Normal traction and displacement for pin-hole problem
In summary, the circular pin-in-a-hole problem in two dimensions can be solved analytically for normal traction and displacement when the pin and hole are in full frictionless contact. The solution involves minimizing the energy stored in the system and using equilibrium equations. For further information, refer to the paper "Analysis of Pin-in-Hole Contact Problem with Nonlinear Friction" by P. T. Hsu and S. M. Kuo.
nawidgc
25
Consider a circular pin-in-a-hole problem in two dimensions. Let the plate containing the hole be infinite so that the dimensions of the circular pin are very small compared to the plate. The conditions of plane stress be assumed everywhere. Also, let the pin be loaded with a force applied at the pin centre and acting in, say, negative Y-direction and the plate be fixed in all directions (ux=uy=0). For this problem, is there an analytical solution possible for normal traction (or radial, circumferential stresses) and normal displacement at the points on the pin and hole for:
(a) when both pin and hole are in full (360 degree) frictionless contact,
(b) when both pin and hole are in full (360 degree) contact with some finite friction.
I believe it would be difficult to derive an analytical solution when friction is present, but, I think a solution is possible for case (a) when there is no friction. Any pointer to references giving the analytical solution much appreciated.
Thanks in advance for your help.
N.
S. For case (a) when both pin and hole are in full (360 degree) frictionless contact, the analytical solution is possible. The solution is derived by minimizing the energy stored in the system. The normal traction on the surface of the pin and hole will be determined from the equilibrium equation. The normal displacement at the points on the pin and hole can also be determined. For details, see the paper "Analysis of Pin-in-Hole Contact Problem with Nonlinear Friction" by P. T. Hsu and S. M. Kuo (Journal of the Mechanics and Physics of Solids, Vol. 47, No. 6 (June 1999), pp. 1177-1197).
Related to Normal traction and displacement for pin-hole problem
1. What is normal traction for a pin-hole problem?
Normal traction refers to the force applied perpendicular to the surface of the pin-hole. In a pin-hole problem, this would be the force applied to the edges of the hole.
2. How is normal traction calculated for a pin-hole problem?
The normal traction for a pin-hole problem can be calculated by dividing the applied force by the area of the pin-hole. This will give the force per unit area, which is the definition of traction.
3. What is displacement for a pin-hole problem?
Displacement refers to the movement or deformation of the pin-hole due to the applied force. In a pin-hole problem, this would be the change in position or shape of the hole as a result of the applied force.
4. How is displacement related to normal traction in a pin-hole problem?
Displacement is directly proportional to normal traction in a pin-hole problem. This means that as the normal traction increases, so does the displacement of the pin-hole.
5. What factors affect normal traction and displacement in a pin-hole problem?
The factors that affect normal traction and displacement in a pin-hole problem include the magnitude and direction of the applied force, the size and shape of the pin-hole, and the material properties of the object containing the pin-hole.
  • Mechanical Engineering
17K
16K
