of index 2, it is always normal.
3. What is a quotient group?
A quotient group, also known as a factor group, is a group that is formed by the elements of a normal subgroup and their respective cosets. Essentially, it is the group of all possible quotients of the elements of the original group by the elements of the normal subgroup.
4. How do we calculate the order of a quotient group?
The order of a quotient group is calculated by taking the order of the original group and dividing it by the order of the normal subgroup. This can also be represented as |G/N| = |G|/|N|, where G is the original group and N is the normal subgroup.
5. What are some applications of normal subgroups and quotient groups?
Normal subgroups and quotient groups have many applications in abstract algebra, particularly in group theory. They are used to study the structure and properties of groups, and also have applications in other areas of mathematics such as number theory and geometry. Additionally, they have practical applications in cryptography and coding theory.
  • Topology and Analysis
  • Math POTW for University Students
  • Linear and Abstract Algebra
