Normal subgroups (Sylow Theorem)
In summary: If G is a normal group, then every coset of G is automatically a subgroup. This is because if we multiply out the group multiplication on G, we get a product that is a group again, and every coset is automatically a term in this product. The same goes for any other group operation. So cosets are a way of representing groups.Suppose we want to represent the group G on the cosets of the subgroup $P$. To do this we need to find a homomorphism from G to the cosets of P. But this is not so easy. We need to find a homomorphism that preserves the order of the cosets. But this is not so easy either. We
mathgirl1
23
Let G be a group of order [tex]pm[/tex] where p is a prime and p > m. Suppose H is a subgroup of order p. Show that H is normal in G.
There is a very similar problem
Let |G| = [tex]p^nm[/tex] where p is a prime and [tex]n \ge 1, p > m[/tex]. Show that the Sylow p-subgroup of G is normal in G.
Proof:
Let [tex]n_p[/tex] be the number of Sylow p-subgroups of G. By the 3-d Sylow Subgroup Theorem we know that [tex]n_p \mid m[/tex] and that [tex]n_p \equiv 1 (mod p)[/tex]. Since m < p and [tex]n_p \mid m[/tex], it follows that [tex]1 \le n_p \le m < p[/tex]. Since we also know that [tex]n_p \equiv 1 (mod p)[/tex], it follows that [tex]n_p=1[/tex]. Let P be a Sylow p-subgroup of G. Since for every [tex]g \in G[/tex], [tex]g^{-1}Pg[/tex] is also a Sylow p-subgroup of G and since [tex]n_p=1[/tex], it follows that for every [tex]g \in G[/tex] that [tex]g^{-1}Pg=P[/tex]. Hence P is normal in G, as claimed.
So this is the same problem that I need to solve with n=1. Is there a way to solve this without Sylow Theorems or Sylow subgroups? We barely covered that so not sure we can use it to prove this problem.
Also, why is [tex]g^{-1}Pg[/tex] also a Sylow p-subgroup of G since P is?
Any help is appreciated. I would like to solve this problem without Sylow theorems but not sure where to start cause I am already stuck in this thinking.
Thanks!
You have shown above that there is exactly one subgroup of order $p$. Let us call it $P$. Furthermore, this is a Sylow $p$-subgroup because $p$ is the largest power of $p$ which divides $|G|=pm$. Thus, by the third theorem all Sylow $p$-subgroups are conjugate. Consider $gPg^{-1}$. Show that this subgroup has order $p$, and so, it is a Sylow $p$-subgroup. But since there is only one such subgroup it follows that $gPg^{-1} = P$. Since this is true for all $p$ we conclude that $P$ is invariant under conjugation, so it is a normal subgroup.
Hi,
You asked for a different proof that doesn't use the Sylow theorems. Here is one. The idea of representing (finding a homomorphism) a group G on the cosets of a subgroup is worth remembering.
FAQ: Normal subgroups (Sylow Theorem)
What is a normal subgroup?
A normal subgroup is a subgroup of a group that is invariant under conjugation by elements of the larger group. In simpler terms, it is a subset of a group that remains unchanged when its elements are multiplied or divided by elements of the larger group.
What is the significance of normal subgroups in group theory?
Normal subgroups are significant because they allow us to define quotient groups, which are an essential concept in group theory. They also help us understand the structure of a group and its subgroups.
How is the Sylow Theorem related to normal subgroups?
The Sylow Theorem is a group theory theorem that helps us determine the number of subgroups of a given order in a finite group. Normal subgroups play a crucial role in the proof of this theorem as they are used to simplify the structure of a group.
Can a group have more than one normal subgroup?
Yes, a group can have multiple normal subgroups. In fact, every group has at least two normal subgroups - the trivial subgroup {e} and the group itself. It is also possible for a group to have infinitely many normal subgroups.
How do you check if a subgroup is normal?
To check if a subgroup is normal, you can use the definition of normal subgroups and see if it satisfies the necessary conditions. Alternatively, you can use the fact that all subgroups of an abelian group are normal, or use the conjugacy test, which states that a subgroup is normal if and only if it remains unchanged under conjugation by all elements of the larger group.
